Eco v Power mode
Discussion in 'Gen 3 Prius Main Forum' started by Garybaldi, Apr 3, 2011.
  1. Garybaldi
    Garybaldi Junior Member
    US
    I just bought a Prius IV and the sales man told me that Eco & Power modes consume the same amount. Is it true from your experience?
  2. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    From my experience having put 11,000+ miles on my Prius. Eco will give you the best mileage...it is only a minor difference........but it's there.
    Eco causes you to move the fuel pedal more then Power does, Power will give you the top performance of the ICE & EV combined. In performance I talking about more speed & power to the wheels.
  3. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    If you drive very aggressively they will be the same. For everyone else Eco will give better fuel economy, for a number of reasons. Have a search and you'll find lots of threads about it.
  4. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    More or less true. Virtually all of what they do is just recalibrate pedal response. ECO is trivial. I drive in neither one and "normal" FWIW.
  5. Exponent
    Exponent New Member
    22
    Kansas City
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Try the following as a guide;
    Eco - town/city
    Normal - Open road/Highway
    Power - Overtaking or fun :)
    Eco assists you to be more economical, Power assists you past that slow car.
  7. davesrose
    davesrose Active Member
    767
    164
    Atlanta
    I usually stay in normal mode myself. There are slight differences with each mode: most of it is the accelerator, but there is also a difference with A/C. I think the accelerator differences between Eco and Power are more important when you're getting used to the car. By now I've gotten used to mine so that I can just "gun it" whenever I need (no matter what mode). As for MPG, I think it's more about your own habbits then what mode the car is in (practicing "hypermiling" will give you the best mileage).
  8. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    I might recommend:
    Eco: When you need fine control at low gas pedal depression. Stop & go; Pulse & glide.
    Power: When you need fine control at high gas pedal depression, or max climate control.
    Normal: if you want consistent gas pedal response, and never change modes.
    Alternatively,
    Eco: When you want to believe you are being environmentally friendly.
    Power: When you want to believe you are being sporty, powerful, macho.
    Normal: ...
  9. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    I seldom drive in anything but ECO. I notice 3 things, gradual, linear starts make starting on slippery roads much easier, the A/C seems less powerful in summer and Cruise Control doesn't make the ICE rev up on hills ( I actually slow down a few miles per hour on uphills). I have had nearly 2 years and 25000 miles. My total average is 54.1 mpg (calculated) and when the weather is really warm I can push to nearly 70 mpg for a tank of mostly city driving. I'll stick with ECO rather than the risky hypermiling techniques.
    Needless to say I'm very pleased with my Prius.
  10. ETC(SS)
    7,139
    Greetings and Welcome Aboard!
    :welcome:
    A previous poster gave you all the high points, and a link to get there. Nothing to add to that except to say that I started off in ECO mode and got used to the throttle in that mode. The difference is indeed minor---but I'm used to the throttle response (or lack thereof) in that mode.
    If you drive like a teenager---you're only gonna get about 45MPG---but you'll still be getting 45, as opposed to like....15 in a truck. (Been there....done that! :D )
    Good Luck!
  11. guinness_fr
    guinness_fr Junior Member
    68
    france
    Not really true IMHO, I noticed that when driving with the HSI bar just below the "O" of ECO, when I run in ECO the ICE seems to provide around 80nm/ft of torque while it provides only 60nm/ft in Power mode, so I'm assuming that Power also changes the amount of torque provided by the electric motors.
    This would make sense as the electric motors can provide a lot of torque very quickly which is what you want the Power mode to offer.
    The difference in MPG of doing this is probably not much but there must be a difference in favor of the ECO mode I guess.
  12. Skoorbmax
    2,641
    265
    Western NY
    But you even say "probably not much". These threads pop up all the time, I mean like every week, and I've not seen a convincing graph, only many many anecdotes talking about it, but nothing that truly compares ECO vs PWR vs NORMAL in the same conditions over enough miles to be statistically meaningful.
  13. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    It could be that the Prius also remaps the HSI bar in ECO vs PWR.
    It definitely remaps the bar for EV.
