  1. kidsao
    kidsao New Member
    ca
    new to the site, just got my self a Prius II and starting to mod it a bit.. make it look alittle better so today i went and install HID on it
  2. PriusII
    PriusII Junior Member
    NorCal
    Which kit did you use and where did you install the ballasts? Any pics of the install? I'm thinking of doing this also.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Thank god you used projectors and not just a pnp kit in the halogen reflectors...
    Output is a little wonky, but much better than most cheap projector kits from ebay I have seen.
  4. kidsao
    kidsao New Member
    ca
    i stick the ballasts right under the head light assy its self.. use 3m double side tape and just tape it on there... yea.. the car came with projectors so thats a plus..
  5. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    damn the pictures are small, so what kit did you get?
  6. kidsao
    kidsao New Member
    ca
    loading pictures right now
  7. kidsao
    kidsao New Member
    ca
  8. F8L
    19,011
    4,081
    Grass Valley, CA.
    Agreed! Although I have no room to talk. I'm just using my factory HID headlight to house my kit. lol
  9. 2ZR JDM
    2ZR JDM Active Member
    106
    142
    Redondo Beach
  10. us_matrix
    us_matrix Member
    110
    What kit did you get? Did u install relay harness? Any issues?
  11. kidsao
    kidsao New Member
    ca
  12. kidsao
    kidsao New Member
    ca
    and no i did not need to install a relay, the kit i got was about $100 but i think its cheaper now
  13. F8L
    19,011
    4,081
    Grass Valley, CA.
    For anyone considering an HID P&P kit take a look at these bulb illumination tests. The OEM Phillips 85122+ (non-colorshifting version) out performs just about every kit bulb on the market. If you like a whiter light and don't mind a small loss of lumens then the 85122 (color shifting version that comes stock on Prius) works well and exhibits a small color shift after approx. 100hrs.
    Also consider the Osram 66240. TRS started selling these bulbs because of all the fake "85122+" bulbs being sold on eBay. You get what you pay for. :)
    Quick Results Spreadhseet: https://spreadsheets.google.com/ccc...GVXpvYXFSQlVhLXc&hl=en&authkey=CIj_t8AH#gid=0
    The Testing Thread: H1 Bulb Operating Temperature (and other properties) Comparison
  14. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    BTW, you need to register to see the picture.
  15. F8L
    19,011
    4,081
    Grass Valley, CA.
    Oops. Sorry about that. :(
    Ohh BTW. I spoke with Nate at TRS today about retrofitting the Morimoto Mini H1 or Mini DRS and he said there would likely be a small amount of cutting involved but it would be a lot easier than using the FX-R projector. If you are not skerd of epoxy he felt that the FX would be a better upgrade.
