Engine Under Panel removal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Feb 19, 2011.
  1. Mendel Leisk
    41,640
    Once before I lifted the front end and took out the fasteners of the maintenance door, but today I thought I'd try removing the whole panel. Comparing to just removing the fasteners at the door, It took maybe an additional 10 minutes, say 5 minutes vs 15 minutes.
    There's a row of 4 10mm (socket size) galvanized bolts at the front, which capture both the leading edge of the engine underpanel and the trailing edge of the plastic "spoiler" ahead of it. Then a couple more 10mm bolts back a bit, interspaced with 2 push-in fasteners.
    There's about 4 push-in fasteners down each side, and about 3 at the back. 2 of the back ones have grey heads, and are the only disimilar push-in fasteners. Per someone's suggestion, I daubed their heads, and directly adjacent, with a dab of quick-dry white out.
    When putting it back in, on each side near the wheel well there's pairs of fasteners, quite close together. One of the pair only goes through 2 layers of plastic, the other goes through a backing metal plate as well. Once both are pushed in it feels much more solid. With only the plastic/plastic fastener in it feels like something is wrong, too loose, but once the second fastener goes in it all tightens up, more stable.
    Anyway, here's a few pics. I was also looking at transmission and engine oil drain/filter access. And I applied some hockey (friction) tape to both sides of the maintenance door, and a second seam I noticed, that runs the full width, further forward.
    All the fasteners:
    A full view of the panel, oriented as it would be on the car:
    In the above picture, the second hinge point I mentioned is apparent: it runs through the "equator" of the large circular opening at centre front of the cover (the hole exposes the front jacking point). This looks to be a second bend point that could be used, if you undid all the rear fasteners but left the cover connected at the front end. Likely just as fragile, though.
    Also, not that practical for a DIY'r using floor jack and safety stands: even if you can raise the car enough to swing down at that second hinge point, it blocks access if you're crawling under from the front of the vehicle.
    Close up of the maintenance door:
    Better view of the maintenance door hinge, on a bench (the underside):
    And the inside (top side) of the same hinge area, with friction tape applied (cleaned the area first):
    Another view of the underside of hinge, this time with tape applied:
    The view to the right, when you crawl under, showing oil filter and drain bolt (14mm socket):
    A close up of the same area, with (Honda) oil filter socket in place:
    And view to the left, the transmission housing, with right side drive shaft going in. Just to left of drive shaft is the fill bolt, and down and slightly right is the drain bolt:
    Close up of the tran. fill bolt with 10mm hex socket on it. A 6" extension on torque wrench is needed. Not quite so much for the drain bolt, but it doesn't hurt:
    Torque wrench on the tran. drain bolt:
    amarino, wigwag, Den49 and 6 others like this.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Good pictures, I'll use this thread next summer when I pull the panel. Thanks
  3. Pooka
    Pooka TIFOSO
    86
    KANSAS CITY
    2014 Prius Plug-in
    where are the jack stand points on 2010 prius?
  4. Mendel Leisk
    41,640
    There might be some strong points on the sub-frame you can also use, but so far I've just used the usual: the points just fore and aft of rear and front wheel wells, on the rocker panel seams. They're shown in the Owners Manual: basically the same points where you would put the scissors jack, the one included for changing a flat.
    If you look on that bottom of rocker panel seam there's a pair of notches: put the jack stand in between them. The usual disclaimers apply: apply parking brake and use wheel chocks on the rear wheels, give the raised vehicle a nudge or two to ensure it's stable.
    Also a good idea when getting under: take something with you that's thicker than you, and sturdy, say a tool box.
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    A piece of mine just broke. The mechanic at the dealer said basically it's a flimsy piece of s---- and don't worry about it. He pointed to a Carolla sitting close by and said that it had the same basic engine and it doesn't have a splash shield. We then threw the broken piece in the garbage, so I guess I won't worry about it.
  6. Jseidl
    Jseidl New Member
    ALbion, Michigan
    Had the same problem when my access panel came off a two weeks after the dealer serviced the car at 15,000 miles. The dealer service tech told me that it wasn't covered under warranty. I saw your post and contacted the dealer again noting that it was the service panel that came off and only the dealer accessed it. If the dealer didn't access it, they worked on the car two week before and should have seen the loose panel. After I contracted the dealer a second time with the Prius chat information, that there is a service bulletin and new part to replace the panel. Having the new panel installed for free under warranty. So complaining to the dealer and quoting Prius Chat works.
  7. theloop82
    theloop82 Member
    Spanaway, Wa
    It is for aerodynamics and improved fuel economy. It reduces turbulence under the car at speed. Probably not alot, maybe 1mpg difference. The Carolla also doesn't have 2 electric motors and 200vDC wires exposed, but really that stuff is made to withstand use without the under panel. I believe the Prius I (fleet only) doesn't have the under car paneling.
    That being said my oil change door broke off after my 5th oil change and i took it in. The dealer gave me the run around even with the TSB in my hand. So i found the president of the dealership's email adress and went straight to the top. I got it fixed the next day.
    It felt great to walk back in there and tell the same smug service advisor who turned me away later to give my a loaner while he was fixing my car.
  8. tumbleweed
    4,067
    692
    Eastern Oregon
    :thumb: Great, sometimes going to the top works.
  9. Mendel Leisk
    41,640
    Last weekend I replaced both the engine oil and filter, and the transaxle fluid. It was at 11 mo and 15022 km, which was 8000 km more than the last oil change service, so km's governed (it's still 8000 km per, in Canada). I know this is way ahead of Toyota's recommendation for transaxle fluid change (never?, nearly never??), but it cost me about $40, so...
    Anticipating the transaxle drain might be messy, I took the engine bay undercover off completely. If you can manage it, this is really the way to go. It takes at most an extra 10 minutes, makes access much easier, and saves wear-and-tear on the infamous maintenance flap. It also affords you a much better view of CV joints and steering linkages, frame members and bolts, which are mentioned in the schedule (at least the Canadian one) as items to check.
    There are about 10 plastic push-in fasteners (2 are different, worth marking), and 6 10mm hex head bolts. Whenever I have the plastic fasteners off I thoroughly rinse them off. I believe it's accumlating grit that leads to a lot of the breakage. I also lightly oil the bolts.
    Anyway, raised the entire car about 10~11 inches, level, onto 6 ton safety stands. Removed the fill plug on the transaxle first, then the drain plug. For the engine oil drains I've been using a bottle and big funnel setup. Here it is under a previous vehicle:
    But for transaxle I elected to use a big, galvanized sheet metail drain pan I have. Turned out to be a good idea. Maybe in part because I had the fill plug removed (next time I'll just break it loose, but leave it on for the drain) the fluid came out in a real rush, splashing a bit on a strut. Mostly it ended up in the pan.
    For refill of the transaxle I used the funnel and tube method, worked like a charm. My wife poured, I kept an eye on it, watching for the start of overflow. Ended up overshooting a bit, let it drain well, to a slow drip, then buttoned everything up and dropped the car.
    Since it was the first change, and because the repair manual stipulates: the next day, after a decent drive, I raised it up again, level, cover off, pan under, removed the fill plug only, to verify level was ok. It was basically the same, a slow drip.
    So it looks like when you do the fill it doesn't change, with a bit of running time. Anyway, this time I made a point of checking the level with a finger, and made a point of splashing a bit out, and letting it sit till it completely quit dripping. Then buttoned up once again and dropped.
    FYI, fill and drain plugs on the transaxle require a 10mm hex drive bit. And the torque is 29 ft/lb. It's recommended to change the washer (I didn't rechange on the second check). The fluid is Toyota ATF-WS, which set me back around $9 per liter. I got 4 liters, you'll need around 3.5.
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    +1 on removing the entire engine undercover rather than just the oil maintenance flap. As you say it gives you an unobstructed view of the entire engine underside for all of the inspections mentioned in the maintenance schedule. If there are any fluid leaks at all you will be able to see them. This will be my plan from now on.
    I had the same thing happen with the fluid rushing out and hitting on the strut and splashing. The next time I will leave the fill plug loose so I can slowly adjust the drain plug flow to try to get more used fluid in the pan and not on me:)
    Very good writeup.
  11. tumbleweed
    4,067
    692
    Eastern Oregon
    Do you believe in the "woosh" theory of changing oil? If you leave the fill plug or cap in and remove the drain plug it doesn't come out as fast. If you leave the fill plug out the oil wooshes out when you remove the drain plug, the woosh is suppose to carry out some of the sediment in the bottom of the pan.
    I haven't heard anyone refer to it on this forum but it is discussed from time to time on other car forums.
  12. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I have not heard this discussion and never really thought about it. I normally have left the oil filler cap on while draining the oil then removed the filler cap to refill.
    The oil pan drain does not have any obstruction close by like the transaxle drain. I have always thought the oil flow was strong enough with the filler cap on.
    What do you do?
  13. Mendel Leisk
    41,640
    It would seem like the faster the fluid whips out, the more completely it's going pull out sediment. All the Hondas we had over the years had a magnetic drain plug on the auto transmission, but not Toyota. Can't hurt I think. They would invariably have a good crop of sludgy filings.
    This was the second oil change, and this time around I put in 4 liters, and said that's it. Actually that's all I had, anyways, so...
    Anyway: I find when I check it after a change, and that's after running for a minute, to circulate into the fresh oil filter, it looks fairly low, close to mid-way between the marks. But give it a day, check it again, and it was less than 1/4" below the top mark (4 US quarts would a bit lower though, maybe still ok). And with our Prius at least: that level seems to bairly budge, between changes.
  14. Mendel Leisk
    41,640
    Just an update, I've started placing the front jackstands at the front end of the structural "rails" on the underbody. They're about a foot in from the rocker panel edges, about 1.5~2" wide. They curve down slightly at the front, slightly, which means when you've just got the front end raised they're not that far off horizontal.
    They're a much broader contact surface, and a lot more confidence inspiring. The knife edge of the rocker panel does not feel good when used with jack stands, especially if raised fairly high: they feel like they're on the verge of kicking out.
    Once I've got the front jackstands under those rail ends, if I raise the rear (which is needed for transmission fluid change), I do put the rear jackstands on the usual rear rocker panel support points. The back is lighter, and coming back to horizontal it feels more solid.
  15. miogps
    miogps Junior Member
    PA
    For some reason I cannot see any images from the opening post. Can someone help me out (repost). Thx.
  16. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The post is from 2011 and the images were lost when the PriusChat forum software was changed a while ago. The OP would have to re-upload them.
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    He probably won't do that unless you quote him so he gets an alert.
  18. tumbleweed
    4,067
    692
    Eastern Oregon
    I think with this Prius I have always taken the filler cap off before I removed the drain plug. The theory of removing the cap first made sense to me so I do it that way, I really have no basis for comparison. I'll try it your way next time and see how that works.
  19. Den49
    Den49 Member
    498
    272
    Maryland
    I remove the filler cap and pull the dipstick before removing the drain plug because although the oil comes out faster and shoots farther, it is a smoother stream that I can control better and makes less of a mess. Also, my thought is the oil will drain better with air being drawn in through the top end of the engine. The "woosh" theory also makes sense, at least for the initial few seconds of the drain.
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I change mine hot, so the woooooosh always applies, usually all over my garage floor.
