mudguard installation
Discussion in 'Gen 3 Prius Accessories and Modifications' started by GaryD1, Feb 11, 2011.
  1. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    I got the smaller us version mudguards with 6 self tap screws and 6 spring clips for 2011 Prius.
    Is the metal where the mudguards fasten soft enough to screw into with hand pressure using the self tapping screws or do I need to predrill small holes?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
  3. ct89
    ct89 Active Member
    323
    266
    New England
    I did not need to pre-drill, just used a hand screwdriver and a little pressure.
    Removing the tire before installing is a must.
    Also, I decided to add an extra screw towards the inner edge of the rear flaps as they just didn't seem to be held secure enough with just the two outer screws.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    My Euro version didn't require any drilling into metal, only two into plastic.
  5. GaryD1
    302
    138
    Seagrove, NC
    While on the note of removing the back tire, can floor jack be used on rear of car? noticed it can in the center front
  6. Mendel Leisk
    41,234
    Not sure if gen II is the same, but looking at the wheel well liners on our gen III, there are push-in style fasteners securing it at most locations, but near the bottom are different fastener style: having flat plastic face with a hole. Could be these are located to match mudflap self-tap screw locations?
    Off-topic: this second type of fastener look to be a royal pain to remove, if you ever want to take off the wheel well covers, to see what mud/grit might have accumulated behind. It might be possible to get them out, playing with a pin to get the tangs to release, but it is very tedious. I like to remove wheel well covers periodically, and there's invariably a lot of debris accumulated behind.
    Addendum: ignore the bit about gen II vs III, see now the OP has gen III.
  7. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    I did some pre-drilling for some of the screws. The front is easy, since one can turn the wheels. On the rear, it probably would have been easier if I had jacked up the car and removed the rear wheels.
  8. unkprius
    unkprius Member
    152
    ^ Ditto here. I used an small electric drill with very small bit to pre-drill all needed holes as the plastic was really tough. Didn't remove rear wheels, in hindsight would have made it far easier/neater but took more time and work. I was putting in fog lights same day.
  9. GaryD1
    302
    138
    Seagrove, NC
    removed rear wheels, marked holes, used small bit. It was a breeze putting mudguards on. It took about 30 min to do all four.
  10. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
  11. ct89
    ct89 Active Member
    323
    266
    New England
    Here's a couple of pictures from my installation...If you look closely, in the second photo you can see the extra screw I added in the inside.
  12. unkprius
    unkprius Member
    152
    ^ I used a piece of aluminum duct tape to hold down that part, but when it finally gives out I'll put in a screw, should have done that in beginning.
  13. mario24601
    mario24601 New Member
    Los Angeles
    I see the extra screw you put on the rears...but maybe the 2012 flaps are different, the plastic section you put the screw on does not extend that far in the ones I just got in the mail...I wonder if they redesigned them somehow for 2012 models?
    Edit: I just noticed yours are US model, I got the Euros guess thats why they are different. Anyone with the Euro version put in extra screws?
  14. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    This is a very good idea & one that should have been thought of & included by the manufacturer.
  15. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Nice looking car. :) Thanks for posting pics after the install. Where did you purchase the mudguards?
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    You don't need to take the tire off if you use a small right angle ratcheting screwdriver.
    I like the extra screw idea, I used some high quality double sided tape and if that gives out I will take the extra screw approach
