2001 Prius battery problem...replace cells?
Discussion in 'Generation 1 Prius Discussion' started by lutung, Jul 26, 2007.
  1. lutung
    lutung New Member
    I have heard that it is possible to replace the individual cells in the hybrid battery. Is this true?
    If so, if anyone knows of a place in the central florida area that can test the cells and replace them,
    I would be forever in your debt : P Other than the Toyota dealer in Gainesville. They are trying to
    charge $3000 for a whole new battery! I heard they can be replaced for around $100 a cell.
    Thanks!!!
  2. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(lutung @ Jul 27 2007, 10:38 AM) [snapback]485867[/snapback]</div>
    IMHO, I don't think so.
    Regarding to my experience about NiMH and NiCd battery, they are connected in series and should have matched characteristics, such as manufacturing lot, ages, internal resistance and so on.
    http://www.tjcells.co.uk/prod.htm
    Ken@Japan
  3. Joekingiam
    Joekingiam Junior Member
    59
    Akron, Ohio
  4. bwilson4web
    16,252
    <div class='quotetop'>QUOTE(lutung @ Jul 26 2007, 08:38 PM) [snapback]485867[/snapback]</div>
    Ken is pretty accurate about the battery and trying to replace individual modules. This is not an 'off the shelf' item. Now if you have an engineering friend handy with the right set of tools, it might be possible to rebuild a battery pack but it would be pretty expensive labor.
    BTW, I saw an Ebay vendor with a battery pack for shipping for about $1.4k earlier this week, which might be another alternative. Of course you'd have a hard time getting the local Toyota dealer to install it.
    I snagged a battery from a salvage but I plan to do my 'electrical engineering' tricks and make sure the cells are in good shape. Nothing gets changed until I test them all but then, this is my fun and not a business. Just something I like to do.
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Obviously, sooner or later someone is going to combine cells from different HV batteries and post the results.
    Unfortunately, too much will be made out of the success or failure forthcoming. A couple of notes:
    Submarine battery experience (and there is a lot of that) show that individual cells wear out at different rates due to location in the pack (the edge cells are cooler than the middle cells). At low SOC, the higher performing cells in the pack start "charging" the lower performing cells all the time. To prevent problems, these cells are jumpered out individually till it is time to replace the entire pack. The HV batteries in the Prius are very long lasting, but they do wear out at some point, and one of the mechanisms will be increasing differences in the cell capacities. So I forsee the following:
    1) Someone combines cells and is absolutely dogged by SOC variations and constant TOD failures or,
    2) Someone gets lucky and has a combination that works (at least till they post).
    Submarines do replace individual cells, but after matching for similar ages in other cells. So this can be done with the right equipment and knowledge. (i.e. It is better than recycling if only a few cells are very bad). Otherwise just randomly combining cells is assured of having quite a few problems.
  6. tkeeler
    tkeeler New Member
    Durham, NC
    2001 Prius
    Dealer just told us our 2001 had one bad cell and wants $3000 for new battery. Wish there was a cheaper option.
  7. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
  8. mattetezal
    mattetezal New Member
    toronto
    2001 Prius
    I have just replaced the whole pack for my 2001 Prius, cost me $4400 after tax and labour, owch! My old battery had one malfunctioning cell I have the whole pack with me and willing to sell it unit by unit, if you know someone who needs a cell let me know, Thanks,
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
  10. 1stgenpriusowner
    1stgenpriusowner Junior Member
    S.E. Wisconsin
    2001 Prius
    Could you contact me about the battery cells you have? thanks
  11. mattetezal
    toronto
    2001 Prius
    Hi I am sorry that I was not online foe a while. Tell me what you want to know about the old battery pack that I have.
    I have left it in a box at my mechanic's. Cell number 4 was reported to be malfunctioning the rest are fine.
    I am located in Toronto Canada my e-mail address is [email protected]
    If you still haven't solve your problem , drop me a line now.
    Thanks,
    m@
  12. mattetezal
    toronto
    2001 Prius
    Sorry for the delay... I did not visit this site for a while.
    The battery pack is located in Scarborough, Ontario, Canada.
    It is very heavy. I am willing to sell the whole cell at once. The price is $600, however I have no idea how much it cost to ship it to your location.
    My mobile is (416)388-9644 I live in Toronto Canada (Eastern Time) If you need more info call me ... Thanks
  13. hybridtech6
    hybridtech6 Tyler
    MN
    2001 Prius
    They can be rebuilt just visit hyridbatteryrebuild dot com
    They give you an in depth guide on how to do it.
  14. illfetchit
    illfetchit New Member
    connecticut
    i have just swapped cells from a few first generation prius with cells from two third generation batteries that cost just over $300 a piece. the whole process ended up costing me under a thousand dollars and i was successful every time. If you are mechanically inclined in any way i can give you a link.
  15. Joyecca
    Joyecca New Member
    New Ellenton SC
    2001 Prius
  16. Joyecca
    Joyecca New Member
    New Ellenton SC
    2001 Prius
  17. Kinsemfarms
    Kinsemfarms Junior Member
    North Carolina
    Can you send the link, please. Looks like my '05 will is down 2 cells.
