radio 2005 transfer 2008?
Discussion in 'Gen 2 Prius Technical Discussion' started by tem, Dec 3, 2007.
  1. tem
    tem New Member
    I have a base 2008 Prius, with 1 play CD, but no cassette player?
    Can I transfer a used radio, CD player, cassette player from 2004, 2005, 2006, 2007 to my car?
  2. pepere
    pepere New Member
    cocoa fl
    I need the same answer my 05 has with all the bells and my 08 has only one cd track no cassette can I swap
    thanks
    Robert
  3. jdenenberg
    jdenenberg EE Professor
    3,944
    1,941
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Ask Steve at Plug In Hybrid Electric Vehicle PHEV
    He will know what works and can supply a tested, salvaged stereo to you at a reasonable cost. I bought a 2006 stereo for my 2004 from him for $82 total cost.
    JeffD
  4. uart
    uart Senior Member
    4,220
    1,211
    Australia
    People are still using cassettes? Must be time to transfer all those old cassette tapes to CDR or mp3. Just use the "line in" jack on your computer to record them, it's dead easy.
  5. Stormtrooper1
    Stormtrooper1 New Member
    MN
    I was thinking the same thing!
  6. pepere
    pepere New Member
    cocoa fl
    It's the 6cd that's the biggy so do yi=ou know or don't care
    Robert
  7. pepere
    pepere New Member
    cocoa fl
    It's the 6cd that's the biggy the cassssssettter is of no no matter
    OK Robert
    Thank but help me if you can
  8. Patrick Wong
    18,210
    6,511
    You probably know that the JBL stereo has a separate power amplifier, located under the front passenger seat. I suggest that you look at your 2005 to locate this and note the wiring harness.
    Then look at your 2008 to see whether you can find that wiring harness. If yes, then there's a reasonable chance that you can swap the stereos without too much trouble.
    If you don't find the wiring harness then you'll have to fabricate the necessary wiring to effect the swap which is probably more trouble than it is worth. Better to buy an iPod, load it up with your music, and plug into the AUX jack of the 2008.
  9. sstk100
    sstk100 Junior Member
    Ne
    I both an 04 with JBL system, and an 08 with standard AM/FM-CD system.
    There's ton's of difference in sound of the two.
    Haven't tried to install a JBL complete system into another car, but would be worth it if you can get the complete sytem.
  10. sktn77a
    sktn77a Member
    303
    NC
    I have a 2005 with the JBL cassette/6CD changer. Later models (Std or JBL) sacrificed the cassette but added MP3/CDRW playback.
