Car bounces after parking.
Discussion in 'Gen 3 Prius Technical Discussion' started by Garybaldi, Apr 16, 2011.
  1. Garybaldi
    Garybaldi Junior Member
    US
    I have Prius IV. When I push to park the cars bounces back and forward. I noticed when I push Power instead of park it does it less but it's still there. Any suggestions? this is the only unpleasant experience with Prius.
  2. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Use the parking brake after you press park (and before releasing the regular brake).
  3. Tideland Prius
    16,621
    Ditto. Use the parking brake.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I wish mine bounced back and forth after parking. ;)
  5. qbee42
    3,079
    Try using the Chicago Touch method when you park.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I really don't want to ask for an explanation do I? lol OK, does it involve sheep?
  7. qbee42
    3,079
    You use the front and rear bumpers as feelers:
    Back in - Bump!
    Pull forward - Bump!
    Back up halfway.
    A perfect parking job every time. :D
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ Ah, OK I thinking something totally different. lol
  9. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    I understand your comment regarding bouncing when parking, but help me understand what you mean when you say, 'I push Power instead of park...' Do you mean when you start the system, after it's been turned off from parking?
    My Prius rolls slightly after I turn it off, but I keep my foot on the brake until the car stops completely on the parking knuckle. I'll use the manual parking brake if I'm on an incline.
  10. bisco
    52,390
    is the car completely stopped before you push park? i'm staying out of the spidey/qb conversation!:flock:
  11. frodoz737
    frodoz737 Top Wrench
    4,721
    2,517
    33
    Sheep and Chicago style aside...
    Set parking brake first...then press park or power (which automatically puts it into park).
  12. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    I checked directly with Japan. They feel it should be a pleasurable experience.
    Japan is Weird - If the car's rockin', don't come a-knock
  13. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
  14. Garybaldi
    US
    Well one can push the Power on/off bottom while the car is on and stopped to put it on park and turn it off at the same time. old cars had this habit, i would think that Prius would handle this better.
  15. bisco
    52,390
    what habit?:noidea:
