2009 Touring Dead at 55000
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nickfromny, Mar 10, 2011.
  1. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    All lights on dash light up and won't shift to reverse or drive only neutral. Towed to dealer and they said it threw several codes and are replacing the tranny. I will keep you posted on outcome.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    ACK!!! Thank goodness it happened before 60,000. Please do let us know what the codes were etc, as you have a very unusual early failure.
  3. nickfromny
    309
    24
    Binghamton, NY
    Will do on the codes. Think we get 5/80,000 on power train, emmission system, and Battery Pack. Do we???? I do alot of driving in the snow and this winter we have had over 120" of the white stuff.
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Wonder if driving in snow caused too much MG1 over revving despite traction control?
  5. seilerts
    3,326
    1,520
    Santa Fe, NM
    Is NY a CARB state? If so, your battery is 10/150. But the transaxle is a powertrain warranty item, i.e. 5/60, though we have at least one recent story of a person that was able to get their trans covered under the CARB warranty.
  6. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    NY is a CARB state so yes, he'd get the 10 year/150K mile HV battery warranty.
    I've never heard of a "5 /80,000 on power train..." for any region.
  7. nickfromny
    309
    24
    Binghamton, NY
    Dealer told me code was POA40. Going to pick her up now.
  8. Patrick Wong
    18,210
    6,526
    DTC P0A40 "Drive Motor 'A' Position Sensor Circuit Range/Performance"
    That confirms that the transaxle needed to be replaced.
  9. nickfromny
    309
    24
    Binghamton, NY
    New Transaxle installed. Covered by Dealer/Toyota. Its running smooth.
  10. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    All's well in Endwell!:p
  11. nickfromny
    309
    24
    Binghamton, NY
    Next up the Green Grand Prix in Watkins Glen on opening weekend at the Track
  12. Mr.Vanvandenburg
    1,362
    666
    2020 Prius Prime
    At 55k, if you're Irish, you have the luck of the.
    That was a mighty fast part procurement, install by the dealer.
    Wonder what the underlying cause was.
  13. Patrick Wong
    18,210
    6,526
    My guess is that the motor resolver sensor was bad. This shows the position of the MG2 rotor and the sensor's waveform output allows the hybrid vehicle ECU to determine MG2 RPM.
    This is a good example of how a little electronic problem can put the Prius out of service. The failure of a sensor that probably cost $2 would result in a $6K repair if the OP's car was out of warranty.
  14. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Oh Sh*%! Got to get the extended warranty.:eek:
  15. nickfromny
    309
    24
    Binghamton, NY
    All good so far.
  16. UKCLASSICPRIUS
    127
    UK LONDON
    in another thread been told its most likely the connector on the transaxal if the car was a wreck or rebuild, or even been worked on when this problem codes p0a 40 p0a41 arrise...
    I have yet to check it out for myself... cars on its way to me...
    Been told My cousin has changed the engine & gearbox complete from a working prius, & the cars still throwing the same codes as before... which makes me think it is a connector fault, which another member sorted out by a little soldering of pins in the connector housing itself..
  17. Sabby
    Sabby Active Member
    295
    127
    SoCal
    When they do a warranty repair like this what warranty do you get on the repair?? Is the powertrain warranty extended beyond 60k??
  18. seilerts
    3,326
    1,520
    Santa Fe, NM
    Replacement parts typically carry a 1 year, unlimited miles warranty. The original warranty still applies as well, if more than 1 year remains, and the mileage cutoff has not been reached.
    2 people like this.
  19. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    Nick, did you have a S2k?
