Prius shifts into reverse instead of drive
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sbgreene, Sep 7, 2006.
  1. sbgreene
    sbgreene New Member
    I have a 2004 Prius with 78,000 miles. Recently, the car has occasionally shifted into reverse when I put it in drive. At first, I thought maybe I was getting confused (after driving it for three years), but I started tracking it, and it definitely happens. I took it to my dealer, who has replicated the problem. They say that the sensor in the shifter is failing to detect the shift, so if the car was last in reverse, after I shift and put it in drive, it still thinks it's in reverse. Fortunately, with the beep, I caught the error pretty quickly. Unfortunately, the dealer says the shifter is back ordered, and they can't get me a new one until October. Until then, I'm driving a rental. No navigation, no bluetooth, no carpool lanes, and lousy gas mileage. I'm bummed.
    Anyone else heard of this? Why are shifters back ordered for a month?
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    what do they mean October? there isn't anything on a Prius that can't be had in 3 weeks max. Tell them to call Toyota HQ and expidite the order. man, how dumb can they be...don't let me answer that.
  3. nancym
    nancym New Member
    denver
    My 2006 Prius is also going into reverse when putting it in drive. It's been doing it about every 1 out of 30 times the past 10 months. I have had the dealer check it out 3 times and they claim they can not replicate the problem, so they will do nothing to fix it. How can I make them fix it???
  4. richard schumacher
    7,676
    1,058
    United States
    Tell them you'll sue their asses if it contributes to an injury accident. Or see whether another dealer will be more helpful.
    Can *you* replicate the problem while at dealer #1?
  5. rsforkner
    rsforkner Member
    369
    Boynton Beach, FL, USA
    2014 Prius v wagon
    I'm getting used to it, but the operation of the shift lever really bothered me for the first few weeks. Maybe it's just me but it always seemed to me that it worked backwards.
    When I push "up" I expect to go forward and "down" I want it to go in reverse. That just seems "normal to me. I had to really watch it for quite a while.
    Did anyone else find this behavior strange?
    Bob
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    This has been the subject of *many* forum threads, but think
    about this: when you have one of those typical center-console
    automatic PRNDL shift levers, which way do you move it to
    go into Drive? Toward the rear to move forward, and toward
    the front to enter Reverse. That's pretty nonintuitive too,
    when you think about it, yet nobody complains. Now take that
    panel and lever and move it up onto the vertical dash.
    _H*
  7. rsforkner
    rsforkner Member
    369
    2014 Prius v wagon
    Dang, didn't think of it like that. I guess that came from the old column mounted levers, pull(down) to go, push (up) to Park.
    I guess I was thinking in terms of a switch: i.e. the wiper switch. Down is on and Up is off. My old Chevy was Up for on and Down for off, like a light switch at home.
    Like I said, I'm getting used to it. It's just harder when you get old.
    Bob
  8. fdr1968
    fdr1968 New Member
    Newburyport
    I have a 2008 Prius with 51,000 mi. I have taken it to the dealer for all the scheduled maintenance appts. and have not had any problems. I have had a a few minor incidents involving shifter problems in the last couple of months but didn't really think anything of it until I had an accident tonight. I parallel-parked into a tight spot and wanted to pull the car forward a little. The shifter did not detect my shift into drive and instead sent me in reverse and I crashed into a pick up behind me. the truck had a protruding towing hitch (?) on the front which sank into my rear bumper, and now I have a nice hole in it. I am hoping that when I take the car to the dealer that they can replicate the problem and fix it for me. Anyone out there with a similar story or any advice? I saw the old post from the 2004 Prius owner, so I know that I'm not crazy and that the same thing happened to me. It also was so quick that there was no time for the reverse "beep" to kick in and warn me.
  9. Patrick Wong
    18,210
    6,514
    I think that you should have the shift lever replaced.
  10. Flashlight
    Flashlight Junior Member
    Oakland
    I thought this was happening to me sometimes, and just the other day when I was dropping some friends off at the airport it happened to me twice in a row. I thought I might be crazy but I'm convinced now.
    My original spot where I pulled in at the terminal dropoff was kind of blocking another car from being able to pull out, and so I hurriedly jumped in the car and tried to pull up a little bit and out of the way.
    Two times in a row I put the car in drive and it went into reverse. It didn't make sense to me because if I didn't move the lever down far enough when I flipped it, it should have just gone into neutral, the next step up. If I 'undershot' it, it should have gone into neutral, not two steps up down into drive (see attached pic).
    Thankfully I braked pretty fast both times, and nothing bad happened.
    Seems to only happen when I'm in a hurry.
  11. priushippie
    priushippie New Member
    330
    Pennsyltucky
    Please look at the indicator in the disply to make sure you actually put it into drive.
  12. priushippie
    330
    Pennsyltucky
    Why are there so many people with just a few posts now that Toyotas have a problem?
  13. qbee42
    3,081
    Perhaps they just learned how to type.
  14. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Yes, these are strange days indeed.
    The concept of "trolling" doesn't exactly fit what is happening.
    We need a new metophor, something that encompases piling-on,
    sneakiness, and a lingering sense of malevolence.
    "Worm" or "snake" isn't quite right.
    Something along the line of;
    * Hyena
    * Jackal
    * Piranha
    * Cockroach
    * Leach
    On a lighter note, how about "duck?"
    As in; "Nibbled to death by ducks."
    Chihauhua?
  15. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    "cork sackers" ?? :D
  16. prius42349
    prius42349 New Member
    Kentucky
    I just bought a 2011 Prius Saturday. This is my second Prius. It did a very scary thing the second I had it. When I pulled into a parking lot, I hit a bump. When I pushed the accelerator to go again, the car started going in reverse, but the dash still showed drive. I attempted to put in drive again but still went in reverse. It done go forward until I put it in park then drive twice. I never had thing like this happen with my 2008 model. The dealership said they couldn't find a problem. Does anyone know what happened? By the way, my kids were with me and verified it was showing drive while going in reverse
  17. studiopeg
    studiopeg Junior Member
    63
    I know this thread is old, but I'm glad I found it. Three times recently my 2007 Prius has gone into reverse when I put it into drive. No backup camera, no reverse beep-beep-beep, but nonetheless it goes into reverse.
    Next time I will try to remember to just hit the brake and look at the dash to see what gear it "says" it is in. Pretty scary stuff.
  18. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    If your issue is legitimate, besides getting it fixed, I recommend filing a safety complaint at Home | Safercar -- National Highway Traffic Safety Administration (NHTSA).
  19. studiopeg
    63
