Starting problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by vivamom, Feb 7, 2011.
  1. vivamom
    vivamom Junior Member
    Pennsylvania
    We have a 2007 Prius with 70,000 miles on it. Twice now, the car has refused to start. Yesterday we tried to jump start it, got nothing. We went shopping with the other vehicle, came home, and then it started when my husband unlocked the car with the remote. It happened again today. I always use the smart key, it wouldn't start. Dead! My husband took me to work, then came home, unlocked it with the remote and it started again. What's up with that??? Any ideas? We just had it serviced a few weeks ago.
    Thanks!
    Mary Alice
  2. Patrick Wong
    18,210
    6,511
    Replace the 12V auxiliary battery.
    2 people like this.
  3. vivamom
    Pennsylvania
    That's what we were thinking, Patrick. Thanks!
  4. Patrick Wong
    18,210
    6,511
    In case you were wondering why the car starts sometimes and why it doesn't at other times: the 12V battery apparently is at a marginal level. The battery produces electric power from a chemical reaction, and chemical reactions speed up at higher temperatures.
    When the battery is warmer then it will produce more power. If you try to start the car later in the day after the battery has a chance to warm up, there's more likelihood that the car will start.
    I also suggest that you review the jumpstart procedure used, as it should have worked. There's something wrong with the way the jumpstart was implemented. Perhaps the jumpstart cables are bad. Perhaps a cable connector did not properly connect with the Prius dedicated positive jump start terminal, etc.
  5. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Just a thought. . .
    Every time you try to start it, it fails? Every time your husband unlocks it with his remote and starts it, it starts fine?
    If it isn't the 12V battery, is it possible that your smart key battery needs to be replaced, but your husband's is still ok?
    - Danny
  6. Patrick Wong
    18,210
    6,511
    Good point, it is an excellent idea to ensure that the fob is not part of, or all of the problem. If the OP was able to enter the car using her Smart fob in the usual way, then I assume the fob battery had sufficient power so that the fob would be recognized by the interior receiver and the Smart ECU. However it doesn't hurt to rule that out as a possible issue.
  7. vivamom
    Pennsylvania
    Well, we got the new 12V battery from the dealer and installed it this morning (in bitter cold weather) and NOTHING!!! All the interior lights work, the locks work, just as they did before. The open door symbol shows, but it won't start. Any ideas?
  8. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    Wow, this is a strange one. Can you tell us, do you have Smart Key, or regular keyless entry? If Smart Key, are all of the smart functions working, such as unlocking the car by touching the door handle? In either case, have you tried all your keys?
    The fact that your interior lights work means that the fusible link is intact and you don't have a reverse polarity problem, which is good. But you are getting into repair shop territory, i.e. combination meter, if our simple suggestions don't help.
  9. Mendel Leisk
    41,749
    I'm thinking it's dying FOB batteries.
  10. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Don't despair - your 12V was probably on its last legs, anyway. You've just saved yourself being completely dead in the water at the worst possible time. Four years is a long time for these batteries.
    Try replacing the fob battery, too. :thumb:
  11. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    If the car won't start you can also eliminate the fob batteries as a cause by putting the fob in the slot in the dash and see if the car starts. If it still doesn't start then its not the fob battery.
  12. Patrick Wong
    18,210
    6,511
    1. Turn on the headlights and see how bright they are. Then turn off.
    2. How much fuel in the fuel tank?
    3. Can you cycle through IG-OFF, ACC-ON (where the MFD turns on) and IG-ON (where the instrument panel warning lights are all on) modes by repeatedly depressing the POWER switch without depressing the brake pedal?
    If there are no problems evident from the above, then press hard on the brake pedal, press the POWER switch, and see if the car will become READY.
    If not, then looks like you'll need to tow the car to the dealer for help.
  13. vivamom
    Pennsylvania
    Saturday night we tried and it wouldn't start, but the headlights came on and the smart key worked to open it. Got no start yesterday either, so this morning my husband called the tow truck to come and take it to the dealer. He decided to try again before the truck came and it started! So he drove it to the dealer to get it checked out. I'll let you all know what they say! The temperature is a bit warmer this morning, up in the early 40's, but with a new battery I don't think that should matter. I'll just be glad to have a car again!
  14. uart
    uart Senior Member
    4,220
    1,211
    Australia
    This question is absolutely vital to diagnosing the problem. Vivamom you really should have given this information right at he very outset because the answer totally influence what are the possible causes.
  15. vivamom
    Pennsylvania
    Well, the SmartKeys were not the problem. I didn't think that was it because both keys worked to open the car. We still don't know what it was, either! Like I said, it started on Monday morning and my husband drove it to the dealer. They checked it out and had no idea what was wrong. So I told him to bring it home as I was sick of being without a car! It worked fine again this morning in 16 degree weather, so I don't think the temperature was part of it. Anyway, the dealer didn't charge us, which was nice of them! I appreciate all of your help and comments!
    Mary Alice
  16. bisco
    52,189
    i gotta wonder about your brake switch. perhaps you don't press as hard as your husband.
  17. Patrick Wong
    18,210
    6,511
    +1 regarding pressing on the brake pedal hard, as you press the POWER button.
    Should you have a future recurrence of the problem, I suggest that you try #3 from my post #12 above. Should you find that you cannot cycle through the three modes, that will provide an important clue towards solving the problem.
  18. vivamom
    Pennsylvania
    Well, Fellow Prii owners, here is the latest. Toyota could find nothing wrong last Monday after it started and we drove it down there. It worked fine for three days, then died again. While it was running, everything was normal. Gas tank is three-quarters full. Friday morning, it died again. Absolutely dead - no signs of life. We had a busy weekend, but tried to start it a few times with both keys, in and out of the slot and got nothing. We did not try to jump start it. We had a flatbed trailer take it to Toyota this morning and heard nothing from them all day. I called around 5:00 and spoke to the guy in charge of it. He said he had their "hybrid guy" look at it and he can usually fix those in half an hour. Neither of them can find what is wrong or get it started. They have called Toyota for an incident number. So we will see what happens tomorrow. He did tell me that he will ask the general manager for a loaner car if they find nothing tomorrow and can't fix it. A mystery.....
    Mary Alice
  19. Patrick Wong
    18,210
    6,511
    When you say "no signs of life", did the cabin interior lights come on? Do the headlights appear bright? (This shows that the Body ECU works and the 12V battery has sufficient power to light up the headlights.)
    Was it possible to cycle through ACC-ON and IG-ON or was the car totally non-responsive when you pressed the POWER button? If the latter, my guess is that the POWER switch might be bad. If that is good, then it is possible that either the Transponder Key ECU or the Power Source Control ECU is flaky and needs to be replaced, assuming that the headlights could be turned on and are at normal brilliance, as stated above.
    Since you inserted the fob into the fob slot, without any improvement in symptoms, that rules out the Smart Key ECU as a potential issue.
    Let's see what action plan the dealer develops on Tuesday, since they also have experienced your car's no-start symptoms and cannot say that the problem is due to driver error. Hopefully the car has logged a DTC that will provide a clue as to the root cause of this problem.
    Suppose by tomorrow the problem goes away and they say they can't find a cause so they want to return the car to you as-is. You might decide to ask them to start "throwing parts at the problem" by replacing likely parts such as the POWER switch, Transponder Key ECU and the Power Source Control ECU. However, since your car has 70K miles, unless you have extended warranty coverage, you'll be charged for the repair. Good luck.
  20. seilerts
    3,326
    1,519
    Santa Fe, NM
    In a way, this is a relief. At least the car is demonstrably broken while at the dealership. I meant to mention a couple days ago that there is an issue with the IG1 relay becoming frozen at very low temperatures but it sounds like that is probably not the case here from the latest news :(
