Scangauge II - What the heck ???
Discussion in 'Gen 3 Prius Technical Discussion' started by revhigh, Jan 19, 2011.
  1. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Hi All,
    Just hooked up my SGII to my new Prius, and it won't stay on. It seems that every time the ICE turns off and the RPM's go to zero, it thinks I'm parking and it powers down after the 10 seconds or so. I know this is what it's doing because if the ICE stays on, the SGII stays on just like it used to in my RAV4. Is there a setting for a hybrid on the SGII ?
    How do I resolve this ?
    Thanks
    REV
  2. markf57
    markf57 Junior Member
    78
    17
    Longmont, Colorado
    You need to change the setting for hybrid.
    From the main screen - MORE>SETUP>FUEL>TYPE - change to hybrid
  3. revhigh
    986
    141
    Thank you ! Thank You ! Thank You !
    I just reset the parameters, but didn't realize there was a hybrid selection.
    REV
  4. gudetime
    gudetime New Member
    long beach, ca
    Whats the scan guage really do?
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    http://priuschat.com/forums/gen-iii...discussion/64406-scangaugeii-work-2010-a.html
    Here is another thread that give information on ScanGauge Xgauges which can monitor things such as: inverter coolant, inverter temperatures, MG temperatures, HV battery Amps, and much more. Xgauge feature can also be used to set the backup beeper to 1 beep vice continuous and turn off the extra Toyota seat belt beeps leaving only the required 6 seconds.
  7. tihsad
    tihsad Junior Member
    93
    So. California
