Why does the ICE turn on sometimes when I put it in Park?
Discussion in 'Generation 1 Prius Discussion' started by BentSpace, Feb 14, 2011.
  1. BentSpace
    BentSpace Member
    195
    Reno
    On my 2002 sometimes when I come to a stop after rolling around with the ICE off, then right after I shift in Park the ICE starts up.
    Why would it do that?
    Is this a bug or is it normal?
    Thank you.
  2. richard schumacher
    7,664
    1,046
    United States
    The engine decided at that moment, by co-incidence, that it needed to warm itself up.
  3. BentSpace
    BentSpace Member
    195
    Reno
    It doesn't happen every time, but it seems to happen too often to be a coincidence. Especially the timing of it turning on right after putting it in Park, it definitely seems linked to the action of putting it in Park.
  4. ChapmanF
    18,436
    I notice that too; I don't think it's a bug; the HV ECU probably had wanted to start the ICE anyway, either to maintain temperature or state of charge, but hadn't wanted to badly enough to do so in gear (where no matter how well it coordinates MG1 with an opposing torque from MG2, you're still likely to feel a bit of a jolt). My guess is they gave it a lower threshold for deciding to start when in park, because then MG1 just acts against the parking pawl and the start won't jerk the car.
    It does turn out to be pretty futile the way I drive anyway, since about the only time I shift into park is just before taking out the key.
    -Chap
  5. bisco
    52,263
    a lot of times, when i pull up to a light, my engine will continue to run. then, when the light turns green, as soon as i let off the brake and step on the gas, the engine shuts off for a second or two and then comes on again for power as i accellerate.
  6. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    Unrelated vehicle, obviously, but my 2010 Honda Insight would always do that. It would run the engine constantly when in park, even if it was off before shifting to park. i found it highly irritating.
  7. Mendel Leisk
    41,809
    Honda Civic Hybrid tactic when parking: pull into spot, wait for AutoStop to initiate, turn key to kill ignition, then shift into Park. Other way 'round, shifting to Park first: it fires up again, for frustrating second or two.
  8. BentSpace
    BentSpace Member
    195
    Reno
    I guess I could just turn it off before I put it in Park, just seems a little backwards. You would think they would have planned that most people put it in park right before turning it off, so what's the point in firing up the engine for 1 second.
  9. Patrick Wong
    18,210
    6,511
    I recall that the reason for the Classic gasoline engine spinning up when you shift to P is to help calibrate the engine ECU. 2G does not do this.
  10. BentSpace
    BentSpace Member
    195
    Reno
    Hmm... interesting, so maybe I shouldn't try to thwart it by turning it off before putting it in Park.
  11. bisco
    52,263
    maybe if the gen III did it, it wouldn't have the crazy startups.
  12. mlibanio
    mlibanio Member
    304
    61
    Toronto
    2002 Prius
    I
    Hi there, I am just curious why this is of such concern? Are you a new owner? Don't get me wrong, I am not being mean in anyway, I am just curious and hope to change your mind as to why this is annoying when its actually a very cool thing about our cars! : )
    My Prius almost never does this in summer. Mostly in winter. It will do this however, if the battery SOC is low enough in any weather, when shifting into park. However, just let the car do what it needs to do. It is doing its absolute best at all times to prolong battery life. My car has 200,000 kms on her and the battery is 100% perfect. Ask yourself, would you rather waste about $0.02 of fuel that it took to start you car for that small period of time to calibrate, or replacing a $2000 battery simply because you did not want to let it get calibrated? That is just my opinion. I find it in no way annoying, and in fact find it impressive that Toyota programmed such a contigency into a first generation car like the G1 Prius. The newer Prius's get away with such things due to superior advancements in battery and ecu design, but given the nature of the way our THS works, I think its pretty good.
  13. john1701a
    john1701a Prius Guru
    12,819
    5,304
    58
    There were actually multiple potential "housekeeping" tasks the Classic model would perform upon shifting to Park. That was totally normal... and yes, welcomed later when the redesign eliminated the need.
  14. BentSpace
    BentSpace Member
    195
    Reno
    Not sure if this was a question directed at me, but I'll answer it anyways :). Yes, I am a new owner. Wasn't annoyed by it, so much as I was just trying to find out if it was a bug or something, but it looks like it's the norm.
    If the engine starts up when I put it in Park should I turn off the car right away or let it run till it turns off by itself and then turn off the key?
  15. Patrick Wong
    18,210
    6,511
    Well, if you want the systems to do their "housekeeping" activities, then you will allow the engine to run until it decides to turn off on its own.
  16. hill
    8,894
    Well . . . I wouldn't go so far as to say the Gen2 eliminated ALL the housekeeping tasks. We DO have to deal with that whacky 8 seconds stopped, in order to permit stealth below 35mph . . . even though temps ought to permit S4 without you having to come to a stop. But each generation does seem to get a bit better.
  17. BentSpace
    BentSpace Member
    195
    Reno
    Yes, I definitely will now that I know.
    Strangely I don't remember reading anything about that in the owner's manual, but maybe I missed it or maybe they forgot to mention it, but it sounds pretty important like something they should have mentioned if they didn't.
