So.. traction battery is the bottle neck?
Discussion in 'Gen 3 Prius Technical Discussion' started by cyclopathic, Apr 15, 2011.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    was going through GEN III specs..
    Gasoline Engine
    Type
    1.8 Liter Aluminum DOHC 16-Valve Variable Valve Timing with intelligence (VVT-i),
    98 hp @ 5200 rpm (73 kW @ 5200 rpm), 105 lb.-ft. @ 4000 rpm (142 N•m @ 4000 rpm)
    Electric Motor
    Motor type: Permanent magnet AC synchronous motor
    Power output: 80 hp (60 kW)
    Torque: 153 lb.-ft. (207 N•m)
    Voltage: 650V maximum
    Traction Battery
    Type: Sealed Nickel-Metal Hydride (Ni-MH)
    Power Output: 36 hp (27 kW)
    Voltage: 201.6V
    Hybrid System Net Power: 134 hp (100 kW)
    so the total Hybrid net power gas engine + max traction battery output, 98hp+36hp = 134hp.
    one cannot stop wondering how better MPG would have been if discharge rate of the battery would be x2.. obviously combined power output would have been higher!
  2. qbee42
    3,079
    It is. Also keep in mind that in general part of the power from the ICE goes through MG1 to MG2. Only in a few select cases could you truly add the total power of MG2 to the power of the ICE. This is how the PSD works.
  3. carpedal
    carpedal Member
    37
    58
    Centreville, VA
    Batteries don't like being quickly discharged. A bank of Ultracapacitors could be used in conjunction with the traction battery for a quick boost in energy during acceleration. The traction battery could also be enlarged from 1.3 kilowatts, but then weight would go up. The problem with the Volt is 16 kilowatts of battery dead weight the car has to lug around until the next charging port is reached. I believe that Toyota has made a good balance between battery weight vs output in the current generation Prius. Any small change can make mileage worse instead of better. Just look at the identical drivetrain in the CT200h as an example.
  4. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Also note the battery can only discharge 27 kW (36 hp) for about 1 second, thereafter it can only sustain 21 kW (28 hp), giving sustained peak power of 126 hp (98 + 28).
  5. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    It's one of the advantages that PHEVs and EVs have.
    The Prius PHV will have more power available due to its larger pack. Of course, in an HEV you're better doing heavy acceleration on the gasoline engine anyway.
  6. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    That's exactly what I pointed out in another thread. The Prius is really tuned to the HSD and vice versa for max fuel economy.
  7. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    MPG wouldn't really be any better with higher discharge rates from the HV battery. if you're asking for 20kw+ of power the ICE would be running in it's maximum efficiency zone.
    The limiting factor is really the boost converter. You can allow higher discharge rates, but you won't get more than 25kw onto the 500V bus. This has been enlarged for the upcoming prius PHV.
  8. fuzzy1
    10,431
    I'm wondering how this would help MPG at all.
    A higher battery rate would capture more regen from drivers with a heavy brake foot.
  9. qbee42
    3,079
    Not better at all. Argonne National Laboratory did an extensive tear-down and test of the Prius. One of the interesting findings was essentially no loss of mileage when the HV battery was reduced to half of its initial capacity. In other words, the battery starts out twice as big as it needs to be. Changing that number to four times isn't going to help.
    Only under very special driving conditions will a bigger battery help. For most drivers it would only add unneeded weight.
  10. richard schumacher
    7,664
    1,046
    United States
    The battery is as big as it is for longer life (relatively smaller range of charge and discharge in normal use).
    Efficient power- and energy-dense batteries are Really Hard. That is why we haven't been tooling around in Edison Electrics for the last 100 years.
  11. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Under the Euro test, the CT200h is getting about the same mileage as the Prius. In fact, slightly better with the 15" wheels, despite being about 40 kg heavier and with CD of 0.28.
    Must be that the drivetrain have gone evolutionary refinement and it is tuned differently.
    Giora.
  12. cyclopathic
    3,292
    547
    2014 Prius c
    on the same route I can get much better (5-10%) MPG running at speeds <45MPH then at 45-50MPH. Reason? at speeds above 45MPH ECU does not shuts engine as often and does not like running on electric only. Battery capacity isn't an issue as it stays above 75%. The only way I can force to discharge it below 50% if the speed kept under 25MPH.
    Avg speeds on US extra-urban roads at least 10-20MPH above 45MPH
    Also on avg drivers on the road brake at rates far exceeding max charge rate, which makes it difficult to capture energy in regenerative braking.
  13. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    According to the report, battery capacity is down to 39% after 160K miles.
    It doesn't say anywhere there's no loss of mileage.
  14. Flaninacupboard
    1,297
    213
    Midlands - UK
    tpfun, as you've never driven a prius you won't know this, but the display in the vehicle covers 40% to 80% SOC window. It's rare to see it get full (8 bars) unless going down a mountain, and it's rare to see it get empty unless crawling for a few miles at consistent very low speeds. My point is that even the 40% SOC window is more than required with the software set the way it is. going down to 39% is going to have such a small difference it would get lost in the noise. It certainly wouldn't be apparent in NEDC or EPA testing.
  15. cyclopathic
    3,292
    547
    2014 Prius c
    Agree, more battery capacity not necessarily translates in better MPG, and under most conditions only small % of battery is used. In stealth mode on Gen III ECU cycles engine on/off while maintaining ~75% charge. Perhaps Toyota calculated then cycling engine on/off every 4min vs every 2min doesn't saves that much fuel but kills traction battery alot quicker.
    However the capacity is a separate issue from higher discharge rate as you can have a battery with smaller capacity and higher discharge rate. As is stealth mode is impossible at 70+MPH, unless you are going downhill. This probably due to max output battery/electric motor can put out, which btw is limited by discharge rate
