PHV range without using EV mode
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JMiller77, Mar 12, 2011.
  1. JMiller77
    JMiller77 New Member
    Pennsylvania
    I'm just curious...if somebody drives a PHV Prius like a regular Prius (not using the 13 mile pure EV mode range), could they theoretically get better gas mileage by staying in the electric part of the hybrid system indicator?
  2. qbee42
    3,081
    Yes. The Prius calculates mileage only by measuring fuel consumption, not battery charge. Anything that moves the car without burning fuel increases the displayed mileage.
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    In the PHV (the prototype at least) you cannot manually override the CD mode and go striaght to CS mode (i.e. "regular Prius" mode).
    Giora.
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    There's no need. Even at 70 MPH and well beyond 13 miles, you're still going to get a big MPG boost. For example, this drive I did with the PHV:
  5. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    What is the true MPG of a PHV AFTER its at-home charge is exhausted? It has a larger battery than a non-PHV, but in most cases a non-PHV never hits full capacity. Also the PHV is heavier. Can it generate better mileage and if so how? I understand its electric motor and regen are the same, right, or can it regen more aggressively (in which case I absolutely understand it getting better mileage).
  6. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    I believe John posted above pics of his 64mile trip :)
    (out of which 13 were ev i would guess)
  7. Skoorbmax
    2,641
    265
    Western NY
    Right, but that's one trip. Some people around here get crazy mileage. I wonder what his mileage would be on the same trip, or what Toyota's official position is of PHV mileage.
  8. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I'm sure when it was tested in CS mode it got "the same" mpg as a gen3. Regen capability will be increased slightly, as the boost converter and battery are more powerful. hypermilers don't regen much though, so it won't help with getting really high numbers.
    As to the OP's question, you cannot enter or exit EV mode at will. It is in EV mode under ~30kw of power and 62mph. above either of those thresholds (so if you charged up at a service station on the freeway, and then when right up to 70mph) you would still be in CD (Charge Depleting) mode. In this mode the ICE runs at a low power level, and the electric motor continues to operate at a high power level (exact data is unknown, but will probably vary significantly based on road speed and load) meaning the displayed "MPG" will be very high (think still 80+MPG) until the EV packs are exhausted. they will likely be exhausted within the 13 miles you'd expect from EV mode, unless you are going down a hill.
  9. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    Since there is no EV mode button, if you get in the car and drive it 4 or 5 miles down the road at 40 mph, will the engine be on during that time? In other words, will it attempt to warm up the engine each time you start the car, or only after a certain point?
  10. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    No, the engine will not come on to warm up each time you start so long as there is charge left in the EV battery. It will come on close to the end of the 13 mile range (it comes on in a 'light operating' mode to begin the warm up process before it has to take over once the battery is depleted and run like a normal Prius) or if you punch it hard.
  11. drash
    drash Senior Member
    2,595
    1,337
    Upstate NY
    XLE AWD-e
    Weird but since the battery is directly affected by temperature, maybe Toyota could slip in a Winter button that would turn on the engine to help with the warm up. When the cabin temperature gets up to a certain point then the electric only would gradually kick in. Would help with those particularly cold mornings in the spring and fall. Just a suggestion.
  12. Flaninacupboard
    1,297
    213
    Midlands - UK
    I believe it will start the ICE right away of heat is required, is that right?
  13. adric22
    642
    146
    Fort Worth, TX
    My 2008 Prius (with enginer kit) does this as well. In the morning I drive along in EV mode for several miles until I reach a street where the speed limit is 45 so I have to go above the 34 mph limit for EV mode. The engine kicks on but when I watch the scanguage II, it is still drawing all motive power from the battery for at least another 20-30 seconds unless I really press the gas pedal hard.
  14. Skoorbmax
    2,641
    265
    Western NY
    In this case those in cold climates, during the winter at least, will really have no EV-only range, just an EV-boosted mileage because the ICE will be running purely for cabin heat.
  15. Flaninacupboard
    1,297
    213
    Midlands - UK
    Well that makes sense. when i'm going 60mph and want 1kw of heat the engine would barely be idling to produce that much heat, so the motive power will still come mainly from the traction battery and the "MPG" will still be 100+.
  16. Skoorbmax
    2,641
    265
    Western NY
    You know, not being 100% EV for some range due to various conditions may not be sexy like it is in the Volt (which has an electric heater, apparently not a great one), but it certainly has its ups from an effectiveness standpoint. One uses gas to boost range of an EV vehicle, the other EV to boost the range of a gas. I think Toyota did it better, but then they also have spent many more years at this.
  17. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    The Prius plug-in prototype has heat pump based A/C heating, not from the ICE coolant heat, therefore the ICE does not run because of cabin heat requirement.
    Ken@Japan
  18. Skoorbmax
    2,641
    265
    Western NY
    Thanks!
  19. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I suppose this electrical driven heat-pump will shorten the range in EV mode?
    Giora.
  20. Flaninacupboard
    1,297
    213
    Midlands - UK
    Yes, but less than a resistive heater would. If the heater is running at 1kw, you will lose 4 miles of range for each hour it operates. if you are running 30mph, you'll cover the 14 mile range in just under half an hour, so with the heater on that may reduce to a 12 mile range. This is roughly the same as the Leaf losing 16 miles of range for having the heater on, or the Volt losing 6 miles.
    That's not looking at all at the impact on range -driving- in the cold has (because of increased air density, decreased tyre pressure, increased friction on the road etc) but it's easy to see the PHV going to a 10 mile EV range, the Volt to 28 miles and the Leaf to 71 miles.
