2011 black prius
Discussion in 'Gen 3 Prius Main Forum' started by priusartstudio, Mar 25, 2011.
  1. priusartstudio
    30
    48
    SoCal
    I just realized today that the color of both front and rear bumper is a little bit different color from main body. The body is a bit brownish black, the bumpers are black. Has anyone noticed about this?
  2. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    it is always like that - body is metal, bumpers are plastic...
  3. Hokeysmoke
    Hokeysmoke Junior Member
    76
    Oregon
    The paint needs to be more flexible on the bumpers so it's a different formulation. That said, Toyotas are not known for their great color matching between body parts.
  4. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    It's more of a problem with lighter colors but has been known to happen to black. A forum member with two black Prius reported the same issue with one of them.
  6. dynasty
    dynasty Member
    153
    26
    northern NJ
    I have a 2010 black one and the color looks uniform... you should try to take your car back under warranty and they should replace the bumpers for you.
  7. Tideland Prius
    16,539
    Titanium Silver, Tideland Pearl (greenish grey) and Blue Ribbon Metallic - They all had off-colour bumpers but only when you view it at a certain angle and, at least from what I remember, when it's bright & sunny. I don't notice the colour difference when it's cloudy.
  8. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    good luck with the swirl marks
  9. priusartstudio
    30
    48
    SoCal
    I didn't noticed until my friend pointed out on bright sunny day, of course. I start realizing that the other Toyota car have a slight off color bumpers as well.
  10. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    On my Prius, I notice the bottom rocker panels (or do you call them bottom skirts?) are the most different in terms of color.
    My bumpers match pretty well though.
  11. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    My assumption is that plastic components don't gloss the same as metal, so the color/shine will be different between the two materials. I think this is common among all mfg, but some do a better job of matching then others.
