new evidence that ECO mode works
Discussion in 'Gen 3 Prius Main Forum' started by mainerinexile, Feb 23, 2011.
  1. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    That sounds like it could be correct but I don't know where the information is. I did a quick check of the owner's manual and didn't see it. I don't recall that it slows going uphill but I'll try to remember to keep a closer watch on it and see.
    I think you are definitely right about getting better mileage if you let it slow when going up hill. I usually don't do that on highways where there is traffic behind me though.
  2. jdimetal
    jdimetal New Member
    52
    Fredericksburg, VA
    So far I have been using ECO on the highway only and when I am able to lock in CC. I will try to work it in a lot more often and see what happens.
  3. Tideland Prius
    16,582
    Works wonders down to about -10°C/14°F... after that, you'll need extra help than the ECO mode and exhaust heat recirculation system.
