compatible OEM replacement stereo
Discussion in 'Gen 2 Prius Audio and Electronics' started by schmooot, Mar 4, 2011.
  1. schmooot
    schmooot New Member
    BC, Canada
    Looking to directly replace an OEM stereo from a 08 w/o nav. Just a stock replacement nothing fancy
    I'm wondering what numbers I need to know to find a compatible donor.
    I see a bunch on ebay that say they are compatible with:
    PRIUS 06 recvr (w/CD), w/o cass; marked 51825 on radio face
    PRIUS 07-09 recvr (w/CD), marked 51825 on radio face
    also a few same as above but with 51824 as well. I'm just not sure which one I need to get...or does it matter at all?
    Mine happens to have 51830 on the face, can I replace it with a 51824 or 51825? or do I have to have a 51830 as a replacement.
    Or do I need to match the actual model number on the top cover ie. (86120-47270)?
    Also I heard rumor that a replacement will need to be programmed by the dealer to communicate properly with the car.....any truth to this..or a workaround maybe?
    Thanks
  2. schmooot
    schmooot New Member
    BC, Canada
  3. schmooot
    schmooot New Member
    BC, Canada
    nevermind, the parts guy at Toyota says the two are compatible with eachother. The 51830 and the 51825. We will see if it needs to be programmed when it arrives
  4. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
  5. schmooot
    schmooot New Member
    BC, Canada
    I just got one on ebay for $159 shipped. You couldn't have posted that 10 minutes sooner?
  6. schmooot
    schmooot New Member
    BC, Canada
    Just for future reference. The 51825 is the JBL system with the 6-disc changer. It will not plug-and-play into a base model prius, different connectors on the back. As long as the replacement deck has the same connectors on the back as yours it will be a direct interchange
