Going down a hill
Discussion in 'Gen 2 Prius Fuel Economy' started by FirstFlight, Feb 26, 2011.
  1. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    When you are going down a hill, is it better to (for MPG purposes):
    a. Do not press the gas or brake and just coast
    b. Gently press the brake (I am only assuming that just tapping the brake will do regen only)
    c. Press the gas lightly so no arrows are going either way
    Also, I've been reading that the scan gauge helps increase MPG. Why?
  2. richard schumacher
    7,664
    1,044
    United States
    c. is best for MPGs. Of course, never let your speed get out of control.
  3. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    The scan gauge merely gives you better information, it would be up to you to make that into better mileage.
  4. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    For instance instead of going for no arrows on the energy screen, I have my scangauge show me the current out of the traction battery and I just set the gas pedal to minimize the current (not positive or negative by more than an amp or two) when gliding.
  5. BrettS
    BrettS Active Member
    290
    136
    Orlando
    C is best for the best fuel economy because regenerative braking is lossy... you'll still lose some energy in the process. So, if you can avoid doing any regenerating at all and use the momentium you gain going down the hill to keep going forward without using any power then you'll get the best mileage.
    However, it may not be the best option in every situation. If it's a very steep hill then using a and b (as needed) to keep within the speed limit is best. If you know you'll need to stop at the bottom of the hill because of a toll or a traffic light or whatever, then using b to gradually slow down well ahead of the stop would be better than doing C down the hill and braking hard at the bottom.
  6. dogfriend
    7,512
    1,189
    Carmichael, CA
    Momentum. Momentum. Momentum.
    Get it, keep it, and watch out for momentum thieves. :madgrin:
  7. uart
    uart Senior Member
    4,220
    1,209
    Australia
    It really depends on how steep is the hill.. Some have mentioned the importance of keeping momentum and of the inherent losses in regeneration but there is a flip side to that coin. The higher your speed the more energy is wasted in wind resistance and this can be very significant at higher speeds.
    For that reason I think another strategy could be better. I think that near the top of the hill it's best to make use regenerative braking to keep the speed low and some time towards the bottom if the hill move to the glide state (no arrows) just in time to allow your speed to rise to the target level for traveling on the road in question. Obviously I'm assuming you're the only car on the road here, what's optimal for energy conservation and what we can get manage without annoying other drivers are two different things. :)
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Wow talking about dedication! How much harder is it to maintain zero current than to maintain the traditional "no arrow glide"?
  9. BAllanJ
    667
    78
    Kingston Ontario
    Well it's more that I like keeping the bar graph display and don't want to flip back and forth from screen to screen. Also, I've mounted my SG right above the steering wheel at 2 o'clock so it's closer to my field of view. Having the battery current displayed also allows me to brake without having to switch to friction braking. Also, the arrows don't show you how far from balance you are but the numbers do.
    I display rpm, ign (those two help find the shm and i pulse at 2000 rpm or so too ) engine coolant temp, and battery current.
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I wish there was a Glide option to go along with the Eco,Normal,Power modes. A button you held down on the steering wheel for Glide would also do the job.
  11. BAllanJ
    667
    78
    Kingston Ontario
    I would love that.
  12. uart
    uart Senior Member
    4,220
    1,209
    Australia
    They have, it's called "N" :D
  13. 05hybrid
    05hybrid New Member
    29
    Corpus Christi
    i always do that, i even try it on the freeway :)
