pancakes??????
Discussion in 'Fred's House of Pancakes' started by thecrazyone, Feb 26, 2011.
  1. thecrazyone
    thecrazyone New Member
    in my prius
    where are these pancakes i read about im hungry :confused:
  2. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    It's just food for thought.
    And not usually very filling. :rolleyes:
  3. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    We shut down pancake production years ago.
    Yada yada food inspector yada yada civil court yada yada no more pancakes.
  4. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Not pancakes anymore... now, it's Vegan low-fat buckwheat waffles! :p
    Hmm, sounds like Sunday mornings at our house.
  5. caffeinekid
    caffeinekid Duct Tape Extraordinaire
    334
    44
    Houston
    Mmmmm....pancake pasties and whipped cream. :nod:
  6. Mendel Leisk
    40,828
    Here's mine:
    Crack two eggs into bowl, dump on a good bit of Roger's 9-Grain Cereal (suitable for cooking/eating), and wisk a bit, just using a spoon.
    Add a bit shy of one cup of Aunt Jemima's Buttermilk Pancake mix. (I know, not scratch, but it works for me)
    Chop half a Granny Smith apple into fine slivers, sprinkle over top, with the object being to get them separated and coated into the flour.
    Add just shy of a cup of milk, your choice. Stir until just blended, don't puree ;)
    Meanwhile, prep. a couple of things:
    1. In a gravy boat or similar, put a good shot of corn syrup, dash of vanilla extract, shot of molasses (blackstrap or what have you), and a shot or two of water. Stir up a bit, to semi-mix, then microwave for 30 seconds on high. Alternately warm it up on stovetop in small sauce pan.
    2. Put a few tablespoons worth of frozen blueberries in a bowl and run through the microwave on a defrost cycle. Again, small saucepan on stove works.
    Back to the pancakes:
    Bring a griddle to 350~375 degrees fahrenheit (a little trial and error is needed, depends on your griddle's theromostat).
    Put the batter onto the griddle, in a "six pack" of 1/4 cup dollops. If there's any left over, distribute uniformally to each.
    Flip them just as soon as possible, when there's a hint of bubbles.
    Let them go maybe 2~3 minutes on the second side, give them a good chance to rise.
    Serve spread lightly with marg/butter, topped with a dollop of yogurt, then blueberries, and finally a drizzle of the syrup.
  7. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Did you mean to say pastries, or was that slip intentional? :p
  8. TonyPSchaefer
    14,816
    2,499
    66
    I prefer my pasties on something a little rounder than pancakes.
  9. caffeinekid
    334
    44
    Houston
    Oh, I definitely meant pasties.
    ....with some rasberries. :D
    The wifey keeps dropping hints of how nice it would be if I took the time to cook a meal once in a while, so I made her breakfast on Valentines Day. ;)
  10. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Pancakes *are* round. You mean something not quite so flat. ;)
    Do you prefer whipped cream, or maple syrup?
  11. richard schumacher
    7,664
    1,044
    United States
    Mmm, pamcakes
  12. A Prime Factor
    A Prime Factor Formerly "I want my PHEV"
    340
    171
    Madison, WI
    Welcome to PriusChat. Unusual first post, but that's okay.
    I like potato pancakes.
  13. A Prime Factor
    340
    171
    Madison, WI
    Either that or else Tony's pancake-making skills are not up to par.
  14. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    In case anyone would like to try my waffles, here is the original recipe:
    1 large banana
    1.5 cups whole wheat flour
    1/2 cup oats
    2 tsp baking powder
    2 tsp cinnamon
    1/2 tsp nutmeg
    2 cups water
    Blend in blender until almost smooth. Bake in waffle iron. You will need to oil the waffle iron, as the batter has almost no fat at all. Note: the riper the banana, the darker the waffles will be, and the more likely that they will stick to the waffle iron, hence will need more oiling.
    Gluten free, no-fat, vegan Buckwheat waffles:
    Same as above, but instead of WW flour, I blend 1.5 cups of raw buckwheat groats in the water, using the blender, until smooth. Then, I add the rest of the ingredients. Amazing!
    Note: I've tried using buckwheat flour (pre ground) and it turns out crappy.
  15. A Prime Factor
    340
    171
    Madison, WI
    They sound good, and I'd eat them if you served them to me, but I'd be reluctant to make them due to the may-stick-to-the-waffle-iron property.
  16. qbee42
    3,079
    Okay, I tried them, but the banana peel got all stringy in the blender.
    If you are really worried, add a tablespoon of oil to the batter. Make sure you also oil the iron.
  17. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
    Bra...
    They have spray cans nowadays...
    It WORKS...
    :rockon:
  18. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I made pancakes for supper tonight, because that's what the kids wanted. Oatmeal, with lots of added fruit - blueberries, a banana, and a mango. Kinda tasty, though the extra sugar made them more prone to burning, so I had to be extra careful. I sure love a big ol' cast iron frying pan.
  19. qbee42
    3,079
    Don't use normal Pam type of non-stick spray on a waffle iron or grill. At higher temperatures this stuff will turn into glue, completely destroying the non-stick characteristics. I managed to wreck a couple of appliances learning this the hard way.
    If you want to use a commercial non-stick spray for high temperature applications, Pam makes a special variety for grills.
  20. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    The non-stick stuff (Teflon?) doesn't seem to last very long. After a couple of years, bits of it start ending up in the food, and that can't be good. A few years ago I made my own. ;) I bought a big unseasoned cast iron frying pan, took the sander to it, and then seasoned it with oil in a hot oven. I've never seen a smoother one. :)
