Turn radar cruise on/off
Discussion in 'Gen 3 Prius Main Forum' started by Chris2128, Mar 22, 2011.
  1. Chris2128
    Chris2128 New Member
    85
    Oklahoma
    I have a 2010 prius v with adv. Tech. I noticed that I cannot turn off radar if I want to use regular cruise control sometimes when there is denser traffic. I know that it can be turned off on a Toyota sienna if you press and hold the radar distance button. I've tried with the prius, no luck. Any ideas?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    After pressing the button to turn cruise control on, push and hold the stalk forward (the actual cruise stalk that has the on/off button on it). That turns off the radar mode and makes it operate like normal cruise control.
  3. Chris2128
    85
    Oklahoma
    Does Pre-collision system work when not using radar cruise?
    I have a 2010 prius with adv. Tech. I was just wondering for peace of mind if the pre-collision system still works when you are not using cruise control. Any ideas?
  4. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    Re: Does Pre-collision system work when not using radar cruise?
    It absolutely does.
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Yes, just because you turn off the radar cruise control, the unit does not stop emitting and using the radar. It's still activated even when cruise/radar cruise is off in general, so it does not turn off because you choose not to use radar cruise.
  6. Chris2128
    85
    Oklahoma
    Does pre-collision system detect deer or other animals?
    I have a 2010 prius with adv. Tech. I drive 100 miles a day and it gets really dark around 10 pm. It would be great to know if the precollision system can detect deer or other animals on the road or not.
  7. Chris2128
    85
    Oklahoma
    Constant use of radar
    When I drive out of state, I drive for about 4 or more hours continuously till I need more gas and for these 4 or 5 hours I never use the brakes because the radar cruise control does all of that. Does this system heat up or is it's life affected with such continuous use?
  8. Chris2128
    85
    Oklahoma
    Will try this in an hour and let's hope it works for me.
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Re: Constant use of radar
    Nope, use it and enjoy it.
  10. Airboss
    Airboss Junior Member
    Southern New Joysey
    First, let me say that I don't know if it heats up or not. Police radar, at least some of the older ones, are continuously on. The newer ones (not laser) are pulsed on by the cops at the last moment to try to out maneuver a radar detector. We all know that the police sure like to keep the radar on, for our traffic safety, of course.
  11. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    It is my understanding that the radar is always on whether you're using the cruise control or not. The pre-collision system uses the radar as well.
  12. Airboss
    Southern New Joysey
    Re: Does pre-collision system detect deer or other animals?
    My guess (ex Air Force radar type tech) would be no. The low power of the Prius radar, coupled with the poor radar reflectivity of the deer (no metal), would not be detected.
  13. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    That's why they have antlers, that is where the aluminium foil goes!! :eek:
  14. drash
    drash Senior Member
    2,590
    1,335
    Upstate NY
    XLE AWD-e
    :eek:
    How about a crazy man with an axe and a 6-pack of bud lite?
  15. Thai
    Thai Prius Neophyte
    1,197
    89
    The system will alert us to avoid him so that we can give him a ride in our Prius....
  16. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Deer have crossed my path seemingly within inches twice without any reaction from the avionics.
    What's the advantage of the normal cruise control?
  17. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    It's a paradox. I tried holding the stalk for the active cruise control foreword for a couple of seconds today while driving my Gen III V with the ATP. In spite of numerous tries, the radar cruise control continued to display the bars for the distance to an obstacle and remained active. What am I doing wrong.
  18. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I tried the other day also and at first I did not think it would turn off, but I held the stalk forward longer and it did turn off the radar. The DRCC distance blocks went away and the screen was just the rectangle outline with the MPH setting displayed. Might have to hold it forward longer to turn off the radar. I could not select the radar again from the traditional CC I had to turn off all CC and start from the beginning to get the DRCC radar back online.
  19. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Once you've set a speed, you can't change from radar cruise to dumb cruise. You have to shut the cruise off and turn it back on then turn off the radar cruise. To reactivate the radar cruise, turn off and on the cruise.
  20. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    You pulled and held it; it's a push and hold.
