2008 prius front bumper replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by markmezzano, Mar 15, 2011.
  1. markmezzano
    markmezzano New Member
    I need to replace my front bumper. Is it difficult or is there anything special I should be aware of?
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    Toyota recommends disconnecting the battery negative before starting work like this.
    The hard part is paint. If you buy a new one, it will be black. If you haven't painted a bumper like this before, it is not an easy DIY thing.
  3. sstk100
    sstk100 Junior Member
    Ne
    Best to have it painted by body shop. The paint is a base color coat, then a clear coat to finish.
    It takes some time to remove and replace a bumper, because of all the connection points.....not difficult, just time consuming.
  4. PriusTech
    PriusTech Active Member
    264
    133
    Reno
    Note the position of the edges as relates to the mating parts before dis-assembly, it differs going around the edge, and it doesn't necessarily just fall into the correct position going back on.There's a hidden bolt at each far back corner (10mm head). It helps to have two people going back together, where it fits around the headlight is a little bit tricky. If it's been wrecked before it can be more difficult due to fitment. Check to make sure the mounting pads by the fenders aren't broken, replace if necessary.
  5. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    ^ +1
    Good advice. I've had mine off twice and it wasn't difficult but far from fun. Take pictures as you go with removal and be sure to keep the bolts sorted by location - there are differences.
    - D
  6. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    The hardest part is getting it loose from the headlights.
