2006 Prius, "ready" light not coming on and no start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by autotech1100, Apr 16, 2011.
  1. autotech1100
    autotech1100 New Member
    North Ga
    Hi everyone, I have a 2006 Prius that is giving me fits. The car is equipped with the smart key but it seems to be working normally. I insert the key, press the brake, and then press the power button like I am supposed to but the "ready" light doesn't come on and the car won't start. I checked the brake light switch and it is working correctly. 12v battery is charged and shows 12.35 volts. I have been tinkering with the car for the past three days and have only gotten the light to come on and the car to start twice out of the numerous tries. The last time it started the dreaded "triangle" and check engine light were on so I plugged my scanner in and got code P0A1F, I had a spare battery ECU so I replaced it, while I was at it I removed the battery and cleaned the terminals, there was only a very small amount of light corrosion on a couple of cells. All cells tested good and had uniform voltage. I haven't gotten the car to start since putting everything back together. I have a small amount of experience with these cars but I've got alot to learn. If anyone could offer any advice I would greatly appreciate it!
  2. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    I never saw this, but the manual says:
    P0A1F-123 Battery Energy
    Control Module
    Abnormal
    signal input
    from battery
    ECU (ROM/
    RAM
    malfunction)
    - HV battery
    system
    - Battery ECU
    Comes on Comes on DTC stored ​
    HV-177
    P0A1F-129 Battery Energy
    Control Module
    HV battery
    voltage circuit
    malfunction
    - HV battery
    voltage circuit
    - Service plug
    grip
    - High voltage
    fuse
    - Battery plug
    - Battery ECU
    HV-179
    P0A1F-593 Battery Energy
    Control Module
    IG2 signal
    circuit of battery
    ECU
    malfunction
    - Wire harness
    or connector
    - Battery ECU​
    HV-183
    So, it you changed the ECU and still have the problem, it could be a harness issue.
  3. autotech1100
    North Ga
    Thanks for the quick reply vertex. I think the car has 2 problems but one is hopefully fixed. Stupid me evidently didn't get the service plug in the battery pack fully seated. I got it to start awhile ago and the check engine light is now off , my scanner shows no pending codes or freeze frame data. The hybrid system seems to be working correctly and the hybrid battery seems to be charging just fine per the monitor, although the "triangle" and yellow "!" are still on. With the smart key I hit "lock" and then "unlock" twice and after doing that I was able to get a ready light and the car started. I let it run for awhile and drove it around the parking lot. Now after powering down it won't start again, even if I do the lock and unlock cycle. Any advice is appreciated!
  4. Patrick Wong
    18,200
    6,500
    1. I suggest that you disconnect the 12V battery for several minutes, then reconnect. This will clear any DTC logged by the hybrid vehicle and traction battery ECUs. Maybe the car will start but if problems remain, the DTC will come back.
    2. If by yellow "!" light, you mean the amber ((!)) warning light, that is a brake system light produced by the skid control ECU. Apparently your car has a problem in that area. The skid control ECU DTC will not clear by disconnecting the 12V battery, but I have previously posted on how to clear DTC by using a jumper wire on the OBD-II connector.
    3. If you manage to make the car READY again, check the traction battery state-of-charge gauge in the MFD. If it is getting low, then you should force-charge the battery by putting the gear selector in D, holding the car stationary by pressing the brake pedal with your left foot, then flooring the accelerator pedal with your right foot. This will force the gasoline engine to spin MG1 in the transaxle, which will provide power to the inverter to charge the traction battery.
  5. autotech1100
    North Ga
    Thanks for your advice. I did have the 12v battery disconnected but not since I discovered my mistake in not having the service plug fully seated. I'm going to leave the battery disconnected overnight and see what happens. I will clear the skid control DTC by your method. I actually just did what you suggested about the battery. It showed that the traction battery had just over a half charge. I got it to fully charge using the method you described, afterwards I drove it around the parking lot a few times and it ran great other than the warning triangle and amber warning lights staying on.
  6. autotech1100
    North Ga
    Well, the problems continue. I reconnected the 12v battery this morning and the car immediately switched to ready and fired right up. After about 5 seconds the dreaded triangle light came back on. Hybrid system seemed to be working fine and charging correctly. I turned the car off and tried to restart it and got nothing, no ready light and no start. The check engine light never came back on and my cheapo actron scanner showed no codes. I disconnected the battery again and this time after reconnecting it the car still won't go into ready mode, but I did notice the triangle didn't come on this time. I really do appreciate all of the help so far from everyone here!
  7. autotech1100
    North Ga
    Update: After trying numerous times I finally got the car to boot. After about 15 seconds of idling in park the triangle light came on and my scanner read code P0AA6, Hybrid battery negative contactor circuit stuck closed. After seeing this I decided to go for a drive, I drove the car about 3 miles down the road and it did great but the triangle stays lit. Aaaaaarrrrrrrggggghhhhhhh!!! Now I'm almost scared to power the car down because I know what will happen!
  8. Patrick Wong
    18,200
    6,500
    DTC P0AA6 means that there exists a high voltage ground fault. The three digit INFO code will help to narrow down the location of the fault. The car will refuse to restart, after this code is logged.
    Besides the master warning red triangle light, what other warning lights or MFD warning icons/messages showed up?
    If your OBD-II scanner does not pick up the three-digit INFO code associated with the DTC then you'll have to have a Toyota dealership retrieve it, or else invest in Techstream Lite.
    https://techinfo.toyota.com/techInf...hinfo/html/prelogin/docs/tsliteflyertinfo.pdf
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    Please tell us, is this a customer's daily driver, a trade-in/auction/wholesaler purchase, or a salvage rebuild? There is a particular combination of subcodes for P0AA6 (526 + 613) that indicates a transaxle failure. Getting the secondary codes read would be very helpful.
    Keep that 12V on a charger, it may not be getting any juice from the DC-DC while the code is set.
    Please compare the picture below to your HV battery connection, just in case something is missing.
    EDIT: As far as the relays go, start by having the 12V disconnected for 5 minutes. Then connect the 12V, put foot on brake, and press the power button. In between pushing the button and seeing Ready, you should hear three clicks, corresponding to the system main relays.
  10. autotech1100
    North Ga
    Patrick, my Actron only shows the one code, it doesn't show any info codes. I am calling some other shops to see if they have anything to scan it with but so far when I mention that I am working on a Prius they tell me no. Besides the triangle the only other light is the amber ( ! ) and they both pop on at the same time . I know you mentioned earlier that it was a skid control fault, I haven't tried resetting it as of yet. Any chance that could cause the P0AA6? Seilerts, this car belongs to a dealer who bought it at an auction. I did fully charge the 12v on Thursday, it was almost completely dead. It seems to be holding up well but I will charge it again tonight. The connections are the same on my battery as the one you pictured, I double checked that to make sure. I have learned that if I disconnect the 12v battery and pull the service plug from the hybrid battery for a few seconds and reconnect them the car will go into ready mode and start, after a few seconds the triangle and ( ! ) come back. I drove the car about 5 miles with no problems but as soon as you shut it down it won't go back into ready mode unless you disconnect both batteries again. Thanks again to all of you for the help!
  11. vertex
    672
    144
    new york
    2018 Prius Prime
    Here is the description for your code:
    P0AA6-526 Hybrid Battery
    Voltage System
    Isolation Fault
    Insulation
    resistance of
    high voltage
    circuit and body
    is low
    - Frame wire
    - System main
    relay
    - System main
    resistor
    - HV battery
    assembly
    - Electric
    inverter
    compressor
    - Battery ECU
    - HV transaxle
    assembly
    - Inverter with
    converter
    assembly
    - Main battery
    cable
    - No. 2 main
    battery cable
    - Battery plug
    - No. 2 frame
    wire
    - Junction block
    Comes on - DTC stored ​
    HV-421
    P0AA6-611 Hybrid Battery
    Voltage System
    Isolation Fault
    Insulation
    resistance of A/
    C compressor
    motor or A/C
    inverter is low
    - Electric
    inverter
    compressor
    - Inverter with
    converter
    assembly
    HV-421
    P0AA6-612 Hybrid Battery
    Voltage System
    Isolation Fault
    Insulation
    resistance of
    HV battery,
    battery ECU,
    system main
    relay, or system
    main resistor is
    low
    - HV battery
    assembly
    - Battery ECU
    - System main
    relay
    - System main
    resistor
    - Main battery
    cable
    - No. 2 main
    battery cable
    - Battery plug
    - No. 2 frame
    wire
    - Junction block
    HV-421
    P0AA6-613 Hybrid Battery
    Voltage System
    Isolation Fault
    Insulation
    resistance of
    HV transaxle or
    motor and
    generator
    inverters is low
    - HV transaxle
    assembly
    - Inverter with
    converter
    assembly
    HV-421
    DTC No. Detection Item DTC Detection
    Condition
    Trouble Area Master
    Warning Light
    MIL Memory See page​
    P112 HYBRID VEHICLE CONTROL ​
    – HYBRID CONTROL SYSTEM HV–79
    HV​
    P0AA6-614 Hybrid Battery
    Voltage System
    Isolation Fault
    Insulation
    resistance of
    motor and
    generator
    inverters, A/C
    inverter, system
    main relay,
    system main
    resistor, or
    frame wire is
    low
    - Frame wire
    - System main
    relay
    - System main
    resistor​
    HV battery
    assembly
    - Inverter with
    converter
    assembly
    - Main battery
    cable
    - No. 2 main
    battery cable
    - Battery plug
    - No. 2 frame
    wire​
    - Junction block
    As Patrick said, he info code will help narrow down which fault you have.
    The HV battery pack is an area that is inspectable. You could pull the covers off, and look at the wiring on the sides of the packs. If some moisture got in, or a cell leaked and caused corrosion, it could cause this problem, and could be visible. As long as the problem is not the transmission, it is not to bad to fix. If it is the battery pack it may still be under warranty.
  12. autotech1100
    North Ga
    Looks like I may have to take it to a dealer to learn what the info code is. I called a few shops around here and the common response was "We don't work on hybrids". I've been doing light to moderate repair jobs for years and the Prius doesn't seem so bad to me for the most part. A couple years ago I did a hybrid battery upgrade on a 2001 by replacing the cells with ones from a newer battery and the job wasn't bad at all. I really appreciate all of you. The past two days I have driven the car quite a bit and have noticed that during regular driving it does great, the triangle only comes on when you have to sit at a red light or in slow traffic for a while, and then not always. I'm going to call a dealer tomorrow and set up an appointment, I will let you guys know what I find out.
  13. seilerts
    3,326
    1,518
    Santa Fe, NM
    Cool. Note that the three digit info codes are crucial. If all you get back is a report of "P0AA6 replace transaxle," that is entirely not helpful. Many dealership techs either don't know this, or it doesn't make it past the service advisor into the record..
  14. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    From the last 4 sentences it really does sound like a stuck relay, the lack of charge to the 12V complicates things even more.
  15. Alan14
    Alan14 New Member
    Santa Cruz
    I jus got a 2006 Prius from a friend (who doesn't have advice on this) and now it won't start. Same as the following entry: it has a smart key and will get as far as neutral but won't go into reverse or neutral and the brake light comes on and is working....any advice? THANKS!
    from the following I see I am not the only one with this problem....:
  16. JC91006
    JC91006 Senior Member
    16,762
    8,562
    Check the 12v battery
  17. bisco
    51,844
    how many miles on her? if it's not the battery, possibly the shifter.
  18. JC91006
    16,762
    8,562
    If it's not the battery, then you'll want to return this back to your so called friend.
    No start situations can be very costly to fix in a prius
