Where to find parts? (specifically map lights)
Discussion in 'Generation 1 Prius Discussion' started by Kardinal, Mar 30, 2011.
  1. Kardinal
    Kardinal Junior Member
    Northern Virginia
    I have a 2002 Prius and neither my mechanic nor the usual spots (Advance, the online places I have run across) can find replacement bulbs/lamps for the map lights. Does anyone know a part number or a source for these things?
    Thanks for any help you can give!
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    Super Bright LEDs - Miniature Wedge Base Bulbs
    You want one that puts light forward.
    [edit: actually, 2002 might take a different bulb in the map light. The vehicle cross check is ambiguous. Compare the pictures with the bulb to be sure]
  3. Kardinal
    Northern Virginia
    Thanks for the reply. No, they don't match. The 2002 lights are held in with a metal clip, it seems, and are clearly incandescent, not LED. Any other suggestions?
  4. Corwyn
    2,171
    659
    Maine
  5. Kardinal
    Northern Virginia
    Of course LEDs would be preferable.
    No, they're single-node incandescents. I'll snap a picture later and post it.
    Frankly, looks a lot like this one:
    (Not my photo, just something I found to give you an idea)
  6. Corwyn
    2,171
    659
    Maine
    I'm stumped.
    Take the bulb with you to your local hardware store or auto parts store. See if they can find you a match. Make sure the voltage and wattage match as well.
    Good Luck.
  7. ChapmanF
    18,412
    Have you ruled out the parts counter at a Toyota dealer, or is there none near you? That was what I did when my 2001 needed map lights, and it was pretty quick and painless. I think they charged about four bucks each. I guess that might be more than you could spend someplace else, if you don't account much for your own time finding the someplace else. The part number might be 90981‑12005 according to toyodiy.com (but then, the dealer can usually handle it just fine if you say you've got a 2002 Prius and you're looking for map light bulbs). They won't be LEDs though; if you want those you'll have to find your own retrofit bulb that will fit.
    -Chap
  8. Kardinal
    Northern Virginia
    Thanks, Chap, I guess I instinctively avoid Toyota dealers because I have that "dealer = expensive" mentality. But, of course, if I can't find it online, it seems perfectly reasonable to go where one can get them AT ALL. I will do that.
    BTW, this is what they look like, in case it jogs anyone's memory.
  9. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    Hipstor and Roccobro like this.
