Near Center Speedometer....Again?
Discussion in 'Prius v Main Forum' started by Rest, Jan 11, 2011.
  1. qbee42
    3,079
    I don't know why the fuss. As best I can tell from driving on public roads, most drivers don't use the speedometer anyway. Toyota could save money and replace the speedometer with a sticker that just says "FASTER" in big, bright letters.
    :D
  2. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    Gen 2 has controls going across the center of the dash, but the speedo is directly in front of the driver.
  3. Rest
    Rest Active Member
    1,210
    CA
    No it's not! The speedometer is closer to the center, than the driver. And while not located in the center of the dash, it's still in an off position to the driver.
  4. eheath
    eheath Member
    207
    New York
    It's like anything else. After a few days, you don't notice that it is different.
  5. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    Perhaps it depends on the Gen II. The 04-05's speedo is closer to the driver than the center of the dash for sure.
  6. Tideland Prius
    16,549
    In the Gen 2, it's almost in front of the driver. The Gen 3 splits the differences between the Gen 1 and Gen 2 and is closer to the centre.
  7. danvee
    danvee Blizzard Brigadier
    326
    53
    New Jersey
    It took me a couple of days to adjust to the more "centralized" speedo. Now, driving another car with conventional positioning seems a bit strange.
    I'd really like the HUD from the Euro version....:D
  8. Rest
    Rest Active Member
    1,210
    CA
    It's not almost in front of the driver and is still off center. I've driven my 2007 Prius for over 4 years and it still annoys me.
    I don't get the reason behind this type of placement, nor have I ever read anything from Toyota explaining it. If it were dead center then I could understand, because this makes manufacturing to other countries easier. But cocked to one side and not being placed directly in front of the driver makes no sense.
  9. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    I'm Driving A 2010 Toyota Yaris for the winter,
    Same thing takes a little getting use to but I think I like it!
  10. Stormtrooper1
    Stormtrooper1 New Member
    MN
    OMG. Why is the HUD not available Here?
    I had one in a 99 Pontiac I used to own. you never had to look at the dash!
  11. qbee42
    3,079
    On the Gen II the speedometer is slightly to the center of the driver. It uses a double mirror system to make the display appear farther away, acting somewhat like a HUD display.
    The slightly to center location is lined up perfectly with the driver's normal line of sight, assuming the driver is looking at mid distance into the center of his lane. This is the reason that the speedometer location is slightly offset.
  12. Stormtrooper1
    MN
    I find the Dark "Space" in front of me a bit odd for the first few moments of driving the 08 prius at night, when i'm used to driving our other standard dashed car.
  13. Rest
    Rest Active Member
    1,210
    CA
    You must be joking?!
    I don't know how you drive, but when I drive I look directly in front of me down the road, in my lane. Not off to the right in the other lane. The center of my lane does not curve to the right in my vision.
  14. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Must be a Prius thing. All the other hybrids, HS 250h, CT 200h, and Camry Hybrid has the analog speedo directly in front of the driver. And the HS 250h is the only one with a HUD option. Which is weird, because I remember a rumor a while back when the Gen II first came out that a HUD option was in the works for the Prius. And that was supposedly the purpose for the center mounted digital speedo.
  15. qbee42
    3,079
    That is what I said: the center of the driver's lane. Looking ahead at the center of the driver's lane puts the speedometer directly in the line of the driver's sight.
    If you look straight ahead, you are not looking into the center of your lane, assuming your car is centered within the lane.
  16. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I hate this trend but then I hated also the one away frmo manual transmissions. But I understood it as I do with this and maybe it's inevitable for lower end vehicles like the Prius (as opposed to luxury ones, I mean).
  17. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    There was a HUD available for the Gen II Prius, just never on US models. :( I think JDM 2nd gen Priuses could get it.
  18. Stormtrooper1
    MN
    Wants so bad...
  19. Tideland Prius
    16,549
    I don't remember seeing a HUD on any JDM Gen 2 Prius.
  20. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    I'm happy that the display is where it is. I have always had a problem seeing a speedometer through the steering wheel.
