Electro-Magnetic Radiation From Prius Gen II
Discussion in 'Gen 2 Prius Technical Discussion' started by ScotlandTim, Feb 10, 2011.
  1. ScotlandTim
    ScotlandTim New Member
    Scotland
    no, we don't do humoUr, not compared to the wonderful comedy of the Yanks.
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    Now I'm rather annoyed I took up my time to provide all of those links for this chump. Can I have those 7 minutes of my life back please?
    Do your own damned research and while you're at it learn how to perform proper automotive comparisons and you'll find that the average diesel DOES NOT get better MPG than the Prius when factors like size and HP/TQ are considered.
    5 people like this.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    There is a far, far, FAR greater health risk of driving a Prius simply because it is a small car. Here in the states, almost every vehicle on the road weighs more than Prius. There's only so much that airbags and crumple zones can do to protect you if you get creamed by a lorry.
  4. bisco
    52,337
    i thought the kilts with no underwear was pretty humorous.
  5. richard schumacher
    7,664
    1,046
    United States
    Tim, there's no clear evidence that EMF has health effects even at high levels, much less for the levels found in a Prius. If you can find any evidence please let us know.
  6. Politburo
    Politburo Active Member
    971
    208
    You think we don't have bullshit detectors on this side of the pond? LOL
    You can go back to your diesel forum now.
    2 people like this.
  7. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Well Tim please do let us know what other electrical items you currently use so we can compare your "risks". Do you have any of the following.
    - Refrigerator
    - Hair dryer
    - Microwave Oven
    - Toaster
    - Air conditioner.
    - Vacuum Cleaner
    - Washing Machine
    - Power Tools (drill or saw)
    - Mobile Phone
    - Cordless Phone
    - Wireless internet
    At a distance of 1 foot all of the above have stronger EM fields than the cabin of a Prius and many have stronger EM fields even at a distance of over 4 foot.
    Electro Magnetic Field
    2 people like this.
  8. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    I find the idea of you people eating Haggis pretty funny.
    2 people like this.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Which is the only reason I would wear a kilt
    "Whoops, sorry about that, I had no idea it was so windy today"
  10. F8L
    19,011
    4,083
    Grass Valley, CA.
    Now I know the secret to you and your harem of women. Then again you are probably restricted from going within 200ft. of schools and Chuck E. Cheese..
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    I am prohibited, by law, from going within 200ft of Chuck-a-Rama, any fitness center, or any public beach
  12. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Actually it can. But its the heat of (some) laptops, not any form of radiation.
  13. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    If you lot had bothered to look at Tim's profile, you'd see that he's been here since August and has already contributed to other threads. He's definitely not trolling.
    The sad fact is that there's a lot of unnecessary scaremongering around electromagnetic fields. As far as we can tell, there is no additional danger from non-ionising radiation at the levels that cars and car components, and indeed WiFi, mobile phones, and broadcast transmitters, are permitted to emit. The authorities are far more interested in preventing interference to radio transmission and reception, and ensuring that cars continue to work when passing under power lines.
    The International Commission on Non-Ionizing Radiation Protection, ICNIRP, sets down guidelines for non-ionizing radiation levels. ('Ionizing' is the classic layman's idea of radiation, due to alpha or beta particles, gamma rays, or cosmic rays - with sufficient energy to remove electrons from atoms, leaving an ionized atom. Normal EM fields are far, far, far below this.) In terms of electric field strength, they are, for occasional exposure:
    Column 1 Column 2 Column 3
    0 Frequency range Electric field strength V/m
    1–8 Hz
    20 000[/SIZE][/SIZE][/SIZE]
    2 8–25 Hz 20 000
    3 0.025–0.82 kHz 500/f
    4 0.82–65 kHz 610
    5 0.065–1 MHz 610
    6 1–10 MHz 610/f
    7 10–400 MHz 61
    8 400–2 000 MHz √3f[/LEFT]
    2–300 GHz
    137[/SIZE][/SIZE][/SIZE][/LEFT]
    Note that the lowest field strength guideline here is more than twice the maximum strength that the car is required to be able to deal with, and several hundred thousand times what it is permitted to emit.
    We're currently in the middle of our Digital Television switch-over, and a lot of the main transmitters are getting new transmitting aerials as the existing aerials were approaching or exceeding 40 years old. ICNIRP guidelines have required the power to be reduced at some sites while the masts are worked on, or new or temporary masts to be placed further away from the old ones. At the Sutton Coldfield mast, north of Birmingham, the engineers' calculations for the temporary mast's location were incorrect and the power had to be reduced to protect workers on the main mast. It's transmitting four analogue TV channels at 1,000 kW effective radiated power, plus six 8 kW ERP digital TV multiplexes. Oh, and five national radio services at 250kW each, and five local radio stations at 10-11kW. And three DAB digital radio multiplexes. This site is less than 250 yards from some houses and under a mile from the main M6 motorway.
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    I did look and I did a quick search on his username and found him on Fuely.com and such. That is the reason I bothered to try and help him in the first place.
  15. qbee42
    3,079
    I did too, not that he seemed to appreciate it. It seems that people often start this sort of thread with a preconceived notion, and when we don't support their notion, they feel abused and whine about it. The whining annoys some of the regulars, and they get a bit snarky. The snarky comments incite the OP, who then lashes out, which then causes a massive pile-on. Ten or fifteen pages later it's a full blown donnybrook, and no one can remember how it started.
    I've seen this pattern too many time to be amused.
  16. F8L
    19,011
    4,083
    Grass Valley, CA.
    We've been around too long. :)
  17. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I still find it amusing. :D
  18. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I didn't think the majority of the original answers to the OP's question were all that "insulting" as he seemed to think they were. In hindsight I'm pretty sure he was just looking for an argument in this instance.
  19. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    That's not an argument its just contradiction. No its not. Yes it is. Its not.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Since we have strayed far, far off the disproven link between Prius cars and "EMF" dangers, I might as well throw this out:
    BAAAAAAAAAAAAAAAAA
