low budget alternative to backup camera
Discussion in 'Gen 2 Prius Main Forum' started by Bob Allen, Jul 19, 2007.
  1. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    There have been a number of posts from folks wishing they had gotten the backup camera option. When I got HUMU in 2004, the camera was not an option so I looked into an alternative solution. I posted this sometime a few years ago, but now that the backup camera IS an option, and many are regretting not getting it, it might be worth posting again.
    I went to an RV supply store and got one of those stick on Fresnel lenses; the flexible vinyl lens with the "record grooves" cut into one side that gives you very wide angle vision. Using manila folder paper as a pattern, I cut a piece that spans the vertical dimension of the lower rear window glass plus a quarter of an inch more creating a tab that fits into the very narrow slit between the glass and the frame on the lower portion of the rear window and helps hold it in place. You moisten the lens before the final installation and it stays in place indefinitely. Does not damage the defrosting wires. The lens is about eight inches wide and is pretty close to the center of the lower rear window so you can see a normal view on either side of the lens.
    Observations:
    1. You look through your rear view mirror, which keeps your eyes looking out and not at the MFD screen.
    2. The Fresnel lens view is wide enough that you can see an object as close as three feet from the rear
    and quite a bit further on either side. Better wide angle than the camera.
    3. Because the lens is located in the rear window, you also have a normal view juxtaposed with the
    Fresnel view. This is handy for parking and judging distance. Works when driving forward too.
    4. If you are really nerdy, you can do what I did and use the wires in the defroster as a "ruler" to get an
    even more accurate estimate. I used an orange traffic cone and positioned it so that the top touched
    the upper defrosting wire and then measured the distance of the cone from the rear of the car. I did
    this for each of the wires. When an object in my rear mirror view (looking through the lens) is
    bisected by the upper wire it is 25 feet from the rear of the car; the next wire down = 9 feet; next
    wire down is 6 feet and the bottom wire is 3 feet.
    5. When cutting the vinyl lens, make sure the center of the concentric "grooves" lies in the center of
    your paper pattern.
    6. At one time, there were photos of this installation in the photo archives.
    Pakeha_Prius and andyprius like this.
  2. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    Thanks for the write up, this seems much safer and simpler than a rear facing camera!
  3. Mendel Leisk
    41,923
    FWIW, we have the back-up camera, but I do not rely on it: the view is so wide-angle, the adage that "objects are closer than they appear" applies in spades.
  4. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Bob I installed one of these in my Mtr. Home rear window and it worked great but I had a very strong smell in my mtr.Home the following year. Anyway it took me a year or so to discover the soars of the smell. You guessed it, it was giving off a very strong chemical smell. I live in a hot climate and I am not sure if this was the issue or not, but if you get a strong smell check it out! Hal
  5. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Hi Pat, Your replies are always so complete. I guess I will have let my timing light also gather dust. thanks again. :):cheer2: Ignore, Wrong thread. just goes to show that even when Patrick Wong makes no comment, he is also highly Accurate !!!
