80 mpg! Nitrogen Works ;)
Discussion in 'Gen 2 Prius Fuel Economy' started by SageBrush, Apr 5, 2011.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Car taken to Costco for tyres rotation, fuel and shopping (combing trips is a mantra in my house.) Trip back home is 11 miles and 367 meters up, that returned 45 mpg on the scangauge. If my arithmetic is correct this is 76 - 80 mpg. I used 1365 kg as mass and assumed 35% engine efficiency. SOC was one bar lower, estimated at 0.2 kwh. Matches my best ever round-trip result.
    Must be the nitrogen in the tyres ;)
    Ah, addendum: the SOC delta has to be divided by 0.35, equal to 0.571 kwh of petrol and not the 0.2 kwh I put in the calc. I barely scraped 74 mpg :( Bloody Nitrogen.
  2. Mark57
    2,945
    2,738
    OK
    You didn't give yourself any credit for operator skill. ;)
  3. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Tyres? Where are you located?
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Tyres, a bit south of Birmingham lad!!!
  5. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Oh ok... do they tax vehicles based on engine displacement in the UK?
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Put twice as much N2 in and see if you get twice the improvement.:D
  7. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Wait 'til you try helium. ;)
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    Now THAT is one heck of an idea. I know you jest -- but why not ? Maybe the volumes are too small to matter ? You also would have to replace losses much more frequently.
    <<<<Qbee>>>>>
  9. FreydNot
    FreydNot Member
    216
    37
    Seattle, WA USA
    Hydrogen is the bomb!
  10. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Nice ride, Sagebrush.
    I think everyone's on to something brilliant. Fill the cabin of the car with helium, wear an oxygen mask. 100 mpg for everyone.
  11. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    If it works for cars, it should be even more effective on airplanes, right? Imagine how much fuel could be saved!
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I filled the cabin of my car with 80% Nitrogen and also 20% Oxygen so I won't need an Oxygen mask. It's great combination, I recommend it.
  13. qbee42
    3,079
    I wonder if you would get a higher pitched tire noise?
  14. mikewithaprius
    656
    103
    Rhode Island
    :p
    Brilliant! It's important not to be too airy but rather err on the side of caution, so best that you put in a little O, too. I will attempt N let you know how it goes.
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I would highly recommend O2 and N2 instead of O and N.
  16. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I have no idea why you think it's the Nitrogen in the tyres. I just use cheap air (which does have quite a bit of Nitrogen in it!) and managed 80 mpg on a run of 16 miles from Harrogate to Leeds center. There was a nice slope down into the city as you can see :)
    This is 80 mpg UK which is about 65 mpg US.
    You just have to drive nice and steady. If I can do it anyone can!
  17. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I like to eat Mexican food before I drive. That way I'm full of gas and therefore lighter. As a bonus, the Prius cabin is filled with lighter CH4. It improves MPG and I swear I get an extra 3.14% boost out of it.
    The only thing is the my Prius no longer qualifies as AT-PZEV.
  18. Nandros
    Nandros Junior Member
    44
    Lechaio Corinth, Greece
    Must be the nitrogen in the tyres ;) DEFINITELY NO!
    Earth's atmosphere contains roughly (by molar content/volume) 78.09% nitrogen, 20.95% oxygen, a variable amount (average around 0.247%, National Center for Atmospheric Research) water vapor, 0.93% argon, 0.038% carbon dioxide, and traces of hydrogen, helium, and other "noble" gases.
  19. Nandros
    44
    Must be the nitrogen in the tyres ;) DEFINITELY NOT!
  20. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Earth's atmosphere is 79% nitrogen, 21% oxygen, plus some trace gases. Putting pure nitrogen inside the tires is nice, but it does nothing to change the mass of the vehicle. In effect, nitrogen inside tires has little or no effect.
