cheap shorty antenna that works
Discussion in 'Gen 2 Prius Accessories & Modifications' started by gigabyte, Feb 26, 2011.
  1. gigabyte
    gigabyte Junior Member
    26
    oakland
    thought id share. found a short antenna that still has great fm / am reception. i got it from the dodge dealership and it was only 4 dollars. its about half the size of the stock antenna. part no. is 5064253AB
    4 people like this.
  2. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Same screw thread and everything? Good find. Thanks!
  3. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Very subtle. I like it. :)
  4. roverguy78
    roverguy78 Elite Lurking Member
    118
    24
    San Antonio, Texas
    Good info! You can also use a 3rd gen Prius antenna, which is considerably shorter, and not expensive (but not $4!).
  5. edgrzy
    edgrzy Junior Member
    Wallingford, Pa.
    I never had a problem with FM , only AM . Toyota replaced 3 radio's under warranty for me. The AM would come in clear for 3-4 months and then I would get static. They stated there was nothing they could do about it.
  6. par_struggle
    par_struggle Member
    44
    36
    nv.us
    2020 Prius
    LE AWD-e
    I'll step in and second this. The Chysler part really does fit, and gives me slightly improved reception over the stock 2009 whippy antenna. It also looks about a billion times better. Really hard to beat the look at the $4 price point. My local Chrysler dealer took two days to get the part, but there was no shipping charge. As it's a block off the highway on my way home, it was an easy pick. Changed it in about ten seconds right in their lot. I'm going to take it back off and put a small dab of adhesive caulk around the bottom edge, but otherwise I'm digging it as is. Less than half the length of the original mast.
    2 people like this.
  7. JeanneFlorida
    JeanneFlorida New Member
    Thank you. It works great
  8. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Yes the post is a few months old... but I'm gonna keep it alive.
    I just ordered my Chrysler $4 antenna, and should be delivered tomorrow. I can't wait to get rid of the long whip OEM factory antenna, I've been looking for a shorty antenna that didn't loose radio reception for over 6 months now... I'm so glad that I ran across this post!
    If there is anyone out there looking for a inexpensive good looking short antenna, this is probably one of your better choices.
  9. caymandiver75
    caymandiver75 Member
    192
    100
    Northern VA
    2019 Prius Prime
    Nice! Do you by chance have a part number for the Chrysler shorty antenna?
  10. Daves09prius
    680
    161
    Gettysburg, PA
  11. Agape
    Agape Member
    378
    Ireland/Eire
    here is the short antenna made of aluminum which I got from ebay for less than Euro6 :
    Product: Aluminum
    Color: Black
    Dimensions: High 55mm (5,5cm)
    Width (at the bottom): 14mm (1.4cm) narrowed to 7mm (0,7cm) at the top.
    link to the auction on ebay:
    http://www.ebay.co.uk/itm/200602197523?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    Item number: 200602197523MINI CAR AERIAL ANTENNA BLACK ALUMINIUM 55mm STUBBY
    note: I had to cut the thread about 3mm-4mm off the length ( I should cut 1mm more really to eliminate gap, see picture)
  12. MarvinHC
    MarvinHC Junior Member
    49
    Europe
    I like that one! How is the radio reception after you have fitted it?
  13. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    Well, I made the jump today. I think it makes my 2005 Prius look nicer.
    The old unicorn antenna worked fine but the rubber at the bottom was cracking and was pitted. I might take a picture and add it here some time.
    Oh, and yep it was $4 plus tax. Got out of there for $4.37
  14. Agape
    Agape Member
    378
    Ireland/Eire
    Hi MarvinHC, I didn't do any proper tests, just ordinary usage, work's fine for me.
    I don't know if this is a real antenna or just written advert on the box (antenna). It looks like it's just a machined piece of aluminum with thread in it, unless there is sort of built in antenna (would question that for this cost). Looks great, isn't it?.
  15. MarvinHC
    49
    Europe
    Cheers, I will give it a try, not much lost anyway for a couple of quid.
    And I agree, it looks good.
    Will let you know how it works over here on the continent.
  16. Scotty Danger
    Scotty Danger Junior Member
    86
    Scottsdale
    Great suggestion; I'm going to buy one this weekend. I was looking at a shark fin, but $4 is much better than $100!
  17. malibucarl
    malibucarl Member
    237
    Malibu, Ca
    Just to update. I purchased one and it's great--only 4 bucks.
  18. Stormz
    Stormz Member
    105
    Perth, Australia
    So what diameter (in mm) is the Prius thread?
  19. dhanson865
    851
    188
    TN, USA
    The antenna is the male and the car has the female.
    The male is about 5 marks on my tape measure (10ft tape). I'm not good at measuring mm so maybe it's 5mm or 4.75 mm? 3/16" is about 4.75mm so maybe that is it?
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Thx for the info. I'm gonna have to get 1 now.
