Dashboard Display Brightness?
Discussion in 'Gen 3 Prius Technical Discussion' started by rehillini, Apr 3, 2011.
  1. rehillini
    rehillini Senior Member
    49
    Urbana, Illinois
    Just took delivery of a 2011. Is there any way to increase the DAYTIME dashboard display brightness?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Use the dimmer to the left of the steering column, rotate it up. If it clicks, then even at night you'll remain in brightest daytime mode. If you have it set to max right before the click, it'll switch over to night mode when the lights are turned on and reduce intensity on the dash lights.
    Pat Chlop likes this.
  3. airgas1998
    airgas1998 New Member
    78
    iowa
    assuming you have the dimmer already jacked up all the way, and the headlights off it will go no brighter than this.
  4. davesrose
    davesrose Active Member
    767
    164
    Atlanta
    What Paradox said: if you rotate the dial past the "click", you'll see the brightness will jack up quite a bit. I usually stay in "daylight" mode with the brightness dial....but sometimes I'll turn the dial down if I'm driving at night and want the NAV screen to switch to night mode.
  5. Hokeysmoke
    Hokeysmoke Junior Member
    76
    Oregon
    This is one thing I miss from my prior car (built in 1994) - an ambient light sensor. The bright position of the dimmer is too bright for nighttime driving (too much glare off the windshield) but the setting just before the click is too dim for daytime driving.
  6. RRxing
    RRxing Senior Member
    2,541
    1,816
    NEPA
    The default brightness for the meter, nav system, and instrument panel is 0 (zero), but can be adjusted by the dealer from -2 to +2.
  7. rehillini
    49
    Urbana, Illinois
    Let me clarify: If the headlights are OFF, it does not make any difference where the "headlights on" dash dimmer control is positioned (it can be all the way down); the dash lights will always be at maximum brightness. That is the brightness I would like to increase.
    Since I do not have the "Nav" feature, I am not sure if the "-2, 0, +2" adjustment is applicable. Does that just apply to the sensitivity to determine when the brightness changes?
    Thanks for your comments.
    I will check with my Dealer Monday.
  8. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Do you wear sunglasses......is this why you need it brighter. ???
  9. rehillini
    49
    Urbana, Illinois
    No sunglasses.
  10. davesrose
    767
    164
    Atlanta
    I'm not sure what you're saying here. The headlights just has two settings: regular beams and high beams. Both of which are dictated by the stick on the left of the steering wheel. The dash/instrumentation dimmer is a dial to the left of that (on the actual dashboard) on the lefthand side of the driver's control set. The only thing this dial does is adjust the instrument's brightness setting (it doesn't effect the headlights).
  11. rehillini
    49
    Urbana, Illinois
    I said nothing about the brightness of the headlights. I am talking about the dash (instrumentation) display brightness. Notice the thread title?
  12. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    I will check with my Dealer Monday.[/QUOTE]
    Please let us know what your dealer does to help you out.
  13. rehillini
    49
    Urbana, Illinois
    Went to the dealer this morning and had the Reverse beep changed to the single beep mode. However he said that there was no Customization to increase the daylight brightness of the dash lights.
    By the way, no charge for the change of the Reverse Beeping. [​IMG]
  14. Pat Chlop
    Pat Chlop New Member
    Frederick, MD
    Thanks for this instruction. My son was in my car and changed the dimmer and the manual did not help.
