What Jack do I use?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Mar 25, 2011.
  1. cyberpriusII
    1,155
    1,764
    Mars Hotel
    So, what jack DO I use for my '08 Prius? The manual clearly states in one of those dire warning boxes in the section about how to change the tire:
    "Do not use the jack that came with your vehicle." (Or words pretty close to that):rolleyes:
    I was in a more than angry mood with hubby -- so mad I was shaking -- so, against better judgment let him drive. So mad, had to do something, so started reading owner's manual. Lots of typos in there -- and then the gem about jack use....
    Actually, does anyone have a recommendation on a "cheap" lightweight floor jack brand. Our's broke awhile back....
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    I bought a combo of 1 floor jack with 2 stands at Sears when it was on sale. Works great so far.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Sounds like a little Jack Daniels is in order...
  4. bisco
    51,851
    not sure what you want to jack it up for. i suppose the tin can one that comes with the car is for emergency use only, but i use it to rotate my tires. i would never climb under the car with that jack or any other for that matter without jack stands.
  5. redrockprius
    redrockprius redrockprius
    167
    30
    Murray, UT
    HUH? The manual I have with my 2007 doesn't say anything remotely like that. How about letting the rest of us know where the manual "clearly" says that (or words close to that)?
  6. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    I believe what they are getting at is that you cannot use the jack that came with the car (which is used at the 4 wheel-specific lift points) to get jackstands in place (because the jack stands use the same points). Therefore, you should only use the supplied jack to change a flat, not to crawl under.
    To crawl under, use a floor jack to lift front, place two stands, lift back, place two stands.
  7. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    While we are discussing jacks and jacking does the Gen. II have a single jack point in the front and rear to be used with a floor jack like how my Gen. III does? I think that that is smart how they integrated the jack points in to the design. Jack up one end insert jack stands on sides at tire changing jack points then repeat for opposite side. Very easy to put up the entire car for maintenance.
  8. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    On pages 423-424 in the Owner's Manual they show how to use a floor jack to raise the vehicle and show the front and rear locations of the jacking points under the car to be used with "floor jacks". They state not to use the scissor jack that came with the vehicle for this purpose as this jack does not have capacity to lift the entire front or rear of the vehicle.
    The scissor jack that came with the vehicle is meant to be used for jacking up one tire at a time for changing flat tires. There are 4 jacking points shown on the sides of the vehicle for this purpose.
    As for a good floor jack, a 3-ton hydraulic jack can be found at Sears, Harbor Freight, Advance Auto or Auto Zone. These are sometime sold in combo sets with two jack stands.
  9. cyberpriusII
    1,155
    1,764
    Mars Hotel
    Ah, you doubt me? :D
    I myself had to read it several times to insure that I was not in an anger-induced haze. :p
    And while they may have INTENDED to infer that one should not use the jack while crawling under the car; that is NOT what they conveyed.
    To an average "idiot" owner like myself it looks like they are saying "never use the jack that comes with the car." ;)
    I might scan the page, later....much later...if that would make people happy, but not sure if I can post it on here, and don't want to read pages of instructions about how to:confused:
    I would still like to know a cheap floor jack possibility. My local tire guru says he can sell me a "slightly used" lightweight racing jack for $80....which seems about $40 too much, although as he says, it's a "pro" quality jack..
  10. bisco
    51,851
  11. richard schumacher
    7,664
    1,046
    United States
    Yep, the Prius owner's manual is not the world's best example of translated technical writing. In comparison the manual for the Honda Civic is a miracle of organization and clarity.
  12. cyberpriusII
    1,155
    1,764
    Mars Hotel
    I must agree with Richard totally about the translations from TechSpeak in the manual!
    First, the numerous misspelled words are unsettling. And the instructions are often unclear. I can NEVER understand the section about resetting the warning light after changing the oil. Tire light is almost as bad.
    I always end up coming here and looking for someone like John's/Patrick's/Richard's(?) translations -- Prius Speak for Dummies -- :D..
    Thanks, guys.
  13. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    The OP has a Gen. II. I was trying to figure if they have the same single front and rear single jack point as our Gen. III's do?
  14. Patrick Wong
    18,200
    6,501
    I bought my 2-1/4 ton Allied Hydraulic floor jack (made in China) from Costco around 20 years ago and it continues to work well. It is not particularly lightweight though, as it is made of steel.
    G2 does not have a single designated jackpoint on the side of the car. However if I wish to raise up one side of the Prius, I will just use a length of 2x4 on the hydraulic jack saddle to spread the load, and lift the car forward of the midpoint with the 2x4 supporting the rail that runs along the edge of the body.
    The reason for lifting forward of the midpoint is that there's more weight on the front of the car. Then jackstands can be placed at the official jacking points to hold up that side of the car.
  15. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
  16. Patrick Wong
    18,200
    6,501
    That is a good choice. Notice however, that the lifting saddle is pretty small. I assume that the handle is going to be shorter than normal, since the jack weighs only 33 lb. So more force will be needed to lift a given load - compared to a normal-sized hydraulic floor jack.
    Here is an alternative jack from the Craftsman line which has a larger jack saddle and a longer handle, both of which I think are more useful for auto repair purposes. However it weighs 3x the other jack.
    Sears: Online department store featuring appliances, tools, fitness equipment and more
  17. cyberpriusII
    1,155
    1,764
    Mars Hotel
    Hey, guys, I do appreciate the jack suggestions.
    However, the last one we had was an allied, IIRC.
    Husband (for the moment) Kevin used it to jack up a tractor he bought and broke it. I guess it was rated one size and the tractor was a LOT bigger. Don't really know.
    I do know that the jack weighed like 49 thousand pounds (well, maybe a little less).
    And even though I am a "fem tresor" I have a lot of trouble lifting the steel jacks.
    The racing one I was looking at is made of <I can't spell this word> aluminium and weighs an appropriate amount. I just don't want to spend $80 for a used jack.
  18. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    ^^^Mahalo^^^
    Howzit Patrick,
    What about the ends front and rear?
    The G3's have two jacking points underneath for use with floor jacks one in the front and one in the rear they are not on the sides. If using those jack points you could lift both of the tires the two fronts or the two rears simultaneously depending on the jack point used. So you can jack either end up place your jack stands on the sides at the appropriate emergency jacking point and then lift the opposite end the place your other jack stands and rotate your tires or change your oil with plenty of room under the car. Here is a pic of me jacking the back end up with rear jack point the front is on ramps and there are jack stands placed at the rear tire changing jack points left/right.
  19. Patrick Wong
    18,200
    6,501
    Well, compare that price to ~$300 for either of these aluminum jacks.
    http://www.sears.com/shc/s/p_10153_12605_00950244000P?prdNo=5&blockNo=5&blockType=G5
    http://www.sears.com/shc/s/p_10153_12605_00970798000P?prdNo=14&blockNo=14&blockType=G14
    Yes, G2 is similar. The rear jacking point is an inverted metal tower while the front jacking point is at the center of the front suspension cross member.
    Looks like something nasty was stuck to your LR tire tread... :D
  20. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Cool it sounds like the G2 and G3 jacking points are very similar if not the same. It was probably a rock in my tire I have a gravel driveway.
