Front passenger cup holder
Discussion in 'Gen 3 Prius Main Forum' started by dbcassidy, Mar 10, 2011.
  1. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    I am currently driving a 2010 Prius and I am having a problem w/ the passenger cup holder. It doesn't want to hold either a cup or can in the upright position (contents spill) I reviewed the owners' manual, it didn't offer any solutions. Am I missing something? Is there an aftermarket accessory or solution I could look into?
    Any help, advice would be helpful.
    Thank you,
    DBCassidy
  2. BrettS
    BrettS Active Member
    290
    137
    Orlando
    Which cup holder are you referring to? The two in the center console are in line with each other, so I'm not sure which would be the passenger cup holder (although I haven't had any issues with cups spilling in either of them). The ones in the passenger and drivers doors are only for bottles and not cups or cans... if you're trying to put a cup or a can in the door then that might be part of the problem.
  3. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    Yes, please confirm with of the passenger cup holders you are referring to? There are at least 5 spaces a passenger could use as a cup holder. There are two between the front seats, one the passenger door (the one in the driver door I am not including, as that is the only one I would term 'drivers' cup holder, otherwise there would be 6 in the car), and they have two in the rear for the rear-seat passengers (or long armed from seat passengers.
    I've used all of them without issue, as have my kids, on many bumpy roads and 'sporadic' stops and go's without issue.
  4. nwprius
    nwprius Member
    227
    35
    I put in a piece of grey inch wide three eights thick self adhesive insulation foam that made the cups I use fit snugly.
  5. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    The one in the doors are great for a bottle of water but thats about it!
    If you look real close at the door panel it has a stamped bottles only
    no cups!
    the cup holders for the center console are just ok! the one with the flip door I use, and the passenger(my wife) uses the one behind it when you slide the armrest back. One on each end of the dash like the Yaris would be nice.
  6. bisco
    52,292
    two more in the middle of the massive wasted bridge space would be perfect.
  7. dbcassidy
    1,581
    290
    So Sorry for not being more detailed in my post. I meant the center console, rear (arm rest) slider area. There seems to be no cup or can restraintin place. Its' like putting a cup or can in the storage area (under the arm rest) and hoping nothing spills or tips over going thru a curve.
    Hopes this helps,
    DBCassidy
  8. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    I do not know what you are doing, but I find it holds cups and cans just fine, as long as you have the liner in place.
    :confused:
    You do have the liners in the holders, don't you?
  9. samsprius1
    720
    182
    2023 Prius
    Limited AWD-e
    If your a coffee drinker this is what I use! Also works well with your favorite cold beverage too. order two! Won't spill all over.
    Copco - Eco-First - Acadia Mug Brown
    amazons got em 5.99 go there for reviews.
  10. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    The passenger cup holder in the bottom of the passenger door is designed to hold the plastic water bottle with cap on. It will not hold cans and cups. At least this is what I read in the owner's manual.
  11. itssunnyv
    itssunnyv New Member
    33
    Studio City, CA
  12. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    Sounds like it's missing the "rear console box pocket", which I would normally call the "cup holder."
  13. Joe166
    Joe166 New Member
    720
    97
    South Florida
    If they called it a "cup holder" everyone would know what the heck they were talking about. That would take all the fun out of it for the manual writers.
  14. ahope577
    ahope577 Junior Member
    Somerset
    There is a removable plastic holder that should be present in this area - it is removable so it can be cleaned but it sounds like it is missing in your vehicle...
  15. bisco
    52,292
    i think you're missing the cupholder itself, er, rear console box pocket.
  16. RRxing
    2,553
    1,827
    NEPA
    Y'know, I think I'm going to start a band called "Rear Console Box Pocket." Has a certain ring to it, doncha think?
  17. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    Do you have the cup holder in place? Mine is pretty snug and does just fine. Try and reseat it to make sure it is snapped in correctly.
  18. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    I assume Groucho, not Karl
  19. bisco
    52,292
    i like it! are you sure it's not taken? sounds familiar.:rolleyes:
  20. bisco
    52,292
    imagine if they took the huge area below the shifter (where the current single cupholder is) and created a beautiful storage area with two cupholders and change holder etc. that would be brilliant! oh wait, it's toyota. only brilliant engineering, not interior design.
