Prius Smart Key Battery Replacement
Discussion in 'Gen 3 Prius Main Forum' started by Nda3rdCar, Mar 2, 2011.
  1. Nda3rdCar
    Nda3rdCar Junior Member
    92
    The battery replacement video link has been removed from the Gen3 thread. Sorry for the inconvenience. It will be posted on Gen2 Maintenance thread.
  2. qbee42
    3,081
    This is posted in the wrong forum. The 2006 Prius is a Gen II, and this is a Gen III forum. The Gen III uses a different fob and battery, so this video does not apply.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    FYI--the Gen III fob is a different design. To replace the battery, you remove the metal key, and use it to pry open the case by inserting the tip into a slot at the top of the fob adjacent to where the key is stored.
  4. Nda3rdCar
    92
    Dang, my mistake. I'll delete it from Gen3 and move it to Gen 2.. Thanks.
  5. Nda3rdCar
    92
  6. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Different batteries too.
