1. kenfl2001
    kenfl2001 New Member
    I have an '05 and live in Florida. I've heard various reports on the OEM tires. Rain and high temps are more of an issue here. Just how dangerous are the OEMs and should I replace them now and not be penny-wise and dollar foolish (they have about 8K miles on them now).
    What are the recommended tires for Florida drivers?
  2. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    I'm quite a ways from Florida, but I have driven in the heat and in the rain. I did have the tires spin once while accelerating from a dead stop.
    Personally, I'd keep the tires. I've purchased snow tires for winter use, but will go back to the OEM's once the winter is over.
    So, while you could get better performing tires, you also should do just fine with the OEM's - replace them once they wear out if you find you are unhappy with them. I'd also ask - How have you found the tires over those 8k miles? You should really be able to answer the question yourself, since 8k miles is a significant trial period :)
  3. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    Dangerous???? Any news stories out there about crashes due to the tires, a la the Firestone fiasco?
    Dangerous????? Methinks you are either reading bad info or not reading ALL the info. The OEM's are fine tires, some people just want better (there are always better things out there)
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    The Integrities are a popular tire available on many car models. They're not "dangerous" if you drive in a half-way reasonable manner. They're just not a 'great' tire.
    I think it's probably dollar wise to drive the OEMs for 20-30k miles and as soon as you think they look a little too worn or notice handling/slippage issues change to something better.
    That said, some have been able to get their dealers to give them reasonable exchange prices for the OEMs right up front. If your dealer will do that then go for it. Also, if you have a tire dealer you usually use you might ask them the same thing...how much to trade in brand new Integrities for some Comfortreads (or whatever).
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    I think the OEM tires are not nearly so bad as some posts might lead you to believe. Of course it may depend on how old you are, when I learned to drive I was lucky if 1 or 2 tires out of the 4 had tread on them, and there were no radial tires except Michelins which most people couldn't afford.
    I find the Prius equiped with VSC (I've never driven one without VSC) is a very hard car to get in trouble with. The springs are to soft and there is to much understeer to do well in an autocross, although I wish someone would give it a try. But for more or less normal street driving it's just fine, even with OEM Goodyears. It's very dependable and it won't surprise you, if you totally blow it and go off the road I think it will, at least, do it the same way each time.
    I plan on putting 30 or 40K on the OEM tires, when I replace them I will put on a set of all season performance tires such as RE092s or RE950s. I should add that if we get very much snow this winter I'll drive my 4WD pickup.
  6. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    <_< I plan to drive the OEM's as long as I can safely. At 13,000+ miles they show minimal wear and I have had no traction issues. I do run them at 40/38 psi for the slightly better fuel mileage.
    Other thoughts: I keep a 12v compressor and high quality analog tire gauge aboard to check and maintain tire pressures regularly (about every 2-3 weeks when I hand wash), and I rotate every 5,000 miles per the Owner's Manual.
  7. kenfl2001
    Thank you all for your responses. My wife drives the Prius mostly and she's a cautious driver to begin with. I must admit that we (me) are more vigilant than usual because my wife is pregnant and we are not taking any unnecessary chances with anything we can control.
    I will wait until there is reasonable wear and then replace them. Any recommendations for Florida driving?
  8. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    The only thing that's going to hurt your fuel efficiency in FL is the heat. As I'm finding, now that I'm not using heat or AC, my fuel efficiency has been getting above 50. Last fillup was MFD 54 and calculated 51. Currently my MFD is still 54. So going by what I saw before and now, I'm seeing a 2-4mpg difference between AC and no AC.
  9. 200Volts
    200Volts Member
    439
    46
    Northern CA
    Ken,
    Keep your tire pressures up to reduce hydroplanning, replace your foglight bulbs with the same wattage-but higher color temperature(bluer) and use RainX on your windsheild.
  10. tochatihu
    tochatihu Senior Member
    9,740
    3,757
    Kunming Yunnan China
    2001 Prius
    [attachmentid=788]
    ...and don't drive through deep water!
  11. Frank Hudon
    Frank Hudon Senior Member
    4,147
    what the hell were they thinking? :blink:
  12. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    I'd guess they weren't :eek:
    I actually had that experience when snowmobiling. One weekend, the water was 2 inches deep and we went right through. The next weekend, apparently beavers had built a dam, the water was a bit deeper and I kept thinking.. "it's gotta start leveling out, right?". It didn't. I stopped when it started getting closer to the engine - no harm done, other than my feet got soaked.
    I'd guess in their case, they didn't drive though the week prior with just a few inches of water. :)
  13. Strong Bad
    Strong Bad New Member
    Autocross?....here ya go...
    [Broken External Image]:http://img231.imageshack.us/img231/3874/priusphotoshoot1010050063sp.jpg
    [Broken External Image]:http://img231.imageshack.us/img231/5740/priusphotoshoot1010050889gv.jpg
  14. Wynder
    Wynder New Member
    254
    Bear, Delaware
    While those pictures are pretty sweet looking... Wth is the point of all that? ;p Do people actually pimp out the ICE to squeeze out an extra 10 or 15 horses?
  15. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I heard a piece on NPR about people who race snowmobiles on water. I mean deep water,
    across rivers! Not just in a straight line either! On lakes over a circular track. They keep a
    diver on call to fetch out anyone's snowmobile that gets sunk. Apparently it works if you keep
    going fast enough! Who a thunk it!
