Hybrid Car May Have Sparked Garage Blaze
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Octane, Apr 15, 2011.
  1. Octane
    Octane Proud Member of 100 MPG Club
    384
    56
    The Swamp, Southern FL
    The Volt been touted in every single news clip for the past year as an EV. However, when one of the first thousand of them burns, it's now a "hybrid."
    It's not a "hybrid." The Insight, Prius, Civic, Accord, Escape, Lexus, and whatnot are hybrids. The Volt is a plug in hybrid and is the first of its kind (as a fully bore released production vehicle as best as I know.) I believe the purpose of calling it a hybrid is to smear all hybrids and to put the seed of doubt into the viewer's mind even though hybrid technology has been around for a decade without any sort of issues of this nature. It's an attempt to further marginalize the ever more widely accepted technology.
    If my car were to burn and it was called a "Prius Hybrid" without any mention that I happen to have plugged the "hybrid" into the wall and that's what caused the fire, that would be an intentional misrepresentation of the facts.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    NASA should look into it. There could be gremlins in the electricity. ;)
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Yep, that's it
  4. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    did they find the penny in the fuse box yet?
  5. Octane
    384
    56
    Wow, you are ANCIENT.
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Classic spin 101.
  7. fuzzy1
    10,521
  8. hill
    8,836
    So . . . keep the Volt 100 feet from any building while charging, and then life will be good. What . . . should we all go back to buying the Ford Pinto if we want to get 37mpg?
    No? ok then, let's move on.
    :rolleyes:
  9. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I know about a garage that burned down recently due to a faulty standard gas car OH I am sorry that isn't news .... maybe there was a hybrid involved!:eek:
  10. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    most definetly!
  11. DavidA
    2,345
    1,821
    Chicago western burbs
    Give the man some credit. He showed a pic of a 2007 penny. That's fairly up to date, no?
  12. Octane
    384
    56
    I'm torn with that statement. A 2007 penny behind a glass AC fuse is like putting an apple sticker on a bell rotary phone.
  13. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    Is a 2007 penny even conductive anymore?
  14. Politburo
    Politburo Active Member
    971
    208
    I'd think so, since it's still plated with copper. Plus it's not like zinc is an insulator.
  15. austingreen
    austingreen Senior Member
    13,681
    4,219
    Austin, TX, USA
    Many people own old houses:D But what is this rotary phone you talk of?
    Sure they are.
    Now that we have circuit breakers I doubt many people are putting pennies in the fuse box and starting fires. But I also doubt it was the volt.
  16. SlowTurd
    1,156
    333
    nj
    WOW! you must be ancient also!!!
    you knew that the older buss fuses were made from glass
  17. fuzzy1
    10,521
    I still haven't unplugged that rotary phone. It has outlived at least four 'modern' phones, corded and cordless, and hasn't gone dead during the extended (>24 hours) storm-related power outages.
  18. fuzzy1
    10,521
    Another potential case, though probably still guilt by association at this point:
    Investigators work to determine cause of fire
    "MOORESVILLE, N.C. -- Investigators are focusing on an electric car and its charger after a fire nearly destroyed a Mooresville home.
    ... Investigators have determined that the fire started in the garage, but they have not determined exactly what caused it
    A General Motors electric car was connected to a charging station in the garage. ..."
  19. walter Lee
    1,126
    376
    Maryland
    One possibility is that the internal wiring of the home was not upgraded (e.g. from aluminum to copper wiring) so while the 240VAC charger and the proper circuit breaker upgrade were installed to handle the extra electrical load -- the internal wiring was not able to handle the extra load and overheated (causing the housing insulation to burnup).
    BTW - those rotary phone are really sturdy and all they need to work is the tiny current that the phone line already provides.
  20. hill
    8,836
    Zombie thread. Still, it's funny the news clip show a Nissan Leaf driving by, even though the charger cable clip was that of a Siemans model. Talk about tossing a bunch of old photos together in a mish mash fashion.
