  1. eak354
    eak354 Member
    447
    HI
    has anyone noticed their steering wheel off-center? to drive straight i noticed that my steering wheel is turned several degrees to the right, and when i center it, the car drifts to the left. :| i'm wondering if i should bring it in to toyota for an alignment, or maybe wait till the 5000mile checkup. it only has 670miles so far. tire pressures are fine. other than that, the car is great.
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    You get 1 free alignment within the first 12,000 miles or 1 year. I'm not sure I'd "waste" it on a not-on-center steering wheel when instead, you can use it at 10k miles :)
    Unless the car is pulling or darting on freeways, or there's an excessive amount of tire noise or wear (alignment related), or unless a slightly off center steering wheel really irritates you, I'd let it go.
    My wheel is off as well, slightly to the left.
  3. jasond
    jasond New Member
    165
    Boston
    You do? Is that documented somewhere? What exactly do you get, just alignment, or rotation, or..?
  4. HTMLSpinnr
    5,339
    917
    251
    Stated in the warranty booklet. Ask any service advisor at a Toyota service center as well.
    There needs to be cause to get one though - not just "give me an alignment, because.".
    Just the alignment is covered though - I don't think rotations are included.
  5. Dion
    Dion New Member
    128
    Jersey City, NJ
    My steering is off center too. Mine in at the shop today for that reason. It bothers me bigtime. It's a brand new car. The steering should be centered like my previous new car was. If I were you, I would demand they center the steering.
  6. eak354
    eak354 Member
    447
    HI
    Whew! i thought i was the only one with this problem. thanks for the all the feedback! it doesnt really bother me a lot when driving. what bothers me is the fact that it's brand new. i'll just inquire about the alignment and probably hold-off on it.
  7. m1j1tc0rn
    m1j1tc0rn New Member
    92
    i have it too.
    it is slightly to the right but there are a couple things to consider.
    1. does it pull? mine doesn't.
    2. are the roads you are driving perfectly flat? mine aren't and at times i also think my wheel looks normal. it's barely noticable to me.
    something else to think about is the dash itself isn't at a right angle, you'll notice the slope up to the right. this gives a slight visual illusion of misalignment.
    my wife's car had the same thing when it was new.
    anyway, i have it but am not taking it in until i notice a pull or something else.
    -r
  8. Ken Cooper
    Ken Cooper New Member
    339
    Postings I've read on various Prius forums suggest that sometimes these new Prii have wheel alignment problems and that a mis-aligned steering wheel provides a hint to the existance of that problem.
    If you wait too long after buying your new Prius before bringing it in for this problem, chances are the shop might place the responsibility for the problem on your shoulders (caused by your hitting a curb, or bouncing through a chuck-hole, etc.). I'd take it in NOW.
    Be sure though that the steering wheel alignment is checked on a straight and FLAT driving surface (most roads are canted on either side of the center line).
    If you check this Prius New Car Checklist site, note that the steering wheel alignment is prominent on that list:
    http://www.vfaq.net/
  9. alexandreb
    alexandreb New Member
    Mine is brand new and is slightly to the right too (but it doen't pull neither).
    It looks like a very common "feature" isn't it?
    Anyone had a perfect fix after an alignment or we should live with it?
  10. paulisme
    paulisme New Member
    179
    Charleston, SC
    I've leaned to the left for quite a while. I'm used to it by now :wink:
  11. amped
    amped Senior Member
    3,892
    694
    Columbia River Gorge, Oregon
    Your first wheel four-wheel alignment and balance are free during the first 12 months or 20,000 miles, whichever occurs first. (Prius Owner's Warranty Information, p. 9).
    From experience, an acceptable explanation to ensure alignment coverage is something along the lines of "wanders at high speed, constant throttle, level surface, no wind, tires properly inflated". I get it done soon after delivery whether the wheel is crooked or not. Why wear tires needlessly or have to deal with nervous steering?
    Most alignment problems are traceable to the car being lashed down to the deck of a rolling ship for 1-3 weeks before delivery, I've heard. Better to have it tended to sooner than later.
