Our Beloved Prius: Can it go any greener?
Discussion in 'Gen 3 Prius Main Forum' started by ujazzi, Mar 8, 2011.
  1. ujazzi
    ujazzi New Member
    Bulgaria
    I am starting a thread for some exotic, crazy, nice, :eek:,futuristic ideas of how we can get more ecology out of the Prius... Let's go Wild!
    Here is something just to accelerate creativity:
  2. TheBlueWedge
    TheBlueWedge New Member
    49
    USA - Vermont
    Leave the engine off and push it wherever you go? ;)
  3. hamil33
    hamil33 Junior Member
    Pull it everywhere with a VW TDi. (Just a joke guys!)
  4. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    Grind up the plants in the back seat, put in cellulosic digestor, make ethanol, put in gas tank.
  5. happyiswowo
    happyiswowo New Member
    Bellevue
    They can make a plant holder for the prius, like they made a flower holder for the vw bug?
  6. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    Grass top roof anyone?
  7. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I hope John From Australia doesn't mind me sharing these, but i think this is about the best you could do with a prius. The guy is a legend, and shows just what you can do if you really want to do something different and put your money where your mouth is.
  8. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    One thing Toyota could do is to lengthen out the oil change interval. No reason that I can see not to have at least a 20,000 mile interval using synthetic. There's an active thread on this right now.
    Also, I don't really know how much recycled content exists on the car, but I assume there's plenty of room for more recycled interior components.
    Finally, it just might be possible to eliminate some of the electronic wiring; i.e. radio, nav, HVAC, other electronic options, by using WI-FI. I don't know how to do it but I think we have the technology without driving up the cost. This would have to eliminate a ton of copper wire, fittings, connectors, etc. JMO
    Okay, there you have 3 quick ideas that may not hold water, BUT it's a start to making a difference for the good. :)
  9. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Think twice, and maybe three times, about trying to use WiFi for anything critical in the car. External interference can be real; never mind somebody playing Malicious Cracker.
    There are schemes where there's a single high-speed bus that goes around to the various lights and electronics, along with power and ground. The idea is that lights, windshield washers, door sensors, etc. etc. are turned off or on or signal back via the time shared bus; the only other thing needed is power and ground. This can cut a ridiculous amount of wiring of wire from the car.
    KBeck
