When Gas light comes on, how many miles (approx) can you get before it runs out ?
Discussion in 'Gen 2 Prius Audio and Electronics' started by mwhaley99, Jun 7, 2006.
  1. mwhaley99
    mwhaley99 New Member
    63
    Prius 2005
  2. HokieHybrid
    HokieHybrid New Member
    200
    There have been a ton of posts on this forum regarding the unreliable nature of the flashing pip. Sometimes people have gotten as few as 7 miles out of it after that. In short, don't push it.
  3. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    I actually base mine on mileage and not the gauge. Since the calculated MPG is normally pretty close (within a MPG usually) I can easily ballpark when I am getting low. For me, 500 miles is usually around the time to fillup.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    I have never seen the "flashing last pip" or the low fuel warning light. I decided to test them one day and kept driving long after I normally would have. I finally chickened out and filled the tank. By topping it completely up, something I don't normally do, I got 11.7 gallons in so I think I was pretty close to being out. It was a warm summer day however, so the bladder was behaving OK.
    There is a procedure for calibraion of the fuel gage on this site somewhere, I haven't bothered with it I just fill up when I see the last pip, or before.
  5. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(Mark Whaley @ Jun 7 2006, 07:35 AM) [snapback]267205[/snapback]</div>
    From 1 to 100 depending on many factors. In short fill tank before it starts blinking.
  6. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    <div class='quotetop'>QUOTE(seasalsa @ Jun 7 2006, 10:15 AM) [snapback]267234[/snapback]</div>
    Be careful there, SeaSalsa. You don't want to box yourself in with tight predictions. You might want to consider widening the range a bit. :D
    Mark, they're all correct, of course. You should get concerned when the last bip blinks. If you're daring, base it off the current mileage you're achieving. I know exactly how much gasoline I put in the tank from refill to refill (see spreadsheet in signature) so I feel pretty confident in taking current mileage and multiplying by 10 or 11 and refilling when the ODO1 hits that point. Even then, sometimes more or less goes in than I expect.
    In the end, all we can do is say "you've been warned." :)
    Matt Moyeah likes this.
  7. mwhaley99
    63
    So as I only just got the car and its never been down to empty.
    I am right in assuming that it will go to the last (first) bar near empty for awhile, then when it gets very low it will start to blink ?
    I ask as I commute 55 miles each way to work each day and I am down to 2 bars before my trip home today and was wondering if their might be enough in the tank to get another work days worth of driving out of it...I am already at around 500mpg since I intially filled it up.
    I could (for testing purposes and not to get caught out) put a gas container in the trunk with gas in it, just in case.
  8. TonyPSchaefer
    14,816
    2,500
    66
    The last bip will show solid for a while and then start blinking. I usually refill on the same or the next trip once it starts blinking.
  9. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    When the last pip begins bllinking I always refill within 30 mi (45 km) and have never had a problem.
  10. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    This is a mind set I just do not understand. Just fill the car up with petrol when it gets low. Is that so hard? A friend of mine asked, "if the Prius gets such good milage, why do I always see them at the side of the road, out of gas?"
    Good question.
  11. Porridge
    Porridge New Member
    91
    <div class='quotetop'>QUOTE(jbarnhart @ Jun 7 2006, 04:34 PM) [snapback]267438[/snapback]</div>
    Because the Prius is unpredictable. I got over 40 miles after the blinking light came on - the false sense of security is set and this is probably happening to a lot of people. Then on a longer trip coming back from DC the light started blinking and 14 miles later I am calling Toyota Assistance. I was one mile from the next gas station - no battery left to make it and no one would want to do 25 mph on I40 outside of Memphis.
    If you want the math, (from memory), 414 miles, MFD = 40.9 MPG. Roadside assistance put in 3 gallons, I put in 7 gallons one mile down the road. It would not take anymore - I could see the gas in the nozzel. I have been able to get 11.5 gallons in the Prius once - that scared me so I always fill up as soon as possible after the blinking light.
    I welcome all challenges on defending the Prius running out of gas after 14 miles after the light starts blinking. My Prius is not subject to the early recall (oops, I mean TSB) on faulty gas gauges.
  12. seasalsa
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(Mark Whaley @ Jun 7 2006, 09:12 AM) [snapback]267273[/snapback]</div>
    HMMM!! Why not just put it in the Prius tank?
  13. mwhaley99
    63
    Well low and behold.....
    I set off from work on my 55 mile trip home and a few miles into my trip, the level dropped to 1 bar.
    About 20 miles from home, it started blinking (so did my heart)
    But I managed to drive the rest of the way and filled up at my local station.
    so.....
    530 miles on one full tank (assuming around 11.9 gallons)
    52 mpg average
    $33 to fill up (10.33 gallons)
  14. TonyPSchaefer
    14,816
    2,500
    66
    So you drove 530 miles on 10.33 miles averaging 51.3 miles per gallon. Remember, it's the amount of gas it takes to refill the tank that you make the calculations with.
    We can assume (sometimes incorrectly) that the tank will refill to the same amount each time. It's an assumption and is prone to be wrong from time to time, just roll with it. Then you drive a ways. The amount of gas it takes to refill the tank is the amount of gas it took to drive those miles. In this case, 530 divided by 10.33 is 51.3. If you want to track your lifetime mileage with a spreadsheet, let me know and I'll send you mine. Check the link in my signature.
    dmh1026 likes this.
  15. Craig63
    Craig63 New Member
    FL
    I have an 09 base. I love it. Wanting to experience that "Kramer Volvo Moment" (lol) as depicted in an infamous Seinfeld episode, I consulted my Prius owners manual and noted it has a tank capacity of 12.9 gallons. With this information I have (and am still attempting) to take it to the max. So far, the best on the odometer is 572 miles. When I pulled into the gas station I filled up the tank (until it overflowed with a trickle) and the gallons added was 11.6.... I was averaging about 50.1 miles (according to the trip info on fuel ). It must be notated I do drive moderately and utilize the cruise control often. So, if I had 1 more gallon (1.3 actually) maybe I could have gone another 40 + miles.......Kramer.....here I come.......I will keep you posted. :)
  16. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I would check again, I think my 09 has a 11.9 gallon tank.
    I get gas with one pip when alone in the car.
    I get gas with two pips with my wife in the car.
    I get gas with three pips with my mother in law in the car.
    You just have to judge the consequences of failure.
    Horseflesh and Data Daedalus like this.
  17. kalidasa
    kalidasa New Member
    I have a 2006 Prius and whenever I get the low fuel warning (beep + last blinking segment) I push my tripometer -- assuming I have one-half gallon of petrol remaining -- I've always been able to get another 20 to 25 miles further. However, YMMV ... so be careful. If you run out of petrol you may get chastised by the dealer when they service your vehicle and interrogate your system.
  18. fdf
    fdf Junior Member
    27
    After having run out of gas last summer under circumstances that were puzzling and seemed uncharacteristic of previous gauge functioning, a while ago I ran into one more element of puzzling behavior:
    After filling up (I'm feel sure it was full, because the shutoff popped off 4 or 5 times -- I recall wanting to be sure of having maximal range), I got in and drove just a short distance past the pumps, parked, and went into the store. It seems I turned off the car so soon, before all of the segments had lit up, that when I returned and drove off, the top segment stayed unlit. Furthermore, until I was down (all too soon) to 2 segments lit, the out-of-whack bias persisted throughout that tank! At the next fill up, it took far less gas than the (then confused) gauge would have indicated.
    So, in addition to the slope levelling device and the bladder, it looks like there are indeed, as many people seem to suspect, even more complications.
  19. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I wouldn't bother chancing it. I almost always get gas when I hit 2 pips. If I get down to 1, for me, that means get gas ASAP.
  20. wrexed03
    wrexed03 New Member
    42
    Melbourne Australia
    Did 15kms on last flashing pip today. I got lazy i couldnt be bothered filling up last night or in the morning before leaving for work. lol..
