uncomfortable drivers seat - ways to fix?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by aelskus, Feb 26, 2011.
  1. aelskus
    aelskus New Member
    Maine
    The drivers seat in 2010 and 2011 Prius III is uncomfortable for me. Specifically, I need my butt to be level with my knees. I tried a wedge - wasn't quite enough.
    Have others had this problem?
  2. Mendel Leisk
    41,780
    Another relevant specific: how tall are you? ;)
  3. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Lack of lumbar support is a problem that we have solved with a small pillow in our II. No pillow is needed in the driver-side seat of the V.
  4. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    Have you pumped the seat all the way up?
  5. socalev
    socalev New Member
    31
    mission viejo
    i have heard of owners putting washers under the seat trackes to adjust the rake of the drivers seat in the prius
  6. bisco
    52,224
    phone book?
  7. Nuckz23
    Nuckz23 Member
    127
    Santa Clara, California
    You might want to try this product: Extendmyseat
    I have been experiencing discomfort especially during long drives. I am over 6 ft and I believe the problem is that my legs are not supported by the seat. This product will give you more leg room and hopefully result in more leg support.
  8. unkprius
    unkprius Member
    152
    That would work for me except I would also need to purchase the Extendmyarms product so that I could reach the steering wheel that doesn't have enough telescoping grrrrr.
  9. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    The lumbar support works great in mine.
  10. roypaik
    roypaik Member
    161
    39
    Orange County
    2020 Prius Prime
  11. Zedknepplin
    Zedknepplin semper prius
    124
    65
    162
    Georgia
    My wife had a similar problem with her Honda Fit. We tried the foam wedge, etc. What worked for her was some color matching towels folded up nicely. She sits higher too and it works great. :)
  12. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I picked a couple of these up at Walgreens almost a year ago. I installed them under my Clazzio seat covers and have been very happy. If you do a search for lumbar you'll see me thread about this.
  13. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    another question, does anyone know if the gen 3 front seats will fit into a gen 2?
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Common question, but answer is no.
    3rd Gen seat rail width is a good inch or so wider than 2nd Gen, mount feet will not match 2nd gen floor pattern. Electrical wouldn't plug in anyway.
    I'm pretty sure each and every model of car has a distinct seat because mfrs. really don't want someone to switch seats. Reason - liability. Let's say a 3rd gen seat fit into a 2nd gen, and you are later killed in an accident because seat came loose .... Toyota is then toast.
  15. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I would say if you need your butt to be level with knees, then you are likely a shorter individual and therefore, you have room to raise the seat up. When you raise the seat, the tilt should come out of the seat bottom, then your butt will be as high as your knees.
    Typically for taller people will lower down, then seat bottom tilted back to support thighs. Try all the adjustments and use some accessories.
    It's a pretty good chair in the 3rd gen. For me, it's actually a wee bit more comfortable than my Accord Coupe seat.
    That said, power seats are usually the best for comfort.
