Keyless Entry defect, or normal?
Discussion in 'Gen 3 Prius Main Forum' started by davide, Feb 14, 2011.
  1. davide
    davide Junior Member
    86
    suburban Detroit
    I was walking into a store today when a Gen 3 Prius rolled up, so since I haven't bought one yet, I HAD to talk to the driver awhile. She was very nice...purchased it just before year's end. She said one thing she didn't like was having to press the key fob twice in order to unlock the front passenger door. So I'm wondering: Is this some defect, or just the way it works? Is this what the glossy brochure (in the back, under FEATURES) means by "2-stage unlocking"?
    Also: If I don't buy the Prius IV or V, will I need to insert a key to open the hatch?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    should help answer some of your questions.
    2 people like this.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    You can program it so that pressing once will unlock all doors at once. I have this on mine.
  4. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    It can also be programmed so that opening the driver's door will unlock all doors as well. Also, you don't need a key to unlock the back hatch, pressing the unlock button on the key fob twice will unlock the hatch. I have mine set so all the doors unlock when I touch the driver's door handle, this also unlocks the hatch.
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i recommend smart start smart entry.. or whatever they call it now. (i'm so '04)
    this allows you to leave the key in your pocket the entire time. not sure if anyone watched the video.. kinda boring... well.. i Have seen it before....
    it's a joy to be able to walk up, and simply touch with 1 finger to open a door.. even the hatch ( it has a static sensor with a digital touch pad/switch) so it knows you're there and you're simply depressing a button to open the door.. not a real handle.
    then i jump in and start.. it's all pretty instant... not jumbling for keys saves me a LOT of time.
    it only sucks when you forget to transfer your keys to your new pants.. walk out to the car, and it simply doesn't respond... gr.. no key...
  6. Paul58
    1,126
    125
    Atlanta
    Unfortunately, with the Gen 3 Prius, what you describe only works with the IV and V Models. With the II and III Models the "touch" entry only works on the driver's door. But, there are programming work arounds like those described above...
  7. mmcdonal
    mmcdonal Active Member
    666
    98
    Columbia MD
    04 Camry Hybrid key worked the same as the Gen III key in this regard. Twice to open all doors. On the 04 Camry key, you would hear 4 beeps as it cycled unlock twice. On the Gen III key, you only hear 2 beeps even though it cycles twice, so I thought that was a nice mod.
  8. krelborne
    krelborne New Member
    295
    Alabama
    "Once for driver side, twice for all doors" is what I would expect. Both of my other cars (Subaru and Ford) unlock this way. I'm happy to see that this is configurable, though, because the driver's door thing sounds convenient.
  9. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    God! What would she do if she had to use a KEY??
  10. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    There is a reason it can be set for one press drivers, two press' all doors unlock. It's called security. On a dark night in the "wrong" part of town, you DON'T want to unlock all doors! Even when that woman is in the "right" part of town, she should be thinking about that!
    As far as one door SKS, it's still SKS. Yup, it's a lot of work to open the door and press the door unlock switch on the door to unlock all the other doors. ;) But you can still keep the FOB in your pocket, opening and starting the car without removing it.
  11. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    No, the smart key fob will unlock the hatch if it's programmed correctly. I programmed my Prius III to unlock the doors and hatch by touching the driver door handle. I also have it programmed to lock all doors when I put it in gear. Hope this helps.
  12. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yes, that's why I think it's a dumb idea to program it so that opening the driver's side door unlocks all doors. It's better to program the remote so all doors unlock in one step. That way, if you have passengers you can use the remote and if you're alone, you just open the door via the handle and only the driver's door is unlocked.
    I'm amazed how many people here are willing to take this risk.
  13. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    I think that it's all to do with your perception of the risk which amongst other things, it has a lot to do with circumstances where you live, drive and park the car.
    It's good that we have the choice.
  14. twittel
    1,605
    148
    Mt. Pleasant, SC
    I even lock my Prius when I'm standing next to it refueling at the pumps. Hey, I've got stuff sitting sitting in the car what can I say?
  15. qbee42
    3,079
    Exactly. Most in this area don't lock their cars or their houses, even when leaving on vacation. It's common for people to leave keys in the car. If you ask people about it, you get answer like "Well, what if my neighbor needs to use it and I'm not here?"
    It's a good way to live, but I'm not sure that it can last.
  16. Paul58
    1,126
    125
    Atlanta
    Well, considering I'm the primary driver (i.e. my wife never drives it) and we use it to run around on weekends, it's more of a convenience to have all doors and hatch unlock with a touch of the drivers door than digging out the remote when you arms are full or having to open the drivers door and reach in to unlock all the doors. Yes, it's nice to have a choice, and in my case it's not really a dumb idea, but a major convenience option!
    My wife's HS is programmed just the opposite, for the very reason you cite, because she is the primary driver and often is alone. So, having just the driver's door open is a better option for her safety. Again, have the option to program each vehicle to what works best for the primary driver is a smart idea IMHO!
  17. davide
    86
    suburban Detroit
    That YouTube video plus the various comments have been very informative--thanks to everyone.
    This technology is amazing. It will be SO convenient compared to my current 1992 car.
  18. fuzzy1
    10,406
    Sounds like 'home', where dad still lives. I've never seen keys for the Great War era 'locks' on that house -- they'd be pointless -- and modern locks would get in the way. I sure hope it can last.
    But I moved out of that rural environment long ago. Relatives in urban Portland suffered kitchen burglaries while they sat at the dining room table. I couldn't even accept the automatic 4-door unlock when the car went into Park. Whether inside or outside, no car door unlocks until I command so. Fortunately, choice is programmable.
  19. tonyrenier
    362
    44
    Green Bay, WI
    Seems that no one has mentioned that if you push the unlock button on the FOB twice all doors and the hatch unlock. This is not rocket science.
  20. Bob Powers
    Bob Powers Junior Member
    Meadowlakes Texas
    I bought a 2010 Prius IV within the week, and my key fop has stayed in my pocket 100% of the time since then. You don't need to use the key or buttons on it to unlock doors, start engine or lock doors. You just have to have it in your possesion and be within about 2-3 of car to enable the door unlock feature on the door handle. This also works with the rear hatch.
