Rough loud start (what the dealer said)
Discussion in 'Gen 3 Prius Main Forum' started by i8z, Feb 12, 2011.
  1. i8z
    i8z Junior Member
    Columbia Maryland
    I have driven 25,xxx miles on my 2010 Prius. Three times during the last thousand miles I have experienced very loud and scary engine noises during start up. The car had sat for at least ten hours outside in 20-30 degree weather.
    I took the car into the dealership for an oil change and my service advisor told me that Toyota was aware of the problem and the noise was not coming from the engine- but a device that mates the ICE with the electric engine. He told me that although it was a loud and dangerous sounding noise, it was not something that would harm my motor. I asked that the noise be logged into my service record.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thanks for the heads up. Can't imagine that is where the noise is coming from but hey, they should know... right?
  3. cobradb
    cobradb Member
    105
    tn
    there are many post on here with this subj;
    I think it is the engine, and the dealer is full of it,,
    my 2010 did this just after i bought it.
    IT SOUNDED LIKE PRE IGNITION AND THEN THE ENGINE WAS RUNNING BACKWARDS
    These are a very high compression engines and if the intake valve were to close too quickly it could go into pre ignition.
    normally the intake valve stays open some on the compression stroke compared to normal ICE.
    as i understand it''
  4. bisco
    51,882
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    My BS detector is going off.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Oh boy, here we go again.
  7. bisco
    51,882
  8. socalev
    socalev New Member
    31
    mission viejo
    32K colors.
    what is your theory this time?? Very interested in what your special bio research / bs detector abilities are telling you?
    What does i8z do for a living?
    do they own a prius?
    are they a troll?
    Please do tell
  9. richard schumacher
    7,664
    1,046
    United States
    Not really; 9.something compression and about 13 expansion, through the magic of variable valve timing.
    Because motor/generator #1 spins up the engine before fuel and spark are applied it is not credible that the engine could ever run backwards.
  10. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Just a hunch based on the many threads in which the OPs were told erroneous information by their service manager/dealer. Nothing wrong with the OP here. Moreover, many regular posters here would've been told this if it were true, not just one OP.
  11. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Would be more helpful if you included some details on what the loud and scary noises sound like.
  12. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    It's a known problem. Search for rough engine start, violent shaking at startup, etc.
  13. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    Here ya go.
    2 people like this.
  14. DAFTEK
    DAFTEK Junior Member
    94
    Midwest
    Add my 2010 Prius V to the list, Just purchased with 12,500 miles and does the same thing for 3 to 6 seconds! The day i picked it up from the dealer it did it to the sales guy and when i questioned him he said it was nothing and could not reproduce it. Now after over a week it has done about four times in the morning only. I will try and video this also and post it. the more people post it the better chance Toyota looks into it.
    This is my first Toyota but i have to say I'm disappointed, I'm a huge Ford & Subaru guy and have i absolutely wanted to love this Prius but i might just trade it in for a Focus EV now. It not only has an engine knock it also rattles inside like a cheap econobox, this is a $32,000 Prius V! Wth was i thinking selling my 2005 Outback XT-LTD :(
  15. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    This is fairly incredible coming from Toyota. Must be extremely rare happening in a Toyota, yet it's happening in Prius and seems to be popping up here and there. :eek:
  16. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    "Toyota is aware of it"
    Probably, but I have not seen a single instance in which toyota has acknowledged this sound. Also, the ICE mates to the electric via gears. How can this be that? It sounds absolutely like the ICE itself and nothing to do with that.
    What the dealer said sounds dubious. First I've heard of a) Toyota officially recognizing this and b) any concrete diagnosis of the issue.
  17. i8z
    i8z Junior Member
    Columbia Maryland
    Why would I be a troll?
    I simply posted my experience with the noise and what the dealership told me. Some of you posters on the internet crack me up.
  18. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    eh...
    what i've gathered is that this is exactly what he didn't tell you it is... well.. he did.. but didn't...
    it's a giant spring of sorts that cushions the movements of the PSD against the ICE.. and if it doesn't shift right.. as it so frequently seems to do... then it makes knocking noises because the sound is transferring strait through that piece since it's metal on metal.. they installed that piece to make the car smoother... so.. it's really there to make people happier... not the engine... it's a simple design and it works... it simply sounds like crap on start up.
  19. LoveMyPriusIII
    LoveMyPriusIII New Member
    66
    Do I see another recall coming?
  20. Skoorbmax
    2,641
    265
    Western NY
    Nobody said you were trolling but that what the dealership told you was possibly BS.
