New Prius - only 39mpg?
Discussion in 'Gen 3 Prius Fuel Economy' started by manku, Mar 22, 2011.
  1. manku
    manku Junior Member
    29
    United States
    Thanks for all the replies...I'm at about 355 total miles driven, and looks like I have one bar left on gas gauge, so maybe 35mpg.
    I'll refill and keep you updated...
  2. hihosilver00
    hihosilver00 New Member
    American Canyon
    wow.. i thought sopmething is wrong with my prius. thanks to all, i realize what,s wrong with mine..lol i live in bay area and the route i take has lots of hills.
  3. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
  4. manku
    manku Junior Member
    29
    United States
    Filled it up yesterday...just over 9 gallons...and drove about 360 miles, so 40mpg.
    I don't really feel like changing my driving habits completely, so I'll probably just have to suffer at 40mpg, with the occasional 50mpg on road trips.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    As I understand it, you have yet to fill the tank and use a tank you filled up. Do not be surprised when you get better mileage. I try to convince folks not to stress mileage until the third tank, but it is hard to listen.
  6. manku
    manku Junior Member
    29
    United States
    Hardly stressing....9 gallons of regular to go 350 miles beats the heck out of 18 gallons of premium to go 300 (E350, city driving:eek:)
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Google says the E350 is rated 18 mpg, and you report 300/18 or 92% of rated. 92% of Prius rated city MPG is 44, so you are about 10% off expected so far.
  8. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    i think you will come back to report >45mpg after few more thousand miles, keep us updated!
  9. vday
    vday Member
    312
    Israel
    Very true
    My two worst tanks were my first two. :)
  10. JerrySC
    JerrySC New Member
    29
    SC
    I've had my 2010 Prius for about 8 months now. I routinely get about 45.2 mpg (indicated). It's the same in town or on a trip. I am an easy driver and don't do jack rabbit starts, etc. The car is a V model with nav. Normally I am the only one the in the car and tire pressures are set to factory specs. The odometer is at 5000 miles now. I've about resigned myself to the fact that this mileage is as good as it gets on this car. There are no hills here. I tried the over inflation of tires with a small increase in mpg and a dramatic reduction in ride comfort. I've tried all the modes. I leave it in normal now. So, 45 mpg isn't bad at all. It's nowhere near the 50's I hear people report, but it's good enough.
  11. bac
    bac Active Member
    863
    52
    Pennsylvania
    BY FAR, the #1 cause of poor fuel economy is the length of your drives.
    If you're making mostly short trips - your FE will not improve. That's the nature of ALL automobiles - they don't get optimal FE until they are warmed up which generally takes about 5 minutes in most climates.
    -Brad
  12. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    I knew there had to be a down side to my office relocating closer to my home next month!
  13. F8L
    19,011
    4,081
    Grass Valley, CA.
    The 17" wheels don't help either. That's why I rarely have them on my car.I get sick of the mpg drop and put the 15s back on.
    Curious about your speed on longer trips. Have you taken a trip longer than 50 miles and measured FE just on that trip? If so what was the mpg and what average speed did you maintain?
  14. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Remember, the real goal is to use less gasoline, NOT to rack up the largest MPG. Driving more to increase MPG is misguided.
  15. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    That is your first tank MPG, the car probably sat overnight at the dealership while turned on, others who test drove it most likely hammered down on the accel to "test it out". I test drove 3 prii before I bought mine, every dealer just walked away and did not turn the cars off. When I bought my car the display read 27 mpg by the time I filled my first tank at 483 miles it read 55 mpg. I don't have hills where I live. I'm looking to break my 60.4 mpg record this summer. My all time FE average is 54.4 mpg.
  16. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    Trust me, I wouldn't trade it. My office is moving from 12 miles away (already a pretty close commute for me) to about 6 miles away.
  17. macaw
    macaw New Member
    This is true. And cold weather and hilly terrain are both also bad for FE. But one car modification that actually pays for itself within a year or two is an engine block heater. Also block your grill when the daytime temperatures are consistently below fifty degrees F.
    The week before I installed my engine block heater I got 36mpg in my 2006 Prius. The week after I installed it I got over 42 mpg. Over my trip from MO to pennsylvania last thanksgiving before getting the EBH, I got about 44mpg. My commute is only ten minutes each way over hilly terrain, so even in the summer the engine barely has time to get warm before I reach my destination. (optimal operating temperature is about 154 degrees Farenheit, until it reaches that it is less efficient.) Over my past tank of gas my average is 46 mpg now that it's mostly above freezing in the day. I have the EBH on a timer so it preheats for three hours before I leave in the morning. It may seem silly to install an EBH after the winter is over, but even in a mild climate it will help your gas mileage to use one. There is a thread on how to install one stickied in one of the priuschat forums, i think either fuel economy or modifications.
  18. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    You could just drive it further (like go to your old office, then back to the new one). At 18 miles, your MPG will go up up up!
  19. Abu Garcia
    Abu Garcia Active Member
    726
    42
    Peoria, IL
    I have had my 2011 prius for 3 weeks now and it has 945 miles on it. The first tank i got 47.6 mpg and right now I'm at 49.4 mpg. Real happy so far.
  20. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Hills are a bear for sure. I live in a hilly area and I'm constantly dipping into the power end of the HSI just to get around and keep up with traffic.
    When I am in southern NH or southern ME where the roads are flat my MPG shoots up because I can keep it in the low end of the HSI quite easily.
