Flexible Waterproof Cargo Liner 2011
Discussion in 'Gen 3 Prius Accessories and Modifications' started by revmelissa, Apr 3, 2011.
  1. revmelissa
    revmelissa New Member
    Fontana CA
    Hello Everyone,
    I use the under floor storage in the cargo area for work so I get in and out of it multiple times a day. I am looking for a cargo liner that is similar to the carpet liner/overlay that came with the vehicle but that is water proof and will not stain as easily as the light colored carpet in the cargo area. I would prefer to have something made to fit the cargo area. I have looked at the various liners on the PC accessory store and they appear to be stiff and not able to be folded over so I can access the storage under the floor. Does anyone know of a water/stain resistant liner that also allows easy access to under floor storage?
    Thanks,
    Melissa
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    You might want to check out the OEM Toyota accessory all weather cargo liner. It is two piece and is reportedly easy to access the under floor storage with it installed.
    Aloha,
    ED
  3. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Here's a better pic ?
  4. PapaGallo
    PapaGallo Junior Member
    58
    22
    nj
  5. FLteacher
    FLteacher Junior Member
    75
    This is what I have instead of the carpet mat. It works great! It is easy to get under and it caught the ounce of coffee I didn't know was in a cup I put in the back.
  6. revmelissa
    Fontana CA
    Thank you all. The better pics and explanation helped alot. I didn't realize the OEM mat was two pieces.
