rattle from driver side dash
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by scottwyden, Sep 30, 2009.
  1. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Rattletrap is overkill.......our 2010 III had one very slight noise coming from the passenger side dash......it was taken care of during my 1000K mile checkup.......since then there is no rattles. Very quite !!!!!!!!
  2. Kb2lzh
    Kb2lzh Junior Member
    Ca
    When the ICE is running there is a high pitched rattle almost like a
    loose exhaust manifold heat shield noise. It can only be heard
    outside the Prius. It does not bother me inside . Do I have a maintenance issue? This is a new 2011 with 700 miles.
  3. waldo
    waldo Junior Member
    oregon
    I have the same problem with the center of the dash, If I press on the middle of the dash just above the start button, and right above the air vents the rattle goes away, also the right hand side vent, make a rattle sound aslo, I was wondering if the hinge from the glove box was causing this.
  4. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Wow, you've already racked up one million miles?!? You must have one heckuva commute.
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Bad, Pinto Girl. Bad. :p
