Can someone help me understand the PHEV conversion options?
Discussion in 'Prius PHEV Plug-In Modifications' started by BrettS, Feb 14, 2011.
  1. BrettS
    BrettS Active Member
    290
    137
    Orlando
    I've had my 2010 Prius III for about a month now and I'm considering doing a PHEV conversion on it, but I have a lot of questions. First, as some background, my commute is about 22 miles one way... mostly surface streets and mostly with speed limits between 35 and 45... a few 25's and 30's in there and a few 50's and 55's and about 3 miles on the highway.
    The traffic doesn't really support pulse and glide, so I've been trying to maintain my speed and trying to remain in electric only mode when the speed limit is under 45, so I drain the battery and recharge it several times during the commute. I'm thinking this makes me a good candidate for a PHEV conversion... if the kit can keep the battery charged while I'm running in EV mode then I shouldn't have to run the generator at all while I'm going above 45 and theoretically it should improve my mileage.
    Now, here are my questions...
    1 - Do you agree that I would be a good candidate for a conversion?
    2 - Given that my commute is 22 miles each way, how much battery power do you think I'd need. I don't know if I can recharge at work, but I suspect I can. If I decide to go forward with the conversion I'll talk to the people there to find out for sure.
    3 - How does EV mode work in a 2010 with a conversion? I've found that now I can accellerate from 0-40MPH on a flat road staying on electric power only, but it's a very slow accelleration and not really feasible... can you accellerate faster in EV mode with the conversion or is this a Prius limitation and I'll likely still be using the ICE for accelleration?
    4 - What are the differences in the available kits?
    5 - Anything else I should know that I'm not thinking of?
    Thanks much,
    Brett
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    I'm a little busy right now to fully answer via the post, but feel free to give me a call during business hours and I could discuss this with you. You're on the right track and asking good questions.
    608-729-7082.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    This is just my opinion though others may say otherwise.
    PHEV conversion will improve mileage no matter how short the distance traveled. Of course the longer the distance traveled, the better mileage you'll get with or without PHEV kit. Example, if you travel 2 miles per trip, you could average only 30mpg. With PHEV kit you can improve that to 45mpg. If you travel 20 miles per trip, you could average 55mpg. With PHEV kit you can improve that to 80+mpg.
    My 4KW kit lasts about 30 to 35 miles per charge blend mode. If you can recharge at the end of each trip, then a 4KW kit would work. 44+miles would require 6kw kit without recharge in between. Last I heard, Enginer is designing a 6KW kit that will fit in the current 4KW kit enclosure. Not sure when the 6KW kit will be available.
    Acceleration with PHEV conversion will be faster than none PHEV kit but only slightly. Though I haven't timed it but I suspect that a stock Gen III Prius takes about 40-45 seconds to accelerate from 0 to 40mph where as a converted Gen III Prius may take 30-35 seconds to accelerate from 0 to 40mph. This is no where near any record setting acceleration but if you're in rush hour traffic, it's well within the normal driving condition.
    Enginer is the only kit available for 2010-up. PICC will make one in the future but it cost between 12,000 to 14,000 dollars. PICC kit functions the closest to that of the OEM PHEV. It's capable of all EV driving for up to 40 miles and It can sustain EV only up to 70mph. Not sure how fast the acceleration is though.
    grill blocking is the best $2 you'll ever spend to improve gas mileage. Combine that with PHEV, you'll hit 80mpg in shorter distance traveled than none grill blocking.
    Enginer kit is the only option right now for Gen III. Their reliability is questionable. My kit lasted only a week and only 250 miles before the converter burnt out. Other members are reporting failed cells, failed BMS, failed converters, converter not putting out enough power to improve mileage. It comes with standard 2 year warranty. The warranty does not state any mileage limit so I'm guessing it's unlimited miles. Since Enginer is now dealer/installer purchase only, you will most likely need to have them installed it as well. There is a premium installation/warranty package that covers parts and labor for 5 years. Again, no info on mileage so it is possible that the warranty is 5 years/unlimited miles. I wonder if Jack will extend my warranty to 5 years if I pay him the $1000 for CARB.
  4. BrettS
    290
    137
    Orlando
    Thanks for the reply:)
    Currently I'm averaging low to mid 60's on my 22 mile commute... I'm hoping I could get it well above 80 or 90 with a PHEV kit, but even so I'll have a hard time justifying it to my wife if it won't pay for itself in a few years, or at least come close to it.
    Well, I guess that makes it easy to narrow down my options;) At least the Enginer is the lowest cost one... if I have any hope of getting it to pay for itself I think Enginer would be the only option.
    On a side note, do you know if it's possible to upgrade from the 2K to the 4K Enginer kit just by adding another 2K worth of batteries? That way I could get started for a lower cost and then upgrade later if it was working and I was running out of power part way through my commute (which certainly seems likely based on what you said above). If I'd have to toss the 2K kit and buy a new 4K kit to upgrade then it makes a lot less sense to start with 2K
    I don't think grill blocking is for me... I'm in Florida and we spend most of our summer in the 90's. Even this time of year we might get mornings at 40 or 50, but it'll still get into the high 70's or 80's in the afternoon. Plus my car usually spends the nights in the garage, so even if it's 40 degrees outside the engine starts out at 70.
    That's a bit worrysome, but as long as they stand behind the product (and stay in existance) then hopefully they'll get everything worked out in the two years its under warranty and I'd wind up with a solid product after it expires.
    Thanks again,
    Brett
  5. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Brett,
    You can spin it however you want, but it would take a lot for someone to convince me that any PHEV will pay for itself. You have to think of it more like any other accessory you purchase; You get it because you want it, not because it will pay for itself.
    The other systems have different benefits. For example, if you put in a Plug In Supply kit (not to be confused with PICC) it would provide longer all-EV mode, but it does cost more.
    Upgrading is possible. But if you cannot charge at work there is no way a 2kwh unit will last the whole commute. You will probably not be satisfied with a 2kwh system and will want to upgrade. That said, it may be easier for you to get your wife to agree to the lower cost 2kwh system first, and then casually add the extra 2kwh later.
    The Enginer system is a constantly evolving product. There are positive and negative aspects to this. I encourage you to keep exploring your options and gaining input from others. Take a look at the Enginer forums as well.
    I've experienced all the kits and would be happy to chat anytime. If you'd rather I call you, just PM me a phone number and a time to call.
  6. dan2l
    dan2l 2014 Prius v wagon
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Brett,
    If you do not have a Scangauge get one. You want to use the Scangauge to optimize temp. You need to get it up to 155degF as soon as possible. Then you want to be remove Grill blovking if you are hitting 200degF. You will find that even in Florida this time of year you can benifit from Grill Blocking. Then in the summer you may want to change your process to keep the batteries cooler.
    I suggest that you contact Bill in Palm Beach.
    Thanks,
    Dan Lander
  7. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Start with $1 and block half the lower grill until summer.
    Of course, you may have to travel north a few states to find a home center that knows what pipe insulation is. :)
  8. cproaudio
    2,401
    762
    CA
    Plug In Supply kit doesn't make a kit for Gen III Prius. I have not heard of them even planning one for the Gen III. Plug In Supply's 10KW kit costs $8,995 for self install and $11,995 & up for professionally installed for Gen II Prius.
    The new RFE batteries are enclosed so you can't simply buy 2KW battery and add on to a 2KW kit. You'll probably gonna have to buy a whole new set of 4KW battery. It's more cost effective to buy a 4KW kit to begin with. The 4KW kit has 2 batteries exactly like this 48V 80Ah Lithium Battery for EV - Detailed info for 48V 80Ah Lithium Battery for EV,lithium battery for EV,48V 80Ah Lithium Battery for EV,RFE-16F80 on Alibaba.com Each pack is 24V. They are wired in series to yield 48V pack.
    Don't convert to PHEV thinking that you'll make your money back in a few years. Most of the time, PHEV will never make its money back because it cost too much, cars being totaled/stolen or damaged beyond repair, PHEV failed after warranty expired or no warranty at all. You're left with spending more money on replacement parts which add more money on the cost of the kit. I got my kit for less than $2300 plus about another $400 on installation parts and tools. I did my own install. I average 100mpg where others average 80mpg. Even I don't have any hope of making my money back. I converted my Prius to PHEV because I want bragging rights of owning a plug in hybrid.
  9. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    If your fuel is expensive ($7.97 a gallon right now here) then you could make your money back on a PHEV within a couple of years. I am hoping to have mine pay for itself within the 2 year warranty, and anything after that is all bonus. in reality, it could be sooner, since fuel will likely hit $9.28 a gallon in the summer.
  10. richard schumacher
    7,664
    1,047
    United States
    Why do you want to do it? If you want a hobby project then gopher it. But it would be both less expensive for you, and use less petroleum, to sell the Prius and buy a Nissan Leaf.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Agreed. Assuming he can get one in a reasonable time frame.
  12. BrettS
    290
    137
    Orlando
    Thanks... definitely would be going with the 4K kit then, if I do it.
    Unfortunately (or, I suppose fortunately) my gas is nowhere near that. We're at a little over $3 a gallon now and I imagine it's only going up from here, but I certainly hope it will be some time before we hit $8.
    For me it would definitely be a good hobby project and it would be fun to have a plug in hybrid too, but it's still a bit of money to be spending and like I said above, hard to justify to the wife too. But that's one of the reasons I posted here too... despite spending some time reading I really didn't have a good idea of what was available or what to expect... You guys have definitely helped answer my questions and I appriciate your time.
    I suppose that's an option and I did briefly consider the leaf, but there really is no infrastructure to support it here in FL, so it would be relegated to commuting only. My wife and I frequently take trips that would be farther than we could go with a leaf... in that respect the prius (or maybe the volt if I could have gotten my hands on one) is a much better choice.
  13. SFGiant-and-Plugin-Fan
    47
    Durham, NC
    I bought a used 2005 Prius for less than $7.5K and am spending less than $2.5K to get and install a 4kwh Enginer system. I don't think I could have gotten a Leaf for $10K. ;)
  14. pbui
    pbui Member
    190
    Los Gatos, northern CA
    yep, used Prius + Enginer combo is a great deal, and if you have solar electron to charge
    there is a taxi 2004 Prius in Vancouver with over 600kmiles, with a replaced stock battery at 434Kmile, it is still in service
  15. richard schumacher
    7,664
    1,047
    United States
    Have fun! Let us know how it goes.
    There is at least one recent thread describing a lot of not-fun that someone had, possibility related to a PHEV conversion.
  16. Floyd2
    Floyd2 progressio per sententia
    106
    Netherlands, Europe
    In this part of Europe even already $8.48 per US gallon right now. A kWh of electricity costs around $0.30 and with my daily commute I could have a return of investment in about 3 to 4 years.
    Since gas/petrol is subsidised in the US but taxed in Europe we, Flan and me, will have it pay for itself much sooner over here.
    @BettS: My experience is that using blended mode at innercity speeds with a 4 kWh kit will support you for a distance of 66km/41 miles. So if you have the means a 6 kWh kit would be best.
