Anyone hardware a Valentine 1 on the gen 3 prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by lazytrax, Mar 14, 2011.
  1. lazytrax
    lazytrax New Member
    CA
    I am trying to figure out how to hardwire the v1 on my new prius. Any instructions on how to remove the center dome cover? v1 guys please chime in. :confused:
  2. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    You might want to talk to PriusCritter here on PriusChat. He has one. :)
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I had a V1 in my cars for ~10 years (and a Passport before that), but decided I didn't need it in my Prius. :D I sold it on eBay for almost as much as I paid for it. :cheer2:
  4. lazytrax
    lazytrax New Member
    CA
    Cool thanks I will contact him and maybe he can shed me some light on installing this bad boy.
  5. lazytrax
    lazytrax New Member
    CA
    Dont think i can go without the v1. I kind of feel naked without it already.. Have to be extra precautions with the economy like this. :p
  6. Turdblossom
    Turdblossom Junior Member
    28
    Kentucky
    Go to http://www.invisicord.com and get yourself an invisicord. It plugs into your Valentine 1 and into your Mirror wiring. Be sure to choose the micro version so the probes fit the mirror wiring/jack. It will be the best $15.25 you spent
  7. priuscritter
    priuscritter I am the Stig.
    1,525
    199
    Indiana
    Sorry, mine is not hardwired. It is suction cupped to the windshield and i run the cord through the A-pillar molding, under the glove box, and into the power port under the center console. It's a pretty clean install, powers up and down with the car, and very simple.
  8. RadioZero
    RadioZero Member
    154
    59
    Orlando
    2018 Prius
    just did this last weekend. i used an "add a fuse" thing and plugged it into #1 on the fuse block under the dash. #1 is Cig which is switched on by the power button. had to use 15 amp fuses but no worries. i also grounded the unit to the exposed nut on the firewall just behind the E brake.
    i mounted the V1 behind the rearview mirror and everything is working fine. i have no worries about missing rear laser shots from cops. if i passed them then they should shoot me in the rear......
  9. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
    i also have my v1 hardwired. i have it hooked up to acc power via the dimmer control
  10. lazytrax
    lazytrax New Member
    CA
    humm.. I got the base prius which doesn't have any electrical components in the mirror. so invisicord would not be an option. Would I be able to hook it up into somewhere in the dome light area?
  11. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
    i hooked it up the same way the homelink mirror is installed. check out the attached pdf, and it will show you how to wire it using the acc on wire for the dimmer, same as toyota would for the homelink mirror
  12. octomobiki
    octomobiki New Member
    NY
    how did you mount the V1 behind the mirror? do you mean off to the side and not where the black dots are? I found that in the Prius and in our Acura which both have the black dots behind and around the mirror (what DOES that do anyways??) - that we are unable to mount anything there short of very strong double sided tape.
  13. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
    i had some leftover clear bra material and used it over the back dots. im sure you could even use leftover screen protector material or something similar as long as it can be smoothed out
    attached a pic of mine
  14. snakeye2669
    snakeye2669 Junior Member
    Jersey
    dopey423,
    Are the red wire switched on and the white/black wire ground?
  15. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
    yes i grounded the black wire to a nearby screw and then tapped the red wire from the v1 to the grey wire for the acc power source. the v1 turns onright when the power button to the vehicle is pushed. hope that helps!
  16. snakeye2669
    Jersey
    dopey423, thank for the quick reply. Sorry, but let me clarify. I would like to know about the 20 pin connector* going into the map light, that the homelink mirror connected to on the pdf. If the red cable on the diagram is a 12v and the white/black cable are for the ground. I have a Passport 9500ix and a invisicord and what to use those cable to juice up the radar.
    The pdf show the homelink mirror wasn't installed factory, but from the dealer using a t connector, I like do the same for the radar and tap into the same cable.
    Similar to my former Fx35 I trade for the prius, but just tapping in the two cable listed above.
    Basically I like to know what these cable do before I stick anything in it without electrifying myself and the car. I think this would be a good power source to hang Gps, radar, Scantool, etc
    *20 pin connector is in a 2011 Prius without sunroof.
  17. Judgeless
    Judgeless Senior Member
    1,821
    256
    Cleveland, OH
    I have a Cobra unit I hardwired to the car. Here is a pic of the unit.
    Here is a pic I put together that shows were I tapped into. I tucked the wires inside the liner.
  18. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    Have it hard wired, mounted upper left side of windshield, and remote display sitting on top of scanguage ontop of steering colume. Nice and discreet.
  19. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    Valentine One Radar Detector Mount
    I mounted mine under the mirror with the Blendmount. Took me a while to get it installed onto the mirror, but finally got it! (not my thing! lol) Nice, custom, built-in look, I think. My stereo dude hardwired mine into the fuse box and then ran the wire through the rearview mirror arm, under the headliner, down the side pillar, and then to the fuse box...
  20. LeadingEdgeBoomer
    289
    29
    New Mexico
    Here is my solution. I found that I could mount the Valentine unit by using the visor mount by pushing the mount hook above the headliner. I had to block open the visor mount with some stuff to keep it wide open, and it met some kind of obstruction a short way in, but I got beyond that. It now sits high, but below the strange windshield dots, in what I think is an ideal location, on the driver side of the mirror.
    The downside is that the driver visor cannot go beyond vertical, but it works just fine angled at me instead of away from me.
    How to power it? Apparently, everything in the overhead console, definitely the Homelink mirror, is on all the time, and I wanted a switched install.
    I went to the local Audio Express store, and they knew just what I needed. I explained that I needed a switched install, and suggested going along the headliner, down the driver A pillar to the mess of wires behind the panel next to the parking brake. The tech said no, there are unknown fuses involved, and recommended wiring down the A pillar to the On button behind the dash.
    Who am I to blow against the wind? They know more than I do about this.
    Result: Perfect. Took 20 minutes from start of work. Cost me $45+tax. The V1 is mounted high (as recommended), virtually invisible from outside, easy to reach, and easily removed from the car if theft is an issue.
    I still want two power plugs under the rear deck, one for trickle-charging an LED lantern, and the other for ??? a mini-fridge for road trips ??? This experience leads me to believe that these are the guys to do this work.
