Serious rear damage!
Discussion in 'Gen 2 Prius Main Forum' started by Morgueman, Feb 24, 2011.
  1. bisco
    51,529
    Aarp
  2. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    7k to 9k dollars is laughable.
    You can get a new battery from Toyota for 2k-3k dollars now.
  3. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    It doesn't look like the battery is damaged though. I've been around wrecked Prius' enough to know that your battery is unharmed.
  4. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    You may want to have your own insurance company involved in the negotiations, if they will help you. They can make the other company play fair in putting a value on your car, and should have your best interests as their customer at the top of the list. Once your insurance company pays out on your behalf, say for a rental car, they have what is called "subrogation of benefits" and can go after the other insurance company. They carry a much bigger stick than you can negotiating on your own.
    Good luck.
  5. Azipod
    Azipod Member
    139
    NorCal
    That's an obvious total! Time to get the 3rd gen Prius. Consider yourself lucky! :)
  6. Kutanks
    Kutanks Member
    118
    MA
    definately totaled, if it was repaired that car would drive like shift afterwards
  7. Morgueman
    Morgueman Junior Member
    22
    Southern CA
    OP here...Totaled!
  8. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    SO...did you buy it back for less??
  9. Morgueman
    22
    Southern CA
    What do you mean?
