K & N air filter
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Alexma, Mar 24, 2011.
  1. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    What are your thoughts for changing the filter out for a K&N?
    Thanks in advance!
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    My opinion is...no!
    It's been discussed many times, so do a search for more info.
  3. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    Didn't see anything for the 11's. I didn't know if there is a difference with the genIII's or 11's.
    I've had these filters on all my cars.
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Why would you want to?
    FWIW, when I used to have an 02 Maxima, it seems that whenever people (on maxima.org) changed out their air filter assembly for something aftermarket, they'd usually end up having their MAF sensor fail. Not worth it, IMHO.
  5. stream
    2,977
    452
    Long Island, NY
    I've seen that reported in many forums (Porsche, Mercedes AMG, BMW, etc.). Plus, whatever...purported...benefits (HP, etc.) don't really apply to a Prius, do they?
  6. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    K&n filters come.pre oiled....
    The ones that have MAF sensors go out tend to be ones that oil their new filters or after the first cleaning, put on way toooo much oil.
    The extra oil is blown off the filter while driving which ends up coating the MAF sensor which leads to failure.
    Cleaning up the excess oil and spraying the sensor with a cleaner, tends to restore the sensor.
    The MAF sensor has a very thin small wire that measures the resistance as the flow of air passes.over it.
    Being new to hybrids, I am unaware of the relationship between the traction motor and the gas motor.
    On a gas motor...more flow tends to lead to more power. This includes having an exhaust that has better flow. Including a better flowing cat convert.
    I am guessing that a free flowing filter would be a benifit.
    Looking for more real world experience vs personal.opinion on the product.
    I do want to thank everyone for their input.
  7. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    This would also include other "wet" filters like TRD and others.
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    The Prius does not benefit from a "higher flowing" filter like the K&N and the filtration ability is reduced compared to clean stock filter. Personally I wouldn't bother. I've modified and raced V8 sports cars and trucks for decades and even I don't see the benefit of a K&N style filter on my car. :)
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    On most newer cars, except large displacement or forced induction cars, the benefit is very slight to non-existent as verified by dyno days that I have participated in. Keep in mind that the Prius is an Atkinson style engine and not the typical Otto cycle.
  10. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    Good food for thought.
    But, there is a benefit in being able to wash and reuse a filter.
    It helps keep some of those filters from ending up in the landfill.
    Also, helps save money since you are not always buying filters.
    If you change out the filter every 15k miles, you tend to strt recovering the cost after the third or fourth filter.
  11. LoveMyPriusIII
    LoveMyPriusIII New Member
    66
    When I had a Ford Ranger the K & N filter definitely gave me more power and acceleration. At the same time it reduced my fuel economy by 2-3mpg even when I tried to take it easy. I switched back to the normal filter and got my mpg's back.
  12. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    F 8 L....thanks for the input....this was the kind of info I was looking for.
  13. Dusty Chips
    Dusty Chips New Member
    85
    Laughlin NV
    My take is that high flow air filters only make a difference at high revs; who drives a Prius like that?
  14. shawnb2
    shawnb2 Active Member
    533
    107
    22
    Thousand Oaks, CA
    I recently bought one for my car for the reasoning of being able to reuse it. Have used K&N style filters on most of my cars and have never had a problem with MAF sensors or the like. Maybe it's just my imagination but at mid-speeds it does seem to get up and move a little quicker after the first few days of driving. I got it from Amazon for $38 free shipping. Everyone has there own personal opinions about things like this, it's just up to you to make your own mind up for what you want to do. I will say, again not for the performance aspect of it but am looking at eventually getting a cold air intake by HKS. It may or may not do anything but go with the look of the car that I'm after and that's enough for me even with the cost of it. I like to think outside the box you could say.
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    NP man. If you end up putting one on your car and dyno it please post your results. I don't mind being proven wrong if it means we get more solid data. :) Thanks!
  16. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    F8L-Not trying to prove anyone wrong here ;)
    If anything, it will save me money in the long run by being able to clean it and reuse it.
    Makes it a little greener too by not tossing so many used airfilters into the landfills.
  17. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    I still wouldn't bother. Unless your filter looks really clogged at 15K miles, it doesn't need to be changed that often.
  18. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    That's o k, you don't have to bother.
    Some people feel that a K & N is waste of money, I do not.
    This is my first hybrid and I just wanted some input.
    Thanks... :)
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
    Ohh no, I didn't mean it that way. Sorry if it came across that way. I just meant there is not enough data to prove or disprove my opinion regarding the Prius so if you decided to go for it then please report back. :)
  20. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    Thanks F8L....all is good.
