Finally, First Post
Discussion in 'Newbie Forum' started by luv_mist, Apr 8, 2011.
  1. luv_mist
    luv_mist New Member
    Maryland
    Well, I finally got around to getting a solid look at this site. Pretty solid information around. I own a 2008 Prius. It's still a great car. Trying to become more independent in servicing my own car for the easy to do things. I think my warranty might be done soon. I'm planning on changing the light bulbs seeing that the passenger side is on its last legs. Already got pulled over by the cops. I was considering doing an HID conversion kit but I'm still reading up on it a bit. I'm assuming that doing any work shouldn't be that hard. I'm even more confident to be apart of a site that seems open to suggestions and giving proper solutions. Definitely plan on using the knowledge and information on this site to make my Prius ownership more pleasant.
  2. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Wekcome to PC!
    (I wouldn't start with changing headlights if I were you) :)
  3. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Welcome, welcome!
  4. Mark57
    2,945
    2,739
    OK
    Welcome to the site!
  5. bisco
    51,529
    :welcome: i have an 08, but havn't been pulled over yet.:D
  6. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    Just about Everything you need to know is Here!
    PriusChat is a better place:nod:
  7. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Welcome to PriusChat. I'm sure you've lurked about long enough to know that the forum offers lots of tips, tricks and advice. See you around.
  8. Whitney09
    Whitney09 New Member
    india
    Thanks for the update
  9. compac
    compac PSU, Metallic Blue Ribbon
    52
    VA, Blue Ridge mtns
    Lurkers welcomed, lots of great info...:rockon:
