48÷2(9+3) =
Discussion in 'Fred's House of Pancakes' started by Presto, Apr 13, 2011.
  1. 288
    18 vote(s)
    42.9%
  2. 2
    24 vote(s)
    57.1%
  1. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    288? 2? What do you get?
  2. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    PEMDAS, man, PEMDAS!
  3. silentak1
    silentak1 Since 2005
    893
    28
    LA
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Why think, when you have Google ? Google says it is equal to
    (48 ÷ 2) * (9 + 3) = 288
    The rule, however, is left to right for operations of equal precedence unless parantheses tell you to do something else.
  5. qbee42
    3,079
    Correct. You do the addition first, since it's in the parentheses, which gives you 12 at that point. Then you go back and do the division and multiplication from left to right, since it has equal precedence.
  6. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Well, that's scary.
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    288 too. And I suck at math but remembered do the ( ) first then the rest.
  8. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    In Excel, if you do in a cell : =48/2(9+3)
    At first it complains, expanding it to: =48/2*(9+3)
    Then gives 288.
    This would also be :
    a / b (c+d)
  9. mikewithaprius
    656
    103
    Rhode Island
    I must admit, I need another explanation. If it were (48/2)(9+3), of course it's 288, but as written I see 48 over 2(9+3). Go math folk, explain :)
  10. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Like I said, I don't know math for squat, but to have 48 over everything wouldn't it need to look like this? 48÷(2(9+3))? Probably wrong, but trying to make myself proud if right lol.
  11. Presto
    1,326
    24
    Vancouver, BC
    BEDMAS
    It's a one-line equation, and I purposely used a division symbol, and not a slash, as a means of clarifying it.
    If you work through it with the standard BEDMAS convention, you'll get 288.
    48/2(12) <---figure out the stuff inside the brackets, first.
    48/2(12) <----divide 48 by 2 (multiplication and division are the same priority, so you work it left to right)
    24(12) <---- multiply
    288 <----answer
    If you want to specify it with a fraction, then this is the correct formula:
    48 * (9+3)
    To get:
    48
    2(9+3)
    The equation needs to be as Paradox specified: 48÷(2(9+3))
  12. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    This is harder than regenerative braking divided by 1000kw times MPGs! eeek....:eek:
  13. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    How is this difficult? :huh:
    I learned this in 6th grade. It's 2.
  14. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Is that your final answer?
  15. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
  16. bisco
    52,292
    fourth grade, it's 288.
  17. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    As a contrary voice, you can go to a site like:
    PlanetMath: order of operations
    There you get multiplication prior to division. So that approach gives 2.
    Likewise, if you buy 1,000 beers in Europe, how much have you drunk?
  18. mikewithaprius
    656
    103
    Rhode Island
    I still disagree. For those telling me I should check my 4th grade math (bisco!! :p), I did get a 780 on the math part of the SAT back in the day :D
    It's irrelevant that's it's written in one line. The division sign in general is a visual representation of what it stands for, not just two dots and a line. The top dot represents the top value of a fraction, defined by the value found prior to the division sign, the line is of course "divided by", or the fraction line, and the bottom dot the value following it.
    Furthermore, parentheses imply a "doing out" of all attached to those parentheses (or brackets, for those using that terminology). The 2 in the problem is a coefficient in this case. This supersedes the left to right stuff. Another way to think of this is 48÷2x, where x=9+3. In that case it's quite clear you would never do the division first, and that's what we have here.
    If you had written 48÷2*(9+3), it's different...but you didn't! Answer is 2.
    Found some extra reading - you can see a TI calculator will compute that as 2, unless you separate (9+3) from its coefficient.
    The Order of Operations: More Examples
  19. Presto
    1,326
    24
    Vancouver, BC
    Calculator, you say?
    Depending on the model, it may prioritize implied multiplication over regular multiplication. So instead of seeing 2(x), it may treat it as (2x)
    Let's look at the equation a different way. Forget the division symbol, and we'll express it as a multiplication operation by multiplying the inverse of 2, instead of dividing it:
    4*½(3+9)
  20. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    Not according to Wikipedia:
    "Similarly, care must be exercised when using the slash ('/') symbol. The string of characters "1/2x" is interpreted by the above conventions as (1/2)x. The contrary interpretation should be written explicitly as 1/(2x). Again, the use of brackets will clarify the meaning and should be used if there is any chance of misinterpretation."
    I believe that if there were some unambiguous convention in that regard Wikiedia would record it, but all I've been able to find is that juxtaposition in lieu of an explicit multiplication operator while common and accepted practice is NOT unambiguously assigned precedence over conventional computation sequence.
    I for one try not to take chances and use parentheses prolifically. They don't cost anything and they eliminate arguments.
