43mpg Lexus CT200h is now on dealer lots starting at $29,999 (photos)
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Rybold, Mar 2, 2011.
  1. snowsystem
    snowsystem Junior Member
    Vermont
    why no LKA on this new Lexus or Prius V ?
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I don't know if you are referring to my post or not but? Here in Hawaii the CT200h's, Prius V, Five's, and the HS250h's are not being optioned with the LKA for what ever reason. The LKA option is available in other locales though.
  3. snowsystem
    Vermont
    odd that you don't or read anything about this LKA. I took one on a test drive and it really works. wish I knew why they are dropping it on these other cars?
  4. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    lots of people looking at the HS250h complained about high sticker price for loaded models, so they changed that around... if they put everything on it, then people would complain about it being 50k
  5. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Dude there not dropping the option I was only griping the fact that I can't get it here in Hawaii.
  6. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Just goes to show how the AT-PZEV mode is just a political and financial game, something that Sacramento came up with.
    The CT and Prius emissions systems are identical.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Source?
  8. spwolf
    3,156
    440
    Eastern Europe
    is it political because Volt doesnt have it? Starting to show true colors buddy.
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Dude, go educate yourself. Sorry, that's the most polite statement I can come up.
  10. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Another minus is that since the CT isn't AT-PZEV rated, for those in CARB states, they won't get the benefit of the 10 year/150K mile HV battery warranty nor the 15 year/150K mile emissions warranty that AT-PZEV vehicles like the Prius get.
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Right, HV battery still has the 8 years / 100k miles warranty.
  12. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    That's totally weird. My Accord Coupe is SULEV II / PZEV rated for CA. I doubt it is cleaner than a CT200h.
    hmmmmm.
    (I do get the 15/150 emissions rating which kinda cool :)
  13. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    The lower MPG is mostly attributable to the higher Cd.
    Power, and thus energy used is in direct proportion to the Cd.
    CT200h Energy Consumed = (0.29 / 0.25 ) * Prius Energy Consumed
    Gallons of gasoline burned is directly proportional to energy consumed
    CT200h Gallons Gas Consumed = (0.29 / 0.25) * Prius Gallons Gas Consumed
    Since miles per gallon is inversely proportional to gallons gas consumed
    CT200h mpg = (0.25 / 0.29) * Prius mpg
    CT200h mpg = (0.25 / 0.29) * 50 mpg = 43 mpg
  14. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Your calculations hold only if every power sink is proportional to Cd.
  15. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Thanks for reminding me. I remember now... I believe the "A" of the CT200h is smaller than the "A" of the Prius.
    I believe internal resistance & losses ought to be the same. Aerodynamic drag will vary by the way I described earlier.
    The wheels & tires could introduce some additional variability that I did not account for.
    Partly then, the other additional losses and counterbalanced by the gain by the smaller reference area.
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Don't forget to multiply frontal area to the Cd. CT200h is wider but the height is lower. Overall, the frontal dimension is a bit smaller.
  17. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    I believe the fact the CT has 17" or 18" wheels with wider non-LRR tires probably is a huge contributing factor. We have seen it multiple times on this forum where someone took a hit to their mpg by going to larger diameter wheels with wider tires, even when those tires were LRR!
    Would be interesting to equip a stock CT with 195/65-15 LRR's and see what happens to gas mileage. Granted, you'd take a major hit to the Cool Factor, but...
  18. priushippie
    priushippie New Member
    330
    Pennsyltucky
    I'll keep my Prius!
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    oooh wow, that would not look good.
    I still don't quite like the 3rd gen Prius in 17" wheels - they look a little bit too big for the car, and the tire profile looks too small to me. Geez, my Accord carries 17" wheels, but it's 191" long and wider.
    As said before, dozens of times - I think the 3rd gen Prius would look its best in 16" wheels with 55 series tires.
    I think Prius Five should have 16" wheels.
    Heck, even the Leaf gets 16" wheels.
  20. hill
    8,918
    Yep . . . even the difference in rim size between the Gen III's Packages 1 thru 4 versus the package V rims made a teeny dent in mpg's.
